Can I stack thermal pads?
1,072 (0.57/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Philips
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
I'm going to buy thermal pads for my rtx 3080's vram but since there is no 2mm thermal pad available in my country I decided to buy Arctic TP-3 1mm. So if I stack two pads to get a 2 mm pad, will the thermal conductivity worsen?
7 (0.88/day)
Motherboard MSI Pro B650-P Wifi
Cooling EK D-RGB 240 AIO, Noctua Redux 120
Memory Gskill Flare 32GB CL36
Video Card(s) 9070XT Hellhound
Storage Crucial P3 2TB,Samsung Pro SSD 1TB
Display(s) AOC AG276QZD
Case NZXT S340
Audio Device(s) Logitech X140
Power Supply Cosair RM850
Mouse Logi G703
Keyboard Logi G413
VR HMD Quest 2 256GB
should be fine
dgianstefani
TPU Proofreader
5,358 (2.03/day)
Swansea, Wales
Benchmark Scores Legendary
Works fine, but you can also buy thermal putty and use that instead.
2,924 (0.65/day)
Fort Worth, TX
System Name LGA775 | BoX-Server
Processor Xeon E5450 OC3.6GHZ from 3GHZ | i3 3.4GHZ
Motherboard ASUS PQ5-EM | ASRock
Cooling 120MM Heatsink (2-FANs) | Custom HSK 90mm
Memory DDR2 2GB-x4=8GB | 8GB 2x4GB=8GB
Video Card(s) NVIDIA Quadro K2200 4GB | Intel
Storage 500\500/240/240GB SSDs 120GB Laptop IDE
Display(s) Asus 24"
Case DIYPC N1e-SPORT | CoolerMaster 110
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Rosewill RGB
Keyboard Rosewill RGB
Software WiN10ET/WiN11ET
From CHATGBT
Can you stack thermal pads
ChatGPT said:
Yes, you can stack thermal pads, but it's generally not ideal. Here are some things to consider:
Reduced Thermal Conductivity – Each layer adds resistance to heat transfer, making it less effective than a single, properly sized thermal pad.
Air Gaps – If not stacked perfectly, air pockets can form, reducing heat dissipation.
Compression Issues – Some devices require firm contact, and stacked pads might not compress evenly, leading to poor heat transfer.
Best Practices:
Use a single pad of the correct thickness whenever possible.
If stacking is necessary, try to use high-quality pads with good compression.
Consider using thermal paste in combination with a single pad for better results.
If you're trying to fill a large gap, you might also look into thermal putty or shims (like copper plates) to improve conductivity. What are you trying to cool?
1,072 (0.57/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Well I hope this solution would work better than stock.
Is it better?
2,703 (1.25/day)
PNW, USA
System Name Metalia
Processor AMD Ryzen 7 5800X3D
Memory 2x32GB DDR4-3600
I would recommend looking into <1mm copper shims and bond the shims to the cooler with paste, shim<->RAM with the 1mm pad.
Alternatively, as dgianstefani suggested,
Putty is less guess work, and typically still better than most thermal pads.
1,072 (0.57/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Ps. Stock pads are oily, sticky and hard to compress. Much of oil has been spreaded on the PCB.
I have copper shims already but not brave enough
2,269 (0.98/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
it will be fine and dandy but i once left the plastic on one pad and wondered for a while why my vram was getting hot but dont tell anyone eh ;-]..
545 (0.14/day)
If there is no air in between it should function well enough. Not as good as 1 but it should keep temps in check.
1,072 (0.57/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Well that's a good lesson to me:)
Btw, I'm still in shock that even "good and nice" manufacturers use shitty thermal interfaces.
Before changing GPU Tim with thermalright ptm, the fan was spinning like crazy.
183 (0.18/day)
From my experience with a dozen 3080s running with either 2mm or 1+1mm pads on the Vram for a prolonged time:
Sure you can stack pads.
Do it correctly, and the numbers will show no difference:
The idea is to help the pads to dry out evenly over time. To fuse , so to speak.
Scissors are the enemy here.
Box Cutters the hero !
1) align both pads and (removing the thinner cling film) put them together first.
edit: Same procedure as with applying vinyl stickers - the goal is to avoid trapping bubbles (thanks Dammeron!)
2) use a cutting board and cutter knife to cut the pads to size.
Scissors deliver a smushy, wrinkly cut that helps the pads ends to maybe dry up differently and maybe even part if you use oversized pads.
A cutter knife kinda smears both pads together evenly IF cut with even pressure in one swoop starting away from the pad and moving towards it.
fyi:
IF changed completely every year those pads go well with thermal paste on both sides that touch metal.
-2c is what you get for a lot of yearly recurring cost and maintenance (since the paste will dry out into the pad)
837 (0.21/day)
Poland
System Name Proper
Processor 5900X + OC
Motherboard GB X570s Elite AX
Cooling WC Heatkiller 3.0 LT
Memory G.Skill 3600 CL16
Display(s) GB M32Q
Case Fractal Define R6 USB C
Mouse Log G502 X LS
Software Win10 Pro
The conductivity will definitely worsen compared to a single 2mm pad, since You introduce another gap between surfaces filled with micro air pockets. But by how much...? Too many variables in play to specify. Just do it and monitor the temperatures for the first few days - if everything stays within normal margins, just leave it.
1,072 (0.57/day)
Turkey
System Name MSI-MEG
Memory 32 GB
A cuter knife kinda smears both pads together evenly IF cut with even pressure in one swoop starting away from the pad and moving towards it.
fyi:
-2c is what you get for a lot of yearly recurring cost and maintenance (Since the paste will dry out into the pad)
What a perfect guide for me thanks!
Should I also change the phase change material that was applied to GPU die?
1,072 (0.57/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Hello everyone. I changed the thermal pads with Arctic TP3 (1mm stacked to get 2 mm) and the results are impressive. I got nearly 10 degree celsius lower than to stock. That is massive. Taking into account that the MSI Suprim is the top tier GPU series of MSI, I never understand why they use such low quality of thermals for vram and gpu die. Here are the results. (measurements were recorded during flight sim in highest settings with 2k)
