Can't get 5.1 from Pc to Sound system.
leo911
4 (0.01/day)
Hi guys,
Need some advice on what I could be doing wrong.
Receiver: onkyo txst605
GPU: AMD rx6800
Soundcard: xonar se
I am unable to get 5.1 DTS or DD via HDMI or Optical. PC was connected to receiver, then to TV via HDMI out into ARC port on TV(picture and stereo sound) testing via DTS file via VLC etc.
I've also bought this soundcard 5.1 advertised, to try toslink but still only stereo sound.
Do any modded APO drivers like realtek that work for C-Media xonar se?
Or can anyone advice how to force 5.1 via HDMI with this GPU?
Thank you.
2,306 (2.66/day)
Brazil
Processor AMD Ryzen 7 5700X3D
Case Lian Li Lancool 216
Mouse Razer Viper Ultimate
In the Sound Control Panel, if you select your output device and then click Configure (I can only take screenshots in Portuguese here, but I did highlight the button), does it only show Stereo as an option?
INSTG8R
Vanguard Beta Tester
8,098 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Most Optical outputs are just stereo and rely on the amp for DSP to get 5.1
HDMI in theory if set up right sho and can output right uo to 7.1. Sadly I can’t offer any setup advice. I run my Z906s Analogue off my SB ZX IF I ran it via optical it would be stereo and the DSP in my speakers themselves would use either DTS or DD
leo911
4 (0.01/day)
I tried to force 5.1 via HDMI via APO drivers FX configuration via tutorial. I got dolby etc installed but now when I try to select Dolby under advanced it says this format isn't supported by your device.
2,306 (2.66/day)
Brazil
According to these threads in the RoG and the Overclockers UK forums, it looks like the Xonar SE doesn't support DTS and Dolby Digital Live over S/PDIF, further aggravated by its drivers being seriously out-of-date.
100 (0.05/day)
System Name Annihilator
Processor 5800X
Motherboard MSI x570 Gaming Plus
Cooling ID-COOLING FrostFlow X 240
Memory 32GB TForce Xtreem White
Video Card(s) ASRock RX 7800XT Steel Legend
Storage NVME Gen-3 1 TB, 2 TB SSD
Display(s) 32" 144Hz 2k + 34" UW 2k
Case Kediers C-580
Audio Device(s) Sony 5.1 Home Theater
Power Supply TT 850W True Power
Mouse EVGA x20
Keyboard EVGA Z15 RGB Mechanical Gaming Keyboard
Software Winbdows 11
Benchmark Scores 13,797 with AMD Radeon RX 7800 XT(1x) and AMD Ryzen 7 5800X on FireStrike Ultra
I have a SONY Home theater and this situation was a pain at the beginning. Optical only gave me stereo. I connected a HDMI to the HT and still was a bit tricky to get the 5.1 running. It was a learning experience.
Later I learned that the DSP I used with the optical was stereo only, so mind the hardware.
leo911
4 (0.01/day)
Thanks, looks like Hdmi is gonna be my only option. Don't fancy buying another sound card. Would you have any advice on forcing 5.1 via HDMI?
9,728 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Does that Onkyo have a Digital sound stage. I have a Sony receiver with one and it can force 5.1 from the PC thorough Toslink.
2,306 (2.66/day)
Brazil
Issue here is his Xonar SE can't handle 5.1 over Toslink, only through analog.
9,728 (3.46/day)
Cooling In Win SR36
Check the manual on the receiver Toslink is totally digital and Receivers usually can force it but you MB Toslink might also support it.
100 (0.05/day)
Processor 5800X
Case Kediers C-580
Mouse EVGA x20
I have the HDMI from the 6800 to the Home Theater. The HT must support input from HDMI.
9,728 (3.46/day)
Cooling In Win SR36
Check what sound stages the receiver has one of them must be 5.1. My Sony is from 2000 and does not have HDMI but should be able to do DTS or Dolby Digital via digital which includes HDMI. What is the generation of your HDMI cable?
100 (0.05/day)
Processor 5800X
Case Kediers C-580
Mouse EVGA x20
The HDMI cable, I have no idea which generation is, so you can easily guess, cheapo/generic.
The HT is this one: https://www.amazon.com/Sony-BDVN790W-Blu-ray-Theater-System/dp/B006U1YV4E, except that is 4k and mine is 1080p (which I don't use)
Got it for $200 over a year ago practically new, since the owner didn't use it because she lived in an apartment and the neighbors didn't like the noise.
freeagent
9,685 (4.14/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
The source material has to be coded for it. Your speakers have to be set to small, and multichannel if you want to hear your sub..
My NAD had a multichannel stereo feature for those times it wouldn't light up the Dolby or DTS.
