- Sep 1, 2020
- 2,261 (1.50/day)
- Bulgaria
System Name | The Little One |
Processor | i5-11320H @4.4GHZ |
Motherboard | AZW SEI |
Cooling | Fan w/heat pipes + side & rear vents |
Memory | 64GB Crucial DDR4-3200 (2x 32GB) |
Video Card(s) | Iris XE |
Storage | WD Black SN850X 4TB m.2, Seagate 2TB SSD + SN850 4TB x2 in an external enclosure |
Display(s) | 2x Samsung 43" & 2x 32" |
Case | Practically identical to a mac mini, just purrtier in slate blue, & with 3x usb ports on the front ! |
Audio Device(s) | Yamaha ATS-1060 Bluetooth Soundbar & Subwoofer |
Power Supply | 65w brick |
Mouse | Logitech MX Master 2 |
Keyboard | Logitech G613 mechanical wireless |
Software | Windows 10 pro 64 bit, with all the unnecessary background shitzu turned OFF ! |
Benchmark Scores | PDQ |
Maybe somebody will create a backside cooler & mobo that will be able to this ? Similar to what is happening with the wiring connector changes right now....No way to cooler the underside really, its totally going to overheat at higher speeds and voltages.
System Name | ab┃ob |
Processor | 7800X3D┃5800X3D |
Motherboard | B650E PG-ITX┃X570 Impact |
Cooling | NH-U12A + T30┃AXP120-x67 |
Memory | 64GB 6400CL32┃32GB 3600CL14 |
Video Card(s) | RTX 4070 Ti Eagle┃RTX A2000 |
Storage | 8TB of SSDs┃1TB SN550 |
Case | Caselabs S3┃Lazer3D HT5 |
Shorter traces will help in higher memory frequencies. Latency is mainly determined by the timings of the memory itself. It will probably be a few years before CAMM2 takes off, if ever.
The bad part about CAMM2 is going to be the dual-rank stuff. No way to cool the underside really, its totally going to overheat at higher speeds and voltages.
System Name | RemixedBeast-NX |
Processor | Intel Xeon E5-2690 @ 2.9Ghz (8C/16T) |
Motherboard | Dell Inc. 08HPGT (CPU 1) |
Cooling | Dell Standard |
Memory | 24GB ECC |
Video Card(s) | Gigabyte Nvidia RTX2060 6GB |
Storage | 2TB Samsung 860 EVO SSD//2TB WD Black HDD |
Display(s) | Samsung SyncMaster P2350 23in @ 1920x1080 + Dell E2013H 20 in @1600x900 |
Case | Dell Precision T3600 Chassis |
Audio Device(s) | Beyerdynamic DT770 Pro 80 // Fiio E7 Amp/DAC |
Power Supply | 630w Dell T3600 PSU |
Mouse | Logitech G700s/G502 |
Keyboard | Logitech K740 |
Software | Linux Mint 20 |
Benchmark Scores | Network: APs: Cisco Meraki MR32, Ubiquiti Unifi AP-AC-LR and Lite Router/Sw:Meraki MX64 MS220-8P |
so the original CAMM is better than CAMM2?Doesn't seem to have much value at all for desktop, anyway.
The LPDDR5x CAMM options are an interesting proposition for laptops.
