Can a gpu with a pcie 4.0 port suffer stuttering by being connected in a pcie 3.0?
11 (0.01/day)
System Name Windows 10
Processor Ryzen 5 1500x
Motherboard Asus Prime B350 m-a
Memory 16gb ddr4 3200MHz ballistix
Video Card(s) Sapphire pulse radeon rx 580 8gb
Case Aerocool Aero One Frost
Power Supply Nox Urano VX750W
Hi folks!
I have been saving money during months to upgrade my pc and i have adquired the following:
- Psu: Cooler master v850 v2 gold
- Cpu: Ryzen 7 5800x3d
- Gpu: msi rx 6950 tx gaming x trio
- Samsung oddysey g7 4k
The only thing i didnt upgrade is the motherboard, an Asus prime b350 m-a. When the time to finally install the gpu arrived, the games suffered a lot of stuttering and the gpu was making a high coil whine noise.
Could it be that, since the pcie of the gpu is 4.0 and the pcie of the motherboard is 3.0, the motherboard is causing this?
I run the system, as well as the games, in a samsung evo m.2. disk btw, in case you are wondering.
Edit: I forgot to mention the motherboard is second hand, has 5 years and the pcie has no "security flap", i dont know the name in english, but is the part at the very end of the lot that secures the gpu in place.
6,789 (4.73/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
Unless the bus is saturated, it will not cause stuttering. With the 6950 XT you should be safely able to max out your GPU's bandwidth with room to spare on a 3.0 x16 motherboard.
The security lock being missing will not affect performance, what may be occurring is poor seating due to its absence. Remove the card, clean the PCIe slot with some compressed air if possible and reseat the card, open GPU-Z and ensure that it says "PCIe x16 4.0 @ x16 3.0" in this box:
Good luck
3,606 (1.69/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
My 3080 seems fine.
17,269 (4.67/day)
Processor 7800X3D -25 all core ($196)
Motherboard B650 Steel Legend ($179)
Cooling Frost Commander 140 ($42)
Memory 32gb ddr5 (2x16) cl 30 6000 ($80)
Video Card(s) Merc 310 7900 XT @3100 core $(705)
Display(s) Agon 27" QD-OLED Glossy 240hz 1440p ($399)
Case NZXT H710 (Red/Black) ($60)
Good luck
a bit off topic, but how do you actually check in-game to see if its being saturated or not? like how do you know for sure? does the red circle item answer my question, and in-game status doesn't matter?
im really sleepy right now. sorry if this is dumb question
6,789 (4.73/day)
São Paulo, Brazil
GPU-Z has this data in the sensors tab. Look for "Bus Interface Load".
17,269 (4.67/day)
ok this is cool, I never realized this. so basically, just play demanding games, see what percentage is "max" when double clicked on bus interface load in gpuz, and as long as its under like 90% you are not coming close to saturating?
did my brain interpret this right?
10,771 (1.73/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 CL30-36-36-76
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
Any stuttering on the PCIE bus is usually due to errors or ASPM going badly etc. most of the time you can actually see these in event log. Also riser cables that arent fully compliant or faulty can cause pretty epic stuttering (this is pretty common in ITX builds) also shows up in windows event log under system, or in HWinfo.
On NV GPUs enabling resizable BAR will cause stutter in some DX12 ports (Borderlands, Witcher DX12, etc.).
42,247 (6.64/day)
He has left way too many details out on his specs...
6,789 (4.73/day)
São Paulo, Brazil
As long as it's below 99-100% you haven't used all bandwidth the interface can provide and should be safe. Of course, the absolute safety margin is always some 5% give or take but even then, that depends on how much bandwidth you have available in general.
I have a PCIe 2.0 x1 (physical) GT 710 that is so badly bus bandwidth starved that it will hit 100% bus load by simply playing a YouTube video at 1080p. Ouch.
11 (0.01/day)
I dont seem to find it ( see image attached). Now i seem to fix the stuttering, but the coil whine while gaming in 4k is quite annoying. Should I return the card? Because i see people all around talking about the coil whine not being a valid reason for a RMA and also being very frequent, to the point that even if you get a new one, it will also have coil whine.
ir_cow
4,484 (0.76/day)
USA
Your missing quite a number of sensors. Maybe AMD cards show less?
42,247 (6.64/day)
771 (0.23/day)
Earth's Troposphere
Mouse various/various/various
VR HMD -
@Yuanlee Chipset drivers up to date? And then after a graphicscard driver.
