Can unplugging the PC repeatedly from the wall harm it?
149 (0.40/day)
Motherboard ASUS Prime X670E-Pro WIFI
Cooling Noctua NH-D15S
Memory Kingston FURY Beast 2x16GB 6000MHz CL36
Video Card(s) Gainward RTX 2070 Super
Storage Samsung 990 Pro 2TB, Samsung 990 Pro 4TB, Samsung 970 EVO Plus 2TB, Lexar NM790 4TB
Case Fractal Design Meshify 2
Power Supply Corsair HX1000i ATX 3.1
So, one of my relatives likes to unplug all his stuff from the wall when he's not using it.
He shuts the PC down and then unplugs the PC, monitor and TV from the wall, sometimes up to six times/day. Like when he takes a 10 minute break, he wont leave it running, he shuts it down, unplugs from the wall and 10 minute later plug it back again and turn it on.
One day after having used the PC once that day, it refused to post(videocard died), monitor was making weird buzzing noise and TV was completely dead.
I replaced his monitor and videocard earlier this year, there where no issues, but now the PC wont post again. Most likely motherboard died this time. PSU is EVGA G3.
21,148 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
I don't honestly see how that would harm anything at all.
Ruru
S.T.A.R.S.
11,977 (2.80/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Cooling Arctic Freezer 50
Memory 48GB Kingston DDR4-3200C16
Storage ~3TB SSDs + 3TB external HDDs
Audio Device(s) Asus TUF H3 Wireless
VR HMD Oculus Rift CV1
The plug/wall socket is the only one which will have some wear caused by that continuous plugging and unplugging.
I unplug my PC only when there's a really bad thunderstorm going on.
531 (0.28/day)
Hungary
System Name Detox sleeper
Processor Intel i9-7980XE@4,5Ghz
Motherboard Asrock x299 Taichi XE (custom bios with ecc reg support, old microcode)
Cooling Custom water: Alphacool XT45 1080 + 9xArctic P12, EK-D5 pump combo, EK Velocity D-RGB block
Memory 8x16Gb Hynix DJR ECC REG 3200@4000
Video Card(s) Nvidia RTX 3080 FE 10Gb undervolted
Storage Samsung PM9A1 1Tb + PM981 512Gb + Kingston HyperX 480Gb + Samsung Evo 860 500Gb
Display(s) HP ZR30W (30" 2560x1600 10 bit)
Case Chieftec 1E0-500A-CT04 + AMD Sempron sticker
Mouse Logitech G400
Keyboard IBM Model M122 (boltmod, micro pro usbc)
Software Windows 11 Pro x64
Cheap PSU-s can die that way.
It is recommened to use the psu switch first.
296 (2.96/day)
System Name Kuro
Processor AMD Ryzen 7 7800X3D@65W
Motherboard MSI MAG B650 Tomahawk WiFi
Memory Corsair DDR5 6000C30 2x48GB (Hynix M)@6000 30-36-36-48 1.36V
Video Card(s) PNY XLR8 RTX 4070 Ti SUPER 16G@200W
Storage Crucial T500 2TB + WD Blue 8TB
Case Lian Li LANCOOL 216
Audio Device(s) Sound Blaster AE-7
Power Supply MSI MPG A850G
Software Ubuntu 24.04 LTS + Windows 10 Home Build 19045
Benchmark Scores 17761 C23 Multi@65W
Is there an audio setup with a subwoofer? I've had multiple SBCs die and a NUC go flaky, probably after the power-saver strip disconnected everything else but them, and presumably discharged some stray voltage through the HDMI cable to the only ground that still remained connected, one too many times.
ir_cow
4,160 (0.71/day)
USA
I was going to say the same thing. But there is no bases to this myth. Cheap PSU tend to die because of the components inside, not because of lack of power.
21,814 (6.00/day)
Mouse XTRFY M42
He shuts the PC down and then unplugs the PC, monitor and TV from the wall, sometimes up to six times/day. Like if takes a 10 minute break, he wont leave it running, he shuts it down, unplugs from the wall and 10 minute later plug it back again and turn it on.
Just tell him yes, so he can stop this idiocy.
I'm quite sure the process isn't always followed rigorously and stuff gets unplugged while being still on. If you do this 4+ times per day, its a chore and mistakes are made. Zero doubts.
149 (0.40/day)
There is, connected with a 3.5mm to rca cable from the PC.
The psu switch is half dead, when you want to turn it off there's a psychical resistance and it will jump back to the on position.
las
1,568 (0.36/day)
System Name Meh
Case Fractal Design North XL
Audio Device(s) FiiO DAC
This should not be a problem. Loss of power should not be able to cause issues.
2,226 (1.06/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
one might over time wear brass in the plug and socket but other wise no.
1,342 (0.86/day)
There is quite a power surge when re-plugging the PC to the outlet I would imagine or maybe with newer PSU's with resonant desing there is not.
Let them turn it off (shutdown) but tell 'em to not unplug the equipment - it's not grounded when unplugged...
5,898 (2.93/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Sounds like some serious issues with electricity in the apartment.
68 (0.11/day)
System Name Hopes, dreams, donated parts, and electrical tape
Processor Ryzen R5 3600
Motherboard Asrock B450m Pro4
Cooling Stock Cooler
Memory Corsair Vengeance LPX 32gb 3200 CL16
Video Card(s) PowerColor Fighter 6500XT (Running at pcie 2.0...)
