can you help me x1950 crossfire
metinkiruc
6 (0.18/day)
Hello
A licensed software that I use on my system crashes when I install a new driver. Which new card can I use instead of this x1950 crossfire? Which new GPUs or newer models use the same driver or which card can I use with Catalist 6.11? Because I can't change the driver and Catalist 6.11. My license is incompatible.
597 (1.09/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
597 (1.09/day)
That shows you which cards are supported by 6.11 I would look at getting an alternative software for your needs rather than using such old GPU and drivers
1,367 (0.84/day)
Must it be ATi or can it also be nvidia (faster cards with lower power consumption for XP)? Test a GTX 960 or a 660 first.
metinkiruc
6 (0.18/day)
I cant install driver. because LPT1 use dongle protect. i can use only catalyst 6.11
748 (0.11/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
Hello
vees i use catalyst 6.11. if i change or update syytem halted. i cant change driver and catalyst
You either need to provide very detailed information about your system and the situation with the software key, or just take the PC to a shop.
1,348 (3.80/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Motherboard must support crossfire.
597 (1.09/day)
what do you want information
System specs, OS, the software you can only run with a certain ATi Catalyst driver package :ohwell: maybe it notices a system change and you can contact the vendor to reactivate it?
41,887 (6.61/day)
metinkiruc
6 (0.18/day)
This is responsible for an airbus and the construction company is closed. I can't change the motherboard and GPU. I need a new GPU because my GPU is failing and I can't use the system. I tried installing the new GPU system, which was discontinued. I turned the backup back on.
Can you send me the bios of this crossfire and the normal one? There are many bios, I installed them on one card and it doesn't open. I think it's the wrong version.
Display adapters It always comes like this. And when I install different gpu and driver, windows gives a blue screen and when I restart it, there are yellow exclamation marks on these screen cards. My problem is that there are too many pixels in the display of my graphics card and the colors are mixed. There are ridiculous numbers and letters in different places of the screen.
41,887 (6.61/day)
Remove the heatsink and get a ram chip picture please
ir_cow
4,386 (0.74/day)
USA
If you can find that xfire DVI connector, its sells for hundreds now.
41,887 (6.61/day)
He buggered the card by incorrect flashing, now need to unfuck the card
