Can you split pcie lanes for one device (for example pcie 2.0 x1 to pcie 1.0 x2)
13 (0.14/day)
System Name Office case + Dremel = gaming
Processor Ryzen 5 5600x
Motherboard Asus Prime b450m-A II
Cooling Thermalright Assassin X 120 SE
Memory Corsair Vengeance 2x8+2x16=48GB 3600 Mtps
Video Card(s) Msi Aero OC Gtx 1080ti
Storage crucial nvme ssd 1 tb pcie 3.0
Display(s) Minifire 180hz Full HD IPS
Case Asus Aspire m3201
Audio Device(s) xbox wireless headset (over usb)
Power Supply MSI MAG A650BN 650w non-modular
Mouse TMKB M1SE (Pink)
Keyboard TMKB T98SE (Brown tactile switches)
VR HMD Oculus quest 2
Software windows11
Benchmark Scores P106-90 6GB in Steel Nomad: 550 (Vega 8 for display out)
I don’t have high hopes for this, but I’ll ask anyways, mostly out of curiosity.
Is it possible to use a pcie 2.0 x1 slot on a motherboard and use an active adapter to split the lanes. Resulting in double the lanes at half the speed or one pcie generation older. My thought process is that the chipset and gpu mining splitters do something similar. The difference is they share a set amount of lanes between multiple devices and I’m wondering if I can split lanes for one device.
In case you’re wondering why: I have a pcie 1.1 x4 card and want to use it in a pcie 2.0 x1 slot. So converting the pcie 2.0 x1 slot into a pcie 1.0 x2 slot would be beneficial.
Thank you for your input :3
Ruru
S.T.A.R.S.
13,188 (2.98/day)
Jyväskylä, Finland
Audio Device(s) Sony WH-CN720N / TV speakers
VR HMD Oculus Rift CV1
I don't see any idea in your example since aren't 1.0 x2 and 2.0 x1 the same what it comes to bandwith? Or do I just need more coffee to understand what you're meaning :confused:
5,864 (0.81/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
Not without a dedicated chip specifically designed to split and combine lanes, and those are dead in the consumer space. PLX Technology were the guys doing this about a decade ago but then they got bought by Broadcom, reoriented to server, their products became stupidly expensive, and that was that for consumers.
Nowadays server hardware offers so many PCIe lanes that there's almost no need for such chips, thus they are extremely niche and therefore expensive. Take the EPYC SIENA that has 96 PCIe 5.0 lanes, of which 32 can be dedicated to SATA3 ports - even though SATA3 bandwidth is only 15% of a PCIe 5.0 lane's, it's fine to waste that unused bandwidth because doing so is cheaper than using a chip like the type that I mentioned.
1,421 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
I would say transpanda is looking for a PCI riser card like crypto miners use to plug x16 cards in to x1 slots. If any of those cards has its own PCIe chip on it to do what is wanted not sure if there are any.
Ruru
S.T.A.R.S.
13,188 (2.98/day)
Jyväskylä, Finland
2,658 (6.31/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
@Ruru
I seem to remember that the PLX chips on, say, 690 or 7990 weren’t affecting the PCI-e bandwidth or lanes at all and were just for the two GPU chips to be able to communicate with each other. I might be wrong on that, but I don’t THINK I am?
Ruru
S.T.A.R.S.
13,188 (2.98/day)
Jyväskylä, Finland
@Ruru
IIRC they split the incoming x16 to two x8 for the two GPUs. I may be wrong and I don't know THAT much about those things. :D
2,658 (6.31/day)
@Ruru
Don’t think it was a split exactly. Currently looking at the GTX 690 and the PEX 8747 provided 48 lanes of Gen 3 - 16 to each GPU and the remaining 16 to the slot. Stupidly complex thing.
5,864 (0.81/day)
Ikenai borderline!
Ruru
S.T.A.R.S.
13,188 (2.98/day)
Jyväskylä, Finland
@Ruru
Interesting. I guess that all the consumer dual GPU cards had a similar solution.
2,658 (6.31/day)
Ruru
S.T.A.R.S.
13,188 (2.98/day)
Jyväskylä, Finland
NV actually had their own NF200 before moving to Gen 3 and switching to PLX chips IIRC.
