- Jun 27, 2012
- 8 (0.00/day)
- TURKEY
System Name | TJ 07 Custom Mod |
Processor | Ryzen 7600x |
Motherboard | B650 TOMAHAWK WİFİ |
Cooling | Custom Water Cooled |
Memory | Xpg 2X8 16Gb 6400Mhz Cl32 |
Video Card(s) | Asus Rog Strix 3090 Oc |
Storage | Kioxia G2 2Tb Gen4 |
Display(s) | Dell G3223Q |
Case | TJ 07 |
Power Supply | Corsair Ax850 |
Hello guys. I'm Yusuf. Today I would like to share with you my new project.
OLD ZUI [TJ 07 BUİLD]
First of all, I would like to talk a little about the project, its content and myself. I have been using liquid cooling for about 15 years and I renew my parts from time to time. In this project, I will use both some of my old parts and new parts.
This is the first project I made to share. I named it OLD ZUI because of some of the old parts I used in the project. Everyone knows the Silverstone TJ 07 case. The project I'll use the my old TJ 07.
I will share the construction process with you step by step, please feel free to share your comments, ideas and criticisms during this process.
Let's start with the parts I will use first.
MAİN PARTS
Cpu : AMD Ryzen 5 7600x tray (New)
MoBo: MSI B650 Tomahawk wifi (New)
Ram: XPG Lancer RGB Black 32Gb 6400MHz Cl32 (New)
Storage: Kioxia Exceria Plus G3 2TB 5000/3900MB/sn NVMe (New)
Gpu : Asus ROG Strix GeForce RTX 3090 OC Edition (Used)
Case : Silverstone Tj07 Black ( Too Old and pre modded)
Psu : Corsair Ax850 Full Modular ( Too Old)
WATER COOLİNG PARTS
Cpu Block : Corsair Hydrox Series XC7 RGB PRO (new)
Gpu Black : TT Pacific V-RTX 3080/3090 Plus (ASUS ROG) (Used)
Pump/Rez : TT Pasific DP100-D5 Plus RGB (Used)
Rad : Magicool G2 480mm 45mm thick (Old)
Rad : EK Coolstream PE 360mm (Too Old)
Fan : Corsair Sp120 Blue Led x3 (Old)
Fan : GT Ap-15 1850rpm X6 (Too Old)
SPARE PARTS
14MM Hard Tube fitting.
Rotary and Angeled fitting.
Bitfenix Alchemy White Sleved cable (Too Old)
Some 360mm//120mm rad grills.
Fan Controller and Some other modding parts.
MAİN PARTS
WATER COOLİNG PARTS
SPARE PARTS
