bust interface issue can't enable PCIe 3.0 x16
Freacks
3 (0.01/day)
Hello everyone
My specs:
cpu: ryzen 5 5600x
mb: asus rog strix b450 f gaming
gpu: rx 6700 saphire pulse
so I am facing an issue where I can't enable PCIe 3.0 x16! it only detect PCIe 3.0 x8 checked by AMD software and gpu-z
I tried resetting the bios settings and clearing the camos.. also tried changing the pcie settings on the bios settings to support the PCIe 3.0 x16 but still using PCIe 3.0 x16!
I tried DDU and installing the previous driver and the newest driver but same
I tried cleaning pins and checking cables but the same thing
is there any solution?
43,306 (6.75/day)
Hello everyone
My specs:
cpu: ryzen 5 5600x
Yeah, please open your motherboard manual to page ix and read the info near the astrixes (*)
this is why i loathe m.2
1,425 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
outside removing the m.2 drive from bottom slot there is really nothing you can do. Its gonna run at x8 which likely not gonna effect performance anyway. tpu has pci express scaling tests they do and on a RTX 4090 going from 16x to x8 3.0 only effected that at around 3%. Your card should be at most 1% to likely 0%.
233 (0.10/day)
Processor Intel i5-13600KF
Motherboard ASRock Z790 PG Lightning
Cooling NZXT Kraken 240
Memory Corsair Vengeance DDR5 6400
Video Card(s) XFX RX 7800 XT
Storage Samsung 990 Pro 2 TB + Samsung 860 EVO 1TB
Display(s) Dell S2721DGF 165Hz
Case Fractal Meshify C
Power Supply Seasonic Focus 750
Mouse Logitech G502 HERO
Keyboard Logitech G512
The 4090 shows from 3% to 6% loss going from 3.0x16 to 3.0x8, depending on resolution.
The 6600XT shows 1.2% to 2.2% loss, and the 6700 is probably closer to this than the 4090.
43,306 (6.75/day)
I have two m.2 installed ... how to fix then?
*** When the M.2_2 is occupied by M.2 device, PCIe x16_1 will run at x8 mode.
So you remove that m.2 device , place that it in a pcie 4x capable adapter card, and place it in the
PCIe x16_3 slot.
Otherwise you step up to a B550 or X570 based motherboard.
1,425 (0.31/day)
Processor i7-13700k
PCIe x16_3 slot.
to note doing that means the m.2 drive if its nvme will only operate at pcie 2.0 x4 so cutting that performance in half.
RJ
9 (0.00/day)
System Name Jaehaerys
Processor 4790K
Motherboard MSI Z97 G5
Cooling Corsair H100i
Memory 16GB Ripjaws 1866
Video Card(s) SLI MSI 980TI 6G
Storage Samsung 840 EVO 250GB-1TB Mushkin Reactor
Display(s) 27" 1440p Yamakasi Catleap/65" 4K Samsung KS8000
Case Corsair 760T
Power Supply Corsair AX760 PSU
Mouse Logitech G700
Keyboard Logitech G710+/ K70 in Corsair Lapdog
Software Win10
Benchmark Scores FireStrike 23K: http://www.3dmark.com/3dm/14897800 Timespy 10K : http://www.3dmark.com/3dm/14930947
Even on X870E, I have 5 m.2 slots but use only 2 internal m.2's, any more and I would lose x16 for the GPU. My GPU is pcie 3.0 so I need x16. I think on pcie 5.0 you can get away with x8 with negligible (if any) impact on GPU performance.
You can sidestep this limitation if you must have x16: AMD mandates 2 USB 4 ports on X870.
I use an external m.2 enclosure and run it via USB4, it maxes out at 5GB/s. My enclosure has an older onboard controller so I can't max out the USB4 throughput but enclosures with the new JHL9480 chip can. I think 5GB's is perfectly fine. As I said, my 4TB enclosure runs slower but it's still fast:
Toothless
Tech, Games, and TPU!
9,723 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
x8 is fine. Leave it alone.
