Can you flash a cpu?
443 (0.16/day)
Processor i7 4790k / ryzen 1700
Motherboard Asus Maximus VI Extreme / gigabyte b350 mini itx
Cooling Corsair H70 / cooler master master liquid
Memory 32gb DDR3 / 32gb ddr4
Video Card(s) Gtx 1080 / gtx 1080
Storage 128gb Samsung 850 Pro, 2tb hdd / 500gb 850 evo
Case Thermaltake Chaser Mk-1 / Silverstone m13b
Power Supply 1000W OCZ Gold Full Modular / seasonic focus 850w
Mouse Proteus Core G502
Keyboard Corsair K95 RGB
The long story short is I started having a conversation with a friend, neither of us knowing anything about bios flashing, and I am wondering, "Is it possible to flash a ryzen 1900x to a 1950x if it has all of the parts of the processor and they're just disabled?" I'm assuming that the 1900x is like a 1950x just with half the cores disabled, is this correct?
Athlon2K15
HyperVtX™
7,909 (1.18/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
In the past some have had luck unlocking amd cpus
5,717 (0.92/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
Eons ago there were people who enabled their 3 core Phenom to 4 core Phenom via BIOS modding. It used to be possible.
As for now, those 1900X probably have parts disabled physically so not very likely.
443 (0.16/day)
So an r9 290 being flashed to a 290x does not have those shaders disabled physically? Also how would you tell if it's been disabled physically vs software?
443 (0.16/day)
Anyone know if someone is working on an attempt at flashing these? If so does that mean one could potentially flash a ryzen 1600 into a 1700?
236 (0.06/day)
System Name Coffee Lake S
Processor i9-9900K
Motherboard MSI MEG Z390 ACE
Cooling Corsair H115i Platinum RGB
Memory Corsair Dominator Platinum RGB 32GB (2x16GB) DDR4 3466 C16
Video Card(s) EVGA RTX 2080 Ti XC2 Ultra
Storage Samsung 970 Pro M.2 512GB - Samsung 860 EVO 1TB SSD - WD Black 2TB HDD
Display(s) Dell P2715Q 27" 3840x2160 IPS @ 60Hz
Case Fractal Design Define R6
Power Supply Seasonic 860 watt Platinum
Mouse SteelSeries Rival 600
Keyboard Corsair K70 RGB MK.2
I'm betting the days of unlocking cores are long gone. Unless you've got money to burn I would leave it as is.
443 (0.16/day)
I guess they laser the cores off in production so that would mean you couldn't do that.
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Thats not to say in the future someone might figure it out, or they might release the unlock after a long time.
9,781 (2.17/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
I'd rather they do this , then processor manufacturers handling it like call of duty or the battlefield and charging for "DLC/expansions" every few months. Imagine that, "make sure to order you extra cores, or cache" :laugh:
DLC
Downloadable Cores
826 (0.12/day)
Eons ago... Phenoms... Options built into firmwares... BIOS flash... Noobs.
Maybe you could edit the microcode so the bios only had reference settings for the high end chip?
Please enjoy the image of this Barton that has been pencil modded then overclocked using jumpers on the mainboard before enthusiast was a market segment. I dont even think the modder had paid for his CPU insurance.
P.S, not even mad
AsRock
TPU addict
19,191 (2.97/day)
UK\USA
Cooling D15
Typo maybe ?, my Phenom x2 unlocks to a x4 and boards were all so released to do so, so modding was not needed in some cases.
43,799 (6.79/day)
No you can't flash a cpu, only the EEPROM on a motherboard or gpu.
You can attempt to unlock a cpu via bios or hardware mod.
On the CU part of a 290, some do unlock fully without any instability (rarest), some you unlock and they are just unstable (more common but not most common, most you can't unlock the CU (most common)
Same goes for the 390 lineup.
Bear in mind though that some 290s and 290xs have the same exact clock rate, so you might aswell use AB to push them as long as the cooling is good.
924 (0.18/day)
System Name future xeon II
Processor DUAL SOCKET xeon e5 2686 v3 , 36c/72t, hacked all cores @3.5ghz, TDP limit hacked
Motherboard asrock rack ep2c612 ws
Cooling case fans,liquid corsair h100iv2 x2
Memory 96 gb ddr4 2133mhz gskill+corsair
Video Card(s) 2x 1080 sc acx3 SLI, @STOCK
Storage Hp ex950 2tb nvme+ adata xpg sx8200 pro 1tb nvme+ sata ssd's+ spinners
Display(s) philips 40" bdm4065uc 4k @60
Case silverstone temjin tj07-b
Audio Device(s) sb Z
Power Supply corsair hx1200i
Mouse corsair m95 16 buttons
Keyboard microsoft internet keyboard pro
Software windows 10 x64 1903 ,enterprise
Benchmark Scores fire strike ultra- 10k time spy- 15k cpu z- 400/15000
I am literally modding a e5 xeon v3 into a much higher performing part equivalent to 22 cores e5 v4 instead of this e5 v3 18 core, via removing microcode from bios, then injecting a boot driver that uses an old bug to boost all cores to max turbo, hence xeon e5 2686 v3(cinebench 2000 pts) into a xeon e5 2699 v4(cinebench 2600 pts).
stable as a rock if cooled properly :)
mind you I am on 100% stock in bios, default frequencies and bclk!!, no overclocking whatsoever, ram default etc. Just loving it, and it saves power fine in c states and whatever.
Guess what? it is going to get a twin brother for dual monster soon
11,880 (2.17/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
are you enabling more cores ,higher frequencies or both?
924 (0.18/day)
just forcing turbo on all active cores to 3.5ghz, instead of the default 2-3 natively and instead all cores simultaneously @2.3ghz at factory- they are now around 3ghz - 3.5ghz. The normal default clock speed non-turbo is still 2.0ghz for all 18 cores.
hint: "what controls turbo boost in xeons"- a very very long thread
19,378 (3.50/day)
We're talking about unlocking cores... this is just overclocking in a more complicated manner.
6,871 (1.11/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
nevermind, I'm mistaken
924 (0.18/day)
Could be just a complicated overclocking manner, mind you on a completely locked down hard chip, a server part that has a gazillion restrictions out of the box
Never ever before could these mega core parts be tweaked outside of a little base frequency increase, and the $$ value is enormous, these are segmented price wise and in practice a meager QS stepping part(=ES same as OEM exactly)
1,901 (0.32/day)
Processor 5930K
Cooling WATER
Mouse DEATH ADDER
Software W10HB
Please feel free to expunge
924 (0.18/day)
judging from your other posts, I assume you misspelled "explain"??
It's up to the user if he wants to risk a no post situation by modding bios, all the info is in that thread, there's more than meets the eye
19,378 (3.50/day)
Anyway, cool stuff er557.. well done. But, its not adding cores. Its simply overclocking (albeit more complicated). :)
924 (0.18/day)
Sure i'm adding cores..... I just ordered a 2nd 18c proc......:)
924 (0.18/day)
How about this- modding an hdd into an ssd via ram and ssd read and write caching- primo cache application, this is a standard 5tb hdd here:
