Bus interface is different on each boot, need help
4 (0.01/day)
Motherboard MSI b650 gaming plus wifi
Memory G.Skill 32gb 6000Mhz
Video Card(s) MSI 4080 Super
Power Supply Corsair RM1000x
GPU is running at multiple different bus interfaces for seemingly no reason?
I've seen 4 different bus interfaces and the only way to change the bus interface is by restarting/shutting down the PC
Clicking the "?" to open up the graphic also doesn't change the bus interface, neither does running a game.
The PCIe lane will just be stuck at whatever it boots up with.
Here's the 4 combinations I've seen:
16x 3.0
1x 4.0
2x 4.0
16x 1.1
16x 4.0 (which should be the normal one)
I don't believe this is GPU-Z being wrong, because whenever it does run at lower bus interfaces I do notice really big FPS drops and microstutters.
I have tried reseating and cleaning the golden pins on the GPU multiple times, but to no avail.
Also checked for bent pins in the CPU socket, but everything looks normal there too.
Don't really know how to fix this and not sure which component to RMA if there is no fix to this.
486 (0.16/day)
Processor Intel i7 4770k
Motherboard ASUS Sabertooth Z87
Cooling BeQuiet! Shadow Rock 3
Memory Patriot Viper 3 RedD 16 GB @ 1866 MHz
Video Card(s) XFX RX 480 GTR 8GB
Storage 1x SSD Samsung EVO 250 GB 1x HDD Seagate Barracuda 3 TB 1x HDD Seagate Barracuda 4 TB
Display(s) AOC Q27G2U QHD, Dell S2415H FHD
Case Cooler Master HAF XM
Audio Device(s) Magnat LZR 980, Razer BlackShark V2, Altec Lansing 251
Power Supply Corsair AX860
Mouse Razer DeathAdder V2
Keyboard Razer Huntsman Tournament Edition
Try disabling Resizable BAR, see if it makes a difference.
4 (0.01/day)
I'll give that a go next time it boots up on x1, thanks for the suggestion!
I just tried my old 1080 and that card was running at x16 even after 8-10ish restarts, although it did boot up on x16 1.1 once
204 (0.12/day)
WorldWideWeb
System Name ROG
Processor i5-11400F
Motherboard ROG Strix Z490-H Gaming
Cooling Be Quiet Pure Rock (BK009)
Memory Kingston Fury RENEGADE KF3600C16D4/16GX (KIT 2x16)
Video Card(s) GTX1060 6Gb AERO ITX OC
Storage NVMe WD Black SN750 ; Samsung EVO 840 SSD and Mechanical TBs...
Display(s) iiyama Black Hawk G-Master GB2745HSU
Case CM HAF-X
Audio Device(s) Yamaha AV Creative DTT2200
Power Supply Corsair RM-1000
Mouse SteelSeries Rival
Keyboard MS Sidewinder X6
Software Windows 10/11
What mb model/brand, what GPU brand (MSI it seems...)?
Have you tried to seek for GPU vbios updates of the brand? MB bios updates also...
The 4080S is a relatively new gpu on thw wild...so
It can be a compatibility issue, or hw issue from one or another...
980 (1.40/day)
System Name BarnacleMan
Processor 14700KF
Motherboard Gigabyte B760 Aorus Elite Ax DDR5
Cooling ARCTIC Liquid Freezer II 240 + P12 Max Fans
Memory 32GB Kingston Fury Beast
Video Card(s) Asus Tuf 4090 24GB
Storage 4TB sn850x, 2TB sn850x, 2TB Netac Nv7000 + 2TB p5 plus, 4TB MX500 * 2 = 18TB. Plus dvd burner.
Display(s) Dell 23.5" 1440P IPS panel
Case Lian Li LANCOOL II MESH Performance Mid-Tower
Audio Device(s) Logitech Z623
Power Supply Gigabyte ud850gm pg5
Keyboard msi gk30
I had a MB that would only boot GPUs with x8 lanes. It didn't matter so much because it was gen 4 but still, it really pissed me off that I could never figure out the problem.
Have you tried running a stress test to see if it anything is being lowered for power saving reasons? (press the little question mark button). Do you have many other pcie devices?
4 (0.01/day)
MOBO is MSI b650 gaming plus wifi and yes the GPU is also MSI
BIOS is on the newest version and I got the latest drivers for the GPU, but unsure on how to update "vbios"
I have tried running stress tests, but I couldn't really figure out if there was anything else that was lower/lowered other than the bus speed.
On a side note I tried switching the GPU from "silent" to "gaming" with the little switch that is right above the atx 3.0 port, so hopefully this is gonna fix it!
3,778 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
16x 3.0
1x 4.0
2x 4.0
16x 1.1
Please fill your system specs information with details on your profile and make it visible to all users
Its easier and faster if everyone can see your system in a glance.
The only thing that changed on system lately is the GPU or its a new system build together as is now?
