Can I plug a 3 pin fan into a 5 pin dell motherboard header?
Hitec
2 (0.00/day)
I wanted to change the original dell cpu fan out for a different 3 pin one, but the cpu header is a 5 pin. Can I use it like this? Or do I need an adapter?
3,094 (2.50/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
Best to consult the owners manual regarding the header pinouts. If you are still confused after reading the manual, you should contact Dell technical support.
(My guess is that they will advise you to replace it with a Dell-approved replacement unit.)
I've plugged in 3-pin fan cables into 4-pin motherboard fan headers but that was after consulting the motherboard owner's manual. I don't recall working on a system with a 5-pin fan header on the motherboard.
However with my experience with Dell hardware, often they lean toward their own proprietary solutions rather strictly adhering to industry standards.
Anyhow best of luck.
1,065 (0.30/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
a quick google say adapter required
no?
3,094 (2.50/day)
Again, this goes back to the OP needing to RTFM first.
1,065 (0.30/day)
Processor i7-11700K
Cooling Custom Loop
Mouse eats cheese
Keyboard warrior!
3,094 (2.50/day)
Well assuming the Dell forum participants are right (and that could be a big IF), it would be prudent to put a multimeter on the motherboard header to confirm that DC+ was on the alleged pin.
I suppose the likely casualty of an incorrectly wired fan would be the fan motor itself but it doesn't seem to be wise to approach this project with a half-assed methodology (or entire lack thereof).
But that's just me...
823 (0.45/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
