Can not get speakers to work after moving my pc
42 (0.01/day)
texas
System Name *havent named it*
Processor Intel i5 4670k @ 4.4 GHz
Motherboard Gigabyte Z87X-UD4H
Cooling Corsair H100i on CPU exhaust: one 120 rear fan intake: two 120 fans on front, one 120 fan on bottom
Memory 8GB Gskill 2133 RAM 2 sticks
Video Card(s) AMD R9 290 reference
Storage ADATA Premier Pro SP900 256 gb ssd and Crucial MX100 512gb ssd
Display(s) Viewsonic VA2446m 24" LCD
Case CM Storm Scout 2 Advanced Gaming mid tower
Audio Device(s) none
Power Supply FirePower 750W fatl1ty 80Plus Bronze semi-modular
Software win7 OS
I'm a little confused on this. Literally all I did was move into a new home. I hooked up my system and plugged everything in and the only thing that is not working are my speakers. I thought maybe my altec lansing speakers I had for about 16 years finally went out so I bought a logitec system and still same problem. I can't even find it in my devices on control panel or in my realtek audio manager. Any ideas? I have been told it may be my windows 10 that screwed with it but I don't think so. I had it before I moved and everything was working just fine. Any help would be much appreciated. Thank you.
FreedomEclipse
~Technological Technocrat~
24,436 (3.76/day)
Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
First up make sure you can see your soundcard in device manager.
Second: Make sure its plugged in to the correct port.
Thrid: reinstall your device drivers
1,456 (0.32/day)
Israel
Processor AMD Ryzen 7 5800X
Motherboard B550 Aorus PRO V2
Cooling Corsair H115i RGB Platinum
Memory Gskill Trident Z Neo 3600 2x16GB
Video Card(s) MSI RTX 3070 Trio X
Storage WD Blue SN550 1TB NVME/Teranova 1TB Sata/WD Blue SN580 2TB NVME
Display(s) Dell AW3423DWF
Case Corsair 4000D Airflow
Audio Device(s) Schiit Audio Modi+\Magni+
Power Supply Corsair HX850i
Keyboard SteelSeries Apex Pro
Disable and re-enable your sound card in device manager.
42 (0.01/day)
texas
Software win7 OS
I'm not using a sound card using on board sound. My motherboard is a gigabyte GA-Z87X UD4H. has realtek chipset ALC898 channel 7.1
FreedomEclipse
24,436 (3.76/day)
Hong Kong
Its still classed as and called a soundcard, though an integrated one
1,456 (0.32/day)
Israel
Should be under the : sound,video and game controllers tab in the device manager.
9,916 (1.82/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
have you checked plug in that to like mp3 player? and check
13,791 (1.85/day)
Next time, before you go buying new set of speakers, plug them to a phone or MP3 player and see if they make any noise. It's the easiest way to exclude speakers from the list iof "problems".
Check the port if it's correct one as well as check the primary audio device if it's set as default playback. Things tend to go weird lately because monitors tend to be detected as audio device due to DisplayPort/HDMI cables and countless audio passthroughs available on graphic cards.
TheMailMan78
Big Member
22,599 (3.50/day)
'Merica. The Great SOUTH!
Are the speakers turned on? Do you have them in the correct port?
14 (0.00/day)
System Name Mighty Milo
Processor i5-6600K
Motherboard GIGABYTE G1 Gaming GA-Z170N-Gaming 5
Cooling SilverStone AR06
Memory Crucial Ballistix Sport 16gb 2x8GB DDR4-2400
Video Card(s) ROG STRIX-GTX1070-O8G-GAMING
Storage 480GB SanDisk Extreme PRO SSD
Display(s) Acer XB270H
Case SilverStone ML08B-H
Power Supply CORSAIR SF600
Mouse Etekcity Scroll X1 (M555)
Keyboard Logitech G710+ (Brown Switches)
If you're using front panel jacks for your speaker, be sure that the move didn't cause the connector for those jacks to work loose. Also, make sure that nothing is plugged into a jack that gets higher priority (e.g.: stand mic plugged into headphone jack instead of mic jack. This will make lots of things not work all at once).