446 (0.84/day)
System Name No.1
Processor Ryzen 9 9900X with custom PBO + 2200 FCLK fully stable
Motherboard B650 Gigabyte Aorus Elite v1.0
Cooling Thermaltake toughair 710 + Thermal Grizzly Kryonaut extreme
Memory Patriot Viper PVV532G740C36K @ 6200MT/s 30-36-36-63 1:1
Video Card(s) Asus TUF gaming RX 7900 XTX OC edition
Storage 1TB T-Force Z44A7 + 2TB T-Force A440 Pro
Display(s) 34 " Asus TUF Gaming VG3A series
Case Antec C8 constellation white edition
Audio Device(s) Asus Xonar AE 7.1 + Logitech Z906
Power Supply Corsair RM1000x V2
Mouse MSI Clutch GM20 Elite
Keyboard Logitech G512 Carbon
OP, drill down in the bios and ensure your primary GPU slot is set to gen 4 & 16x. Do not leave it on auto. This looks like a MB bios quirk for this particular model of GPU.
I had this issue before on my Z590 MSI Unity board back in its day.
240 (0.25/day)
Processor 7950X, PBO CO -15
Motherboard Gigabyte X670 AORUS Elite AX (rev. 1.0)
Cooling EVGA CLC 360 w/Arctic P12 PWM PST A-RGB fans
Memory 64GB G.Skill Trident Z5 RGB F5-6000J3040G32GA2-TZ5RK
Video Card(s) ASUS TUF Gaming GeForce RTX 3070
Storage 970 EVO Plus 2TB x2, 970 EVO 1TB; SATA: 850 EVO 500GB (HDD cache), HDDs: 6TB Seagate, 1TB Samsung
Display(s) ASUS 32" 165Hz IPS (VG32AQL1A), ASUS 27" 144Hz TN (MG278Q)
Case Corsair 4000D Airflow
Audio Device(s) Razer BlackShark V2 Pro
Mouse Logitech M720
Keyboard G.Skill KM780R MX
Software Win10 Pro, PrimoCache, VMware Workstation Pro 16
Do some benchmarks under vastly different reported speeds and see if you're getting different performance. Maybe it's a reporting issue only. Maybe multiple monitoring software causing reporting issue.
4 (0.01/day)
The build is completely new, no used components or anything of the sort.
I can manually set it to Gen 4, however the PCI lane option does not have a 16x option, only x8+x8, x8+x4+x4, and I think one more 4+4+4+4 option
The PCIe lane option still didn't show 16x as an option when I tried my old GPU
I don't believe GPU-Z is showing me the wrong info, because I usually drop 90-180 FPS whenever it's running at x1
Youseethis
17 (0.03/day)
Try the bios version 7E26v13 with the agesa 1.0.0.7c. This will probably fix your problem.
Tolits67
3 (0.05/day)
16x 3.0
1x 4.0
2x 4.0
16x 1.1
hi, could you please tell how you managed to fix this? I to have this problem and the only similar component i have with you is the mother board. Thinking of RMA to but not sure which component to send back. Thanks
1,767 (3.98/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
It is actually normal for the Bus width to throttle when idle, using 2D applications.
To test this theory, open GPU-Z and click the little question mark right middle. It will open up a render. With another instance of GPU-Z open monitor the Bus width and see if it increases. It should, it's normal operation. If this doesn't fully load the graphics card, you will have to run full screen mode, but can use a second screen to monitor the Bus widths stuff.
If you want your system in full performance mode, then set this in the system settings instead of power saving or balanced mode.
GL!!!!
Tolits67
3 (0.05/day)
GL!!!!
Hi! Thanks for the reply. I did what you have just said but did not change. Maybe move abit but still x1 4.0 instead of x16. Funny thing os i can make it normal by booting in bios first. Stay more than 30 seconds without doing anything, then boot towindows and its back to x16 and normal. If i restart or poweroff and reboot withoitngoing to. Bios, it returns back to x1 4.0. It worries me as gpu z shows i ave my gpu on a wrong pcie slot but ita correct, i have no options in bios to force x16.
Specs:msi mag b650 tomahawk wifi
4070 ti super asus tuf
Ryzen 7 7700x
Corsair rm 850 x
Corsair cl30 6000 16x2
7,447 (4.96/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Ryzen 7 7700x
Corsair rm 850 x
Check for debris on your PCI Express slot. Just pulling the card out and blowing the slot with a can of compressed air or something similar should do the trick. It can cause this sort of behavior. Could be even a crumb of something or some dust that got there while you were building your machine.
980 (1.40/day)
Processor 14700KF
Keyboard msi gk30
Have you tried turning off link state power management? Thats the one that lowers pcie gen for power reasons. Its probably not the source of your problem, but it would at least take one more variable off the board to help diagnostics, if nothing else. Also, it helped me when my p5 plus wasn't waking up properly and its sequential read was 1/3 what it was supposed to be.
Choose my power plan>change plan settings>change advanced power settings>pcie express>link state power management.
And turn to off.
press apply
And yes cleaning the pcie slot with air is a good idea. ^^^
Tolits67
3 (0.05/day)
Hi
And turn to off.
press apply
Hi. First of all thank you for you time to reply and check/help with my problem. I managed to see on reddit same problems 6-7 mo ths ago and confirmed as a bios issue. I decide to do one more restart/cold boot to confirm changing pcie from x16 to x4. Then reset my bios settings from stock and updated to the latest stable bios. Successfully done and now it stays on x16 4.0. Did test out by restarting, shut down, cold boot, bios boot, windows boot. Unplugged and opened and no instances that it went back to 4.0. I will continue to. Monitor but for now, im at peace. Thanks again