Storage Western Digital 2TB Black HDD, Samsung 870 Evo 512GB
Display(s) Asus VA something or other
Case Cougar MX331 MESH-X
Power Supply Corsair CX550m
Mouse Rosewill ION D10
Keyboard Corsair K70 (The old one)
VR HMD $4 Garage Sale Phone Holder and AprilTags
So honestly, the only thing to worry about are inrush currents and the lifespan of the socket itself in regards to what could possibly go wrong with so many cycles of plugging and unplugging the PC. Regardless, unless you have a PSU with TERRIBLE inrush currents, you'll be fine, albeit you may wanna check out a commercial grade replacement for the outlet just for longevity's sake.
...Though, with that said, a part of me gets a bit of worrying vibes from this post because I'm worried the reason for the constant unplugging might be related to some old misinformation that used to be spread around the web that could very well be true in this specific case. It used to be said that keeping things plugged in resulted in excess power being wasted and, as a result, there was a time where I specifically remember being instructed to always unplug things. I'm sure it comes from a time when there may have been bad electrical circuitry in many households or the danger of a power surge, but the fact that you had a monitor, TV, and GPU all die or get damaged makes me worried about the state of the electrics in the house overall.
Did he ever explain why he's chronically unplugging? Was there once a power surge or lightning strike that killed some devices in the house? Or is this something related to security in regards to his PC being possibly accessed without his knowledge because it's plugged in? I just have a weird hunch that there's more to this and that there may be something more dangerous going on where unplugging may have been the best/safest solution for him while not realizing there's something bigger going on with the house. I know it's off-topic from the original question in the thread and feel free to ignore this, but honestly I've had worse happen to friends who had zero idea that something was wrong and had "fixes" like this that they thought was normal. Most dangerously, I once had a friend not realize they were running an ungrounded house for over a decade (!!!) and thought that the "buzzing" they felt when they touched metal was a skin condition.
149 (0.40/day)
Well it's only his PC that has issues, the other electrical stuff works fine, nothing died. The PC that she uses in the same apartment is always plugged in and she didnt face any problems..
He wants to save energy. Nothing died in that apartment aside from the stuff gpu/tv/monitor mentioned. Tv and monitor was connected to the Pc, so I thought maybe some inrush current got discharged through the gpu to the tv/monitor on the hdmi cables. But who knows.
418 (1.73/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
Switchable power outlet when?
61 (0.06/day)
I've seen this fault on a friend's ATX PSU which he asked me to fix. He switches off his computer religiously at the back of the PSU after use. When his PSU's switch was actuated, fizzing sounds and bright flashes were emitted. Closer examination of the switch internals showed burnt and pitted metal contacts, plus a partially melted distorted housing.
The ATX PSU reviews on Tom's Hardware show the inrush currents at 115V and 230V AC. This current spike occurs each time you switch on an ATX PSU and the bulk capacitor charges up. Typical ATX PSU inrush currents from the AC mains lie in the range 40A to 100A, resulting in a brief internal arc each time the switch contacts close. These repetitive arcs lead to slow deterioration of the switch contacts and eventually the switch can fail open or short circuit.
The link below shows a switch-on surge of 78.580A at 115V AC and 93.990A at 230V AC on an Asus TUF Gaming 550W PSU.
https://www.tomshardware.com/reviews/asus-tuf-gaming-550w-bronze-power-supply-review/2
The mains on/off switch is a critical component in a PSU (as an electronics design engineer, this is one of the components I choose carefully). If the switch cannot be physically turned off, you should not continue to use the PSU. In the event that arcing continues after the initial surge (due to high contact resistance), the switch could overheat and become a fire hazard.
Dangerous voltages exist inside an ATX PSU during operation and immediately after switch off until the bulk capacitor discharges. If you don't have a clue about high voltage electronics, don't open up the PSU and mess about inside. You'll probably survive if you get a shock, but it's not worth the risk. In any case, the mains on/off switch can be difficult to replace and the safest option is simply to replace the whole PSU.
This is what I recommended to my friend, but unfortunately he chose another cheap ($35) PSU, so the problem is likely to return in a few years.
Note: If you do leave your computer connected to the AC mains permanently, it will continue to draw "Vampire" power unless switched off completely. Modern high quality ATX PSUs may draw less than 0.5W, but I have numerous old computers that draw between 3W and 8W, as measured on a "Kill-a-Watt" power meter.
21,814 (6.00/day)
Mouse XTRFY M42
You don't save energy unplugging stuff, if anything you're going to have a larger energy footprint because you're increasing wear on components = faster replacement. Imagine the power used in the making of one component. You won't save that in your life by avoiding 'standby' devices for 80 years.
Let him buy one of these and kindly tell him to apply some common sense.
Yeah its amazing how people who think this long about saving power don't figure out simple solutions. Maybe they think applying logic takes too much energy.
2,891 (1.56/day)
System Name Not a thread ripper but pretty good.
Processor Ryzen 9 5950x
Motherboard ASRock X570 Taichi (revision 1.06, BIOS/UEFI version P5.50)
Cooling EK-Quantum Velocity2, EK-Quantum Reflection PC-O11, D5 PWM, EK-CoolStream PE 360, XSPC TX360
Memory Micron DDR4-3200 ECC Unbuffered Memory (4 sticks, 128GB, 18ASF4G72AZ-3G2F1) + JONSBO NF-1
Storage Samsung 2TB & 4TB 980 PRO, 2TB 970 EVO Plus, 2 x Optane 905p 1.5TB (striped), AMD Radeon RAMDisk
Power Supply Corsair RM750x
Mouse Logitech M575
Benchmark Scores Typical for non-overclocked CPU.
Or just buy the relative a switched power adaptor that includes on/off LED switch light and and say here this is easier, just use this on off switch.
