Can not find working VBIOS for my GPU
muky
3 (0.00/day)
Hello everyone! I recently purchased a used XFX RS RX 570 Black Edition 8 GB graphics card with the following details: Part Number 113-57085STB3-W90, Subsystem ID 1682 C570, and Device ID 1002 67DF. However, when I initially attempted to boot the card, it didn't work. To troubleshoot the issue, I switched to the secondary quiet (switch position 2) VBIOS, and the card powered up without any problems.
Next, I decided to switch back to the primary (performance) BIOS and used the amdvbflash tool to save it. Upon inspection, I discovered that the BIOS was from 2019 and seemed to be a mining BIOS, as the memory clocks were significantly higher than the standard specifications for any XFX RX 570. Nonetheless, I tried using the original VBIOS from TechPowerup, but encountered Code 43 in the task manager when attempting to boot up.
Suspecting a potential issue with the VBIOS chip, I decided to flash the quiet (switch position 2) VBIOS that I had previously saved. Surprisingly, the card booted up successfully with this BIOS. Despite having two similar VBIOS options for my card, I tried both of them, but they both resulted in Code 43 errors. Fortunately, I can identify the correct VBIOS for my card based on the Part Number.
Currently, I am using the quiet BIOS (bios switch position 2) as it works fine without any error codes in the device manager. However, I noticed that the stock fan curve appears to be modified, and I cannot set the fans to less than 75% using either AMD Adrenalin software or MSI Afterburner.
If anyone could offer assistance or suggestions regarding this issue, I would greatly appreciate it. Also if necessary, I can upload both the quiet BIOS and the potential mining BIOS that I saved from the graphics card for someone with more expertise to examine and provide assistance.
GPU sticker, If necessary
GPU sticker, If necessary View attachment 300525
Pull the heatsink and get a close up of a ram chip and the metal plate with numbers surrounding the gpu die please
I sincerely appreciate your efforts to assist me. However, I'm happy to inform you that I have managed to find a solution on a different forum. Interestingly, this particular GPU required a unique vBIOS that was found buried deep in TechPowerUp's vBIOS collection.
Gpu-z screenshot then because I have written the flash guides for ATi/AMD cards
And tbh its not unique at all
