Potaziolocooo
- Jan 10, 2025
- 4 (0.25/day)
I have seen that you have helped many people in the forum of this site about the Chinese rx570 580, I recently bought an 8GB rx580, as I understand it, it is an rx 580 2048p, which only has the DVI output enabled, the HDMI and DP outputs do not work As I understand it, they are disabled. It was used for mining and when I installed drivers and checked the GPU Z, it showed that it was a rx 570, the only way to use it was by installing the ATI PARCHER patch, the graphics card is recognized by my PC as an rx570, but in itself it doesn't perform almost anything at all, in gaming it works more or less well with a low fps rate more or less stable, but when you demand a little from the graphics it doesn't perform what it should
I changed the bios for a rx580 2048sp that I found, I checked the type of memory and the graphics worked, the HDMI output was even activated although it did not go over 60hz, but at times it gave me a green screen that froze the windows then I changed it for another I had an rx570 and that one worked but when playing I got green flashes on the screen in some areas of the game. I would really appreciate if you can help me or advise me. I will send everything you ask for and I will even leave you some photos that I managed to take, if you need more, please let me know and excuse my English, I am using Google Translator to be able to communicate