302 (0.34/day)
Germany
System Name Galaxy Tab S8+
Processor Snapdragon 8 gen 1 SOC
Cooling passive
Memory 8 GB
Storage 256 GB + 512 GB SD
Display(s) 2.800 x 1.752 Super AMOLED
Power Supply 10.090 mAh
Software Android 12
With raising VRAM sizes PCIe will not become a bottleneck soon, increased cache sizes on last gen AMD and current gen GPUs overall are another factor that remove bandwidth bottlenecking. Cards that suffer from PCIe bandwidth issues are cards like RX 6400/6500 with the gen 4x4 interface. GPUs like the RX 6950 XT with their x16 interface though do even run quite well on PCIe gen 2x16. The more limiting factor - when not limiting bandwith manually - would be pairing them with a CPU that is not capable of feeding the beast - which is not the case on your new build.
The question is: You bought a new monitor, what did you do with your old one? If you are running a multiple monitor setup you should read the "known issues" section of the display drivers. The stuttering might come from watching a video on the second display while playing a game on the new one.
11 (0.01/day)
Yes, everything is up to date.
I resolved the stuttering issue, it was some options on the amd software, but the coil whine still there and i dont know if i should return the card since a lot of people have coil whine in their high end gpus. Ill link a youtube video i myself recorded for the shop so you guys can listen the coil whine ( it is in spanish tho). Coil whine msi rx 6950 xt gaming x trio - YouTube
minute 0:40 onwards is showing the coil whine in fortnite 4k and heaven benchmark.
302 (0.34/day)
Germany
Cooling passive
Memory 8 GB
Software Android 12
Hey you already have one subscriber - not me though, wrong language ;). In your video there's a bit to much talking or I am just not susceptible to coil whine very much - did not hear anything that would bother me.
Btw. you should post the solution. If someone with comparable issues comes accross this thread there will be the solution present already.
11 (0.01/day)
Yes, the solution was, in the AMD radeon software, activate AMD freesync (as well as in the monitor) and disable HDCP in radeon software as well.
Also in the video the coil whine isnt that high, but in reality is more annoying than that.
6,789 (4.73/day)
São Paulo, Brazil
Check if it's not hidden (right click open GPU-Z settings and check the enabled sensors), if still not available try HWiNFO64?
No need to return the card imo, coil whine usually settles after some time. In my experience anyway...
3,896 (0.89/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
If that's the case, it could very well be a bad driver installation. Or it could be a bad cable or monitor controller if the HDCP handshake is causing issues. Did you install your monitor's drivers?
Coil whine is a fact of life with big powerful processors. Some cards are worse then others.
Count von Schwalbe
3,087 (2.78/day)
Knoxville, TN, USA
Have you thought about super gluing the chokes? Adding a little very runny super glue under the edges of the components making the noise can fix it.
12,344 (5.75/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Only Nvidia cards have that info.
To OP: coil whine has nothing to do with pci-e speeds. Don't worry about it.
Ruru
S.T.A.R.S.
12,797 (2.93/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-A
Cooling Arctic Freezer 50 / Thermaltake Contac 21
Video Card(s) RTX 3080 10GB / RX 6700 XT
Storage 3.3TB of SSDs / several small SSDs
Audio Device(s) Creative Omni BT speaker
VR HMD Oculus Rift CV1
962 (0.63/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 10 Enterprise 21H2 LTSC
In short:
If x16 lanes - no bottleneck
If x8 lanes - a little bottleneck
If x4 lanes - cr@p, get a card with x8/x16 lanes or put this card into a combo of pcie 4 capable cpu and mobo.
114 (0.10/day)
System Name Phenomenal1
Processor Ryzen 7 5800x3d
Motherboard MSI X570 Gaming Plus
Cooling Noctua NH-D15s with added NF-A12x25 fan on front
Memory Predator Vesta 32GB (2 x 16GB) DDR4 3600 BL.9BWWR.300 B-Die @3733 CL14
Video Card(s) PNY XLR8 RTX 4090 VERTO EPIC-X Triple Fan
Storage Boot SSD: SATA 500GB - 1tb + 4tb pcie3 nvme / Spinning Drives: 2tb + 6 tb
Display(s) Gigabyte M27Q 27" 1440P 170 Hz IPS BGR monitor
Case Fractal Torrent - Black
Audio Device(s) Realtek ALC1220P
Power Supply Super Flower Leadex VII XG 1000W
Mouse Razer Viper
Keyboard Razer Huntsman V2 Optical
Benchmark Scores Time Spy - 28594 https://www.3dmark.com/spy/51010148
I'm running an rtx 3080 which is a pcie4 card on a motherboard with a pcie3 slot and the performance is excellent.
42,247 (6.64/day)
