[Case Gallery] Brushed Silver Z72
randomperson21
1,531 (0.22/day)
San Luis Obispo, CA
Processor AMD Athlon64 X2 3800+ @ 2.4Ghz
Motherboard ECS NForce4 A-939
Cooling CPU: Zalman CNPS7000B-AlCu GFX: Zalman VF-700AlCu, 2x120mm+5x80mm w/ Ultra 7ch Fan Controller
Memory Kingston 2x512MB DDR PC3200 Dual Channel 3-3-3-8
Video Card(s) EVGA Nvidia 7900GT KO Superclocked
Storage 2xSeagate Barracuda 7200.8/9 160GB SATAII NCQ in RAID0: 300GB total capacity
Display(s) Samsung SyncMaster 941BW (19" widescreen, 1440x900)
Case Antec P180B
Audio Device(s) Built in. 5.1Ch Logitech Z-5500 500w soundsystem, digital Coax connection
Power Supply Spire 500W
Software Windows Vista Ultimate
Specs:
Intel PXA 312mhz Processor
32MB RAM
320x320 TFT-LCD Display
2GB External Storage
1.2MP Camera
Bluetooth v1.0
PalmOS 5.2.1
Mods:
Removed blue rubberized paint using fine 120grit sandpaper, used sandpaper to get "brushed aluminum" look on underlying metal. Replaced launcher with appshelf, patched in FAT32 support.
My Zire72 was getting fugly like with all the peeling blue paint... and now its pretty!
you want to try this yourself, heres some tips:
1. sand laterally. if you sand in the same direction always, you get a nice brushed metal look, instead of random scratches.
2. don't sand too much. the whole body isn't made of metal, its only coated in metal. sanding too much will get you down to plastic
3. cover up the screen while sanding so you don't scratch it. scratches are bad.
4. cover all open ports, otherwise they'll be filled with gunk.
PVTCaboose1337
Graphical Hacker
9,501 (1.40/day)
Texas
System Name Whim
Processor Intel Core i5 2500k @ 4.4ghz
Motherboard Asus P8Z77-V LX
Memory 2 x 4GB G.Skill Ripjaws @ 1600mhz
Video Card(s) Gigabyte GTX 670 2gb
Storage Samsung 840 Pro 256gb, WD 2TB Black
Display(s) Shimian QH270 (1440p), Asus VE228 (1080p)
Case Cooler Master 430 Elite
Audio Device(s) Onboard > PA2V2 Amp > Senn 595's
Power Supply Corsair 750w
Software Windows 8.1 (Tweaked)
Looks pretty nice. Good job.
disarmedmeteor
91 (0.01/day)
Processor Core 2 Duo E6300 @ 2.00 GHZ @ 1.28V
Motherboard ASRock 775Dual-VSTA
Cooling 1 Zalman VF900 + AS5 on graphics card
Memory 2 x 512 MB DDR 400 Dual Channel
Video Card(s) x800GTO Unlocked to 16 pipes and stable Overclock at 513/550 core/mem
Storage 2 x 250 GB Samsung Spinpoint SP2504C in RAID 0 with 32k Stipe Size
Display(s) Princeton VL158
Audio Device(s) Realtek ALC 888 8 channel onboard
Power Supply 350W Antec PSU
heh, sanding.....
132 (0.02/day)
New York, NY
NICE TO SEE SOMEONE AS CRAZY AS ME!
I actually did that with my razr. i don't use the phone anymore i was just bored rofl. I covered the portholes, key-pad and screens with painters tape and cut it to size with a razor blade. I sanded with 600 and then used 0000 steel wool to get the brushed metal look. For the record you can't do this to the whole razr. Much of it is plastic so it will be a zebra when you are finished...
randomperson21
1,531 (0.22/day)
San Luis Obispo, CA
Case Antec P180B
ex_reven
5,217 (0.79/day)
nice pda man
i personally love the brushed chrome look
its plain, but stylish at the same time, and it stands out well.
Is there a guide you used for sanding/painting cases that you used?
Im looking to repaint my old compy (came out blotchy last time)
:toast:
132 (0.02/day)
New York, NY
try keeping your speed constant and do a 50/50 overlay on each pass so you have as even of a coat as you possibly can. As far as sanding goes....depends on the material.
ex_reven
5,217 (0.79/day)
standard case (cheapy generic)...im guessing sheet metal?
randomperson21
1,531 (0.22/day)
San Luis Obispo, CA
Case Antec P180B
@ex_reven,
nope, i just whipped out some sandpaper and sanded away. not exactly the best method, imo, but it works.
FanATIc
132 (0.02/day)
Gothemburg, Sweden
Processor C2D E6700ES stepping 5 rev B1 @ 3.2GHz
Motherboard Abit AW9D-MAX (bios 12)
Cooling Thermalright XP120+Revoltec 120mm red UV fan
Memory Corsair DomminatorTWIN2X6400C4D DDR2,2x1GB DHX E.P.P CL4-4-4-12T
Video Card(s) Sapphire X1950PRO+ Artic Cooling Accelero X2 @ 670MHz GPU
Storage Seagate Barracuda 7200.10 NCQ 160GB 16MB cache Sata II
Display(s) iiyama ProLite E1900S TFT19' 2ms
Case Akasa Eclipse 62
Audio Device(s) Creative SB X-FI Xtrememusic
Power Supply Tagan Easycon 580W
Software Win XP MCE .:original:.
Not really a mod but, it's ok
5/10
145 (0.02/day)
System Name Orion R7
Processor AMD Ryzen7 1700 at 4GHz
Motherboard ASUS Crosshair 6 Hero
Cooling Noctua HN-D15
Memory 2x 8GB DDR4 3200MHz G.SKILL TridentZ RGB
Video Card(s) EVGA NVIDIA GTX1080 ti FE
Storage 500GB Samsung NVMe SSD + 500GB Samsung SATA + 1TB HGST HDD
Display(s) AOC 27" 1080P
Case CM HAF
Power Supply 650W EVGA G2
Software Microsoft Windows 10 1709 Fallen Creatures :) Update 64bit
I voted 7/10 because:
Everyone that dare to do something like this deserve a medal :)