That was also implemented on some motherboards, like nF680/780 didn't generate heat enough... :laugh:
13 (0.14/day)
Software windows11
I’ll use another example to explain what I mean: Let’s say you have a gpu that has 16 lanes of pcie 3.0, but your motherboard and cpu combo only supports 8 lanes, which however are pcie 4.0. The theoretical speed is the same, but the old card doesn’t support pcie 4.0, so its limited to half the speed (pcie 3.0 x8). If you could split the 8 pcie 4.0 lanes into 16 (1x4.0 lane to 2x3.0 lanes), you’d have 16 lanes of pcie 3.0, allowing the gpu to use the full bandwidt.
I’m trying to do that but with a pcie 2.0 x1 slot splitting it into pcie1.0 x2
Hope this is easier to understand.
13 (0.14/day)
Software windows11
In a way, I’m not totally sure what kind of pcie chip you’re referring to, so we might be thinking of the same thing. But that formfactor would probably work best. Most mining risers support pcie 3.0 x1. If the mentioned pcie chip could split that into pcie 2.0 x2 / pcie 1.0 x4, then yes. that would work for what I’m trying to achieve.
18,013 (2.44/day)
Actually, you'd be mistaken there, as ASMedia has a range of PCIe bridge chips these days, but so far, they're limited to PCIe 3.0 as their fasted product offering.
They also don't have one suitable for going from 1x x16 to 2x x16, which is what I guess is what PLX was widely known for. These are more used in products that need a few more PCIe lanes.
Microchip also has a range of them, but as you say, not for consumer applications, as they're expensive.
5,864 (0.81/day)
Ikenai borderline!
Thanks, I honestly wasn't aware ASM made such chips; a PCIe 4.0 (not even 5.0) version of their 2824 (x8 to x24) would make a killing in the consumer market, if priced right. Imagine X570 with one of those chips in PCIe 4.0, would satisfy all my needs :(
Ruru
S.T.A.R.S.
13,188 (2.98/day)
Jyväskylä, Finland
Ah, like on my case, where my CPU supports PCIe 4.0 but I have only a PCIe 3.0 board?
3,719 (2.51/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
Here's a card with a Pericom PI7C9X bridge chip, working at PCIe 2.0 speeds, and it seems to be just what the OP needs:
(search for "pcie switch card" or "pcie bridge card" on Aliexpress or Ebay, there might be other options at an acceptable price)
5,864 (0.81/day)
Ikenai borderline!
That's muxing/demuxing a single 2.0 x1 link to qud 2.0 x1 links i.e. losing bandwidth, OP wants to get a 1.1 x2 link from a 2.0 x1 link i.e. retaining bandwidth - not the same at all.
18,013 (2.44/day)
I didn't expect you to be either, as it's not as if it's something that has been widely covered by media in general and almost no desktop motherboards appears to be using them. I think I've seen one that used a basic 1 to 3 switch or something along those lines.
Frick
Fishfaced Nincompoop
19,756 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
I don't think they would make a killing, because most people who buy consumer motherboards don't add cards beyond GPU and so why include them? The ship has sailed, the horses have left the barn, etc. There would be a market for it sure, but not "make a killing" market.
bug
13,948 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
There's PCIe bifurcation. But it doesn't do what you need. And I'm not even sure is was there before PCIe 3.0 or so.
232 (0.10/day)
Processor Intel i5-13600KF
Motherboard ASRock Z790 PG Lightning
Cooling NZXT Kraken 240
Memory Corsair Vengeance DDR5 6400
Video Card(s) XFX RX 7800 XT
Storage Samsung 990 Pro 2 TB + Samsung 860 EVO 1TB
Display(s) Dell S2721DGF 165Hz
Case Fractal Meshify C
Power Supply Seasonic Focus 750
Mouse Logitech G502 HERO
Keyboard Logitech G512
3,719 (2.51/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
True. It's all x1, I missed that. I also see that Pericom makes a bunch of different PCIe switch chips, up to Gen 3 - their range is similar to that of Asmedia.
The Marvell 88NR2241, which used to be consumer-friendly (the once-popular WD AN1500 card runs on it) still exists too but isn't consumer-friendly anymore.
@Ware In addition to Dremel the cutter, you also need the Lemerd tool, which magically adds lanes where there are too few.
1,348 (0.20/day)
Noir York
Case AIGO Darkflash C285
If your motherboard is mATX and you use ATX case you can always use riser cards like this
I use x1 to x1 riser to relocate my soundcard further bottom the case so it won't suffocate the GPU
