System Name | Quantumville™ |
Processor | Intel Core i7-2700K @ 4GHz |
Motherboard | Asus P8Z68-V PRO/GEN3 |
Cooling | Noctua NH-D14 |
Memory | 16GB (2 x 8GB Corsair Vengeance Black DDR3 PC3-12800 C9 1600MHz) |
Video Card(s) | MSI RTX 2080 SUPER Gaming X Trio |
Storage | Samsung 850 Pro 256GB | WD Black 4TB | WD Blue 6TB |
Display(s) | ASUS ROG Strix XG27UQR (4K, 144Hz, G-SYNC compatible) | Asus MG28UQ (4K, 60Hz, FreeSync compatible) |
Case | Cooler Master HAF 922 |
Audio Device(s) | Creative Sound Blaster X-Fi Fatal1ty PCIe |
Power Supply | Corsair AX1600i |
Mouse | Microsoft Intellimouse Pro - Black Shadow |
Keyboard | Yes |
Software | Windows 10 Pro 64-bit |
System Name | money pit.. |
Processor | Intel 9900K 4.8 at 1.152 core voltage minus 0.120 offset |
Motherboard | Asus rog Strix Z370-F Gaming |
Cooling | Dark Rock TF air cooler.. Stock vga air coolers with case side fans to help cooling.. |
Memory | 32 gb corsair vengeance 3200 |
Video Card(s) | Palit Gaming Pro OC 2080TI |
Storage | 150 nvme boot drive partition.. 1T Sandisk sata.. 1T Transend sata.. 1T 970 evo nvme m 2.. |
Display(s) | 27" Asus PG279Q ROG Swift 165Hrz Nvidia G-Sync, IPS.. 2560x1440.. |
Case | Gigabyte mid-tower.. cheap and nothing special.. |
Audio Device(s) | onboard sounds with stereo amp.. |
Power Supply | EVGA 850 watt.. |
Mouse | Logitech G700s |
Keyboard | Logitech K270 |
Software | Win 10 pro.. |
Benchmark Scores | Firestike 29500.. timepsy 14000.. |
System Name | My PC |
Processor | 4670K@4.4GHz |
Motherboard | Gryphon Z87 |
Cooling | CM 212 |
Memory | 2x8GB+2x4GB @2400GHz |
Video Card(s) | XFX Radeon RX 580 GTS Black Edition 1425MHz OC+, 8GB |
Storage | Intel 530 SSD 480GB + Intel 510 SSD 120GB + 2x500GB hdd raid 1 |
Display(s) | HP envy 32 1440p |
Case | CM Mastercase 5 |
Audio Device(s) | Sbz ZXR |
Power Supply | Antec 620W |
Mouse | G502 |
Keyboard | G910 |
Software | Win 10 pro |
In the specs of your charger says 1-6 LiPo cells max and 11-18V 50W max so i guess you can charge batteries but only if they have max 6 cells inside.
Because it is the nominal usable voltage. A lithium cell's discharge curve is very flat - it holds at 3.5-3.7v through about 85% of its cycle. When fully charged and put into use, it drains quickly from 4.2 to 3.8, then holds steady until it hits about 3.5 and then drops quickly again to 3.0.lipo batteries are weird.. fully charged they are mostly 4.2 volts per cell.. they always get quoted as 3.7 volts per cell which is way less than they are when fully charged.. that six cells is really 25.2 volts.. i tend to think of them as 4 volts per cell.. it makes life easier.. why they get quoted at a half flat figure i havnt a clue..
trog
Keyboard | Yes |
Don't forget to add friggin' dangerous with the risk of fire or explosion. That's really all that matters here.You'd have to open the battery case and bypass the BMS to use an external charger. Lot of work for absolutely no gain.
System Name | RED |
Processor | Intel Core i5 2500 |
Motherboard | Gigabyte GA-B75M-HD3 |
Cooling | Cooler Master Hyper 212 Evo |
Memory | 2x8GB 1600MHz DDR3 @1333 [Avexir] |
Video Card(s) | Gigabyte GeForce GTX 1060 3GB Windforce 2X OC |
Storage | 1*Samsung 840 Series SSD 250GB, 2*Seagate Barracuda 1TB HDDs |
Display(s) | LG W1934S |
Case | Aerocool X-Warrior Red Devil Edition |
Audio Device(s) | Realtek ALC887 |
Power Supply | Seasonic M12II Evo 520W (80+ Bronze) |
Mouse | Cooler Master Devastator II Mouse |
Keyboard | Cooler Master Devastator II Keyboard |
Thanks for the explanation. I learned something today!Because it is the nominal usable voltage. A lithium cell's discharge curve is very flat - it holds at 3.5-3.7v through about 85% of its cycle. When fully charged and put into use, it drains quickly from 4.2 to 3.8, then holds steady until it hits about 3.5 and then drops quickly again to 3.0.
Laptop packs use a series (and parallel for high capacity packs) of 18650 Li-Ion cells. Lipo cells are the flat "pouch style" batteries found in tablets, phones, and ultra-thin laptops. Laptops usually have between 6 and 9 pins on the battery connector. 4 of them are the straight charge voltage (paralleled + and -) and the rest are for the battery management system inside the battery. You can't charge the cells directly from that connector because without the control signals the BMS won't allow anything through. You'd have to open the battery case and bypass the BMS to use an external charger. Lot of work for absolutely no gain.
Uh. No. I didn't pull that out of my ass, the reason you've read it before is because that's how they work. Seriously, you think Tesla would use a cell with a linear discharge curve in their EVs? Their battery packs are made up of hundreds of 18650 cells. Lol if you believe that, I have some oceanfront property in Kansas for sale that you'd love.sorry put you are wrong on that one.. i play with RC toys and check voltages enough to know they dont behave as you say they do.. they just go down in a linear fashion.. the quoted voltage is just the halfway point.. i have come across your explanation before though.. but sadly it is total bollocks.. he he..
i do speak from experience and not from what i have read by the way..
trog
