can my system run 8800GT???
6,449 (1.11/day)
Midlands,UK
System Name Ultraman
Case Alienware X16
Hello,i'm new to the forum :) and i'm okay with desktops i surpose but i was wondering if my system specs would work on the Asus 8800GT or others,specially my psu.
I've read the minimum psu requirement is 400w for just single card usage but i want check if my psu got another amps to run the card and play games without any problems.
heres my spec:
Processor:
Intel(R) Core(TM)2 CPU 6320 @ 1.86GHz (2 CPUs), ~1.9GHz(Akasa AK-965 Performance INTEL Heatpipe Cooler installed)
Memory:
4094MB RAM
Hard Drive:
288 GB Total
Video Card:
ATI Radeon HD 3650 Series
Monitor:
LG Flatron L1717S
Sound Card:
Creative Sound Blaster Audigy SE
Speakers/Headphones:
Logitech X-140
Keyboard:
Microsoft Multimedia keyboard
Mouse:
Microsoft Intellimouse 3.0
Mouse Surface:
Allsop 3D mousemat
Operating System:
Windows Vista™ Ultimate X64
Motherboard:
GigaByte-GA-EP45-DS3R
Computer Case:
ATX Case
Also i'm using 1 LED 80mm fans and 2 normal 80mms
and heres a picture of my 400w with the amps:
I appreciate the help thanks :)
{JNT}Raptor
732 (0.10/day)
NY
System Name Ummmm...Mine
Processor I7 920 @ 4.2ghz @ 1.29v's load
Motherboard ASUS P6T Deluxe V2
Cooling Custom 1/2 inch H20
Memory 3x2gb Patriot Sector 7 @2008Mhz 27-9-11-9 1T
Video Card(s) EVGA GTX 580 SC 900/1800/1090
Storage 1-Mushkin 60gb SSD 1-500GB WD Black and 2-1TB 32mb WD Black
Display(s) 25 inch Hanns-G 2ms
Case Custom
Audio Device(s) Turtle Beach Catalina
Power Supply Corsair AX850 Pro Series-Modular
Software All Kinds...and then some.
Benchmark Scores 3dMark 11 P7066 Compare Link- http://3dmark.com/3dm11/251153
I would say not to chance it and get at least a 500watt or above decent brand name PSU.......you don't wanna take chances with your PSU.......it just about plugs Into everything.....so why run the risk.
Hope it helps. :)
415 (0.07/day)
Pakistan
System Name Mean Machine
Processor Intel Core i5 2400 at 3.1 GHz
Motherboard Asus can't remember the model
Cooling Cooler Master Hyper 103
Memory Kingston 4GB 1600 DDR3
Video Card(s) Gigabyte 6850 1 GB
Storage WD Cavier SEII 3200AAKS 320 GB and Seagate 500 GB
Display(s) HP X22 LED
Case Generic
Audio Device(s) Creative Sound Blaster Audigy
Power Supply Cooler Master Real Power Pro 650W
Software Pro/E, Delcam Powermill, These things just for work.
I would consider 17A on 12V rail is not enough.
6,449 (1.11/day)
Midlands,UK
Case Alienware X16
1,777 (0.29/day)
South Australia
System Name QUACK
Processor Intel i7 2600K (3.4 GHz, 8 threads)
Motherboard Asus P67P8-V3
Cooling Xigmatek Balder 120mm (4x120,1x140mm case)
Memory Patriot 2 Viper Sector 5, 8GB DDR3 1600 MHz
Video Card(s) Gigabyte GeForce GTX 960 G1 4GB
Storage 1x Samsung EVO 850 (500GB) SSD, 1x Fujitsu 256GB SSD
Display(s) Dell Ultrasharp U2311h 23" (so sexy)
Case CoolerMaster Gladiator RC-600
Audio Device(s) Onboard 5.1
Power Supply Antec 850w with yellow racing stripes
Software Windows 7 HP 64 bit
You might want to consider overclocking your CPU a bit more, as it might bottleneck an 8800 GT.
Other than that, a new PSU would definately help, considering my PSU isn't all that good and it barely runs a 9600 GT.
{JNT}Raptor
732 (0.10/day)
NY
Case Custom
I'd say either the Antec or the OCZ would do the job....both have 36 combined amps on the +12 line so your covered there......of the 2 I'd get the OCZ because of the 3yr warranty compared to the Antec's 2yr warranty.
Hope it helps. :)
JrRacinFan
Served 5k and counting ...
20,124 (3.08/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
Bump it up to the next notch.....
http://www.ebuyer.com/product/127861
That way you won't have to upgrade your power supply again if you go further beyond the 8800GT (GTX260/HD4870 or greater in single card).
EDIT:
Also, The Antec Neopower modular is a good deal too. But you would have to upgrade power supply again for the reasons pointed out in my post.
http://www.ebuyer.com/product/99136
r9
3,300 (0.55/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
It would be strain on the PSU but it will run I had 9800GT with 14Amp
6,449 (1.11/day)
Midlands,UK
Case Alienware X16
Hope it helps. :)
Hm i see thanks for the info :) i'll buy the OCZ psu when i get money. @Error 404 i am considering overclocking my cpu when i buy the new psu =) but i dunno how to do it xD i have tried before but it kinda screwed up and nothing displayed,maybe because i did something wrong
CDdude55
Crazy 4 TPU!!!
8,178 (1.27/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
Should get a more reliable PSU, but 400W should be enough overall.
And OCZ is awesome.:)
5,457 (0.88/day)
Australia
Nope ya 12v Rail Amps isnt enough, you must have at least 26Amp 12v rail for it to run with out blowing the PSU up, and at least a 450W PSU. Trust me i found this out the hard way with a m8s comp.
Get this PSU it will do what you want and has 7yrs warranty ;)
http://www.corsair.com/products/hx450/default.aspx
I have ordered one for my backup/GF rig for using Sli 7600GT's
p_o_s_pc
F@H&WCG addict
13,006 (2.00/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
Hope it helps. :)
+1 i agree :toast: the Antec and OCZ would be best i had a cheap(er) 500w PSU running a 8800GT and an X2 5kBE@3ghz and it shit its self in a month. i wouldn't use any cheap PSU
