Can mobo power on without CPU
Bashdar09
25 (0.01/day)
Hello so i have sold my 5 2600 cpu and i don't have cpu for atleast 10 days i rebuild my entire pc and powered ON the PC without the cpu it won't even spin a fan for a second or any lights is it normal?
B450 A ROG STRIX GAMING-F
16GB 3000MHZ LPX RAM
RX580 8GB SAPPHIRE PULSE
550 WATT 80+ GOLD PSU
Does anyone have that motherboard ? can you try to run with out a cpu to see what happen ? I will be in ur debt forever im in a stress that i damaged . something. 5 3600 will be my new cpu though❤
911 (0.38/day)
Al Balqa', Jordan
Processor AMD Ryzen 5 2600 (Covered with Cooler Master MasterGel Pro)
Motherboard ASRock B450 Steel Legend, BIOS Version: 10.31 [Beta]
Cooling Cooler Master MasterLiquid ML120L V2 RGB, 5x Galax Vortex Wind-02 (3x Front Intake + 2x Top exhaust)
Memory Kingston FURY Beast RGB 3600 MT/s 32 GB (4x 8GB), (KF436C17BBA/8)
Video Card(s) Palit GeForce GTX 1660 Ti Dual OC
Storage Kingston NV2 1 TB
Display(s) MSI PRO M251 (HDMI), Running @104 Hz
Case Cooler Master MasterBox MB520
Audio Device(s) HP H360G USB
Power Supply Cooler Master MWE 550 80+ White
Mouse HP G200 Black
Keyboard Redragon MITRA K551-1 RGB
Software Windows 11 Home
tabascosauz
8,200 (2.35/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Generally, no. Your board doesn't have BIOS flashback. BIOS flashback would allow you to power on the board to update the BIOS just by having the 24-pin and EPS cables connected and a USB stick with the file in the right port, no CPU or RAM needed.
I sure as hell hope you updated your BIOS to ver. 2406 or later before you sold your 2600, or else you will be met with a black screen with your new 3600. If you didn't, you will have to buy an Athlon / request an Athlon kit from AMD / take it to the store to update the BIOS.
Frick
Fishfaced Nincompoop
19,719 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
It's normal.
Bashdar09
25 (0.01/day)
The real question is why?!
Yes that's pretty much what's gonna happen.
Thanks, I don't trust myself with rebuilding a pc
Yes sir its latest ASUS bios installed by an USB stick ver 3103
It's normal.
Thank you so much that is a relife
911 (0.38/day)
Al Balqa', Jordan
Mouse HP G200 Black
I still don't get your point, you can't test your new build without a CPU, hope you updated your BIOS before you sold your 2600 like @tabascosauz said.
911 (0.38/day)
Al Balqa', Jordan
Mouse HP G200 Black
1,470 (0.21/day)
Processor Ryzen 1600AF @4.2Ghz 1.35v
Motherboard MSI B450M PRO-A-MAX
Cooling Deepcool Gammaxx L120t
Memory 16GB Team Group Dark Pro Sammy-B-die 3400mhz 14.15.14.30-1.4v
Video Card(s) XFX RX 5600 XT THICC II PRO
Storage 240GB Brave eagle SSD/ 2TB Seagate Barracuda
Display(s) Dell SE2719HR
Case MSI Mag Vampiric 011C AMD Ryzen Edition
Power Supply EVGA 600W 80+
My point was can i test other parts without a cpu / i updated it to 3103 before selling my 5 2600
if it worked before and all you did was pull the CPU, assuming you didnt use a chisel or yank it straight out of the socket without unlatching the lever :p then don't worry, pop new CPU in and win :rockout:
Bashdar09
25 (0.01/day)
I am way too careful with cpu but not with wires tbh like that hdd led and power sw ..etc drove me crazy
3,819 (0.75/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
I have to wonder what did you expect it to do boot up?
3,819 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
3,819 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
So, if I have everything except the cpu installed, the fans should start, right?
What are you asking?? If you jump the psu? If you jump the psu it will power on.
Frick
19,719 (2.86/day)
w
If you try to start a motherboard without the CPU nothing will happen. If you jump start a PSU the fan in the PSU and the fans connected to the PSU will start.
Cancerror2701
1 (0.00/day)
I have the same mobo i have connected everything exept for the cpu coz i dont have as of the moment.. so i tried to fire it up nothings happen. I got worried since i saw this now i can relax just waiting for my 2600 and hopefully evrything will be just fine..
