Can't run DDR4 at 3600Mhz on X570-F (Solved)
Melle
9 (0.01/day)
RAM: F4-3600C16D-16GVK
Ripjaws V DDR4-3600MHz CL16-16-16-36 1.35V 16GB (2x8GB)
Mainboard: Asus X570-F
CPU: 3900x
RAM is on Asus X570-F QVL list.
First, I tried the XMP/DOCP and changed the volt to 1.35 but that didn’t work.
Then I ran the THAIPHOON BURNER to find out my speed and timings on the RAM.
Made an export so I could use it in DRAM-Calculator-for-Ryzen-1.7.3.
This is what Ryzen calculator comes up with for fast.
I manually tried 3600, FCLK 1800, 16-16-16-36-52 volt 1.35 that didn't work so I tried 1.45 volt that didn't work either.
Then 3600, FCLK 1800, 22-22-22-36-52 volt 1.45 volt that didn't work either.
Now I'm using 3200, FCLK 1600, 14-15-15-30-48, tRFC 288, procODT 60, volt 1.45.
It works and is stable but I can't use them in 3600 any advice on how to run RAM in 3600Mhz for Ryzen?
461 (0.23/day)
Western NY, USA
Processor AMD Ryzen 7 3700x
Cooling Scythe Ninja 5
Memory G.Skill Ripjaws V 16GB (2 x 8GB) (F4-3600C16D-16GVKC) @ 3733 MHz 16-19-19-19-36-56
Video Card(s) MSI RTX 2060 Super Armor OC 8GB
Storage 1x Samsung 970 EVO 500GB / 3x Crucial MX500 / 4 HDDs
Display(s) Dell 23" LCD S2316M
Case Rosewill Rise Glow
Power Supply CORSAIR RM650
Mouse Cooler Master MS120
Keyboard Cooler Master MS120
What BIOS version are you using ?
I would check the Asus ROG forums and see what BIOS version is working best with Ryzen 3000 CP{Us and RAM OCing.
It seems that is a common issue for your MB.
1,647 (0.88/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
I would update to latest BIOS if you don`t have it already. Have you put RAM in the A2-B2-slots? A common mistake is putting the RAM in A1-B1-slots which run quite a bit slower on most MBs.
Melle
9 (0.01/day)
I'm using Version 2608 but I see that they released a new version yesterday 2609. But I don't think that will help me.
Yes, they are in A2 and B2.
EDIT: Before these RAM I used 3200 on those there was no problem using the XMP profile but 3600 seems like a magic barrier :)
1,647 (0.88/day)
In that case try the ryzen safe preset, try going slightly higher. Try 3266, if it works, try 3333 etc. how far can you go? I bet it is either ProcODT or some timing that gives you trouble. Have you reset BIOS after upgrading RAM? Sometimes hidden settings from previous RAM sticks and makes DCOP impossible. A friend of mine experienced that, changed RAM, nothing worked, did a jumper-reset and DCOP wnet fine.
Melle
9 (0.01/day)
Yes, I had to do a BIOS reset actually a few times but I can't remember if I ever tried DCOP after the reset.
But I put in all the values manually that should work also.
I will install yesterday's BIOS update then try DCOP if that doesn't work try step to step up from 3200 but even if 3266 works and 3333 doesn't I will still be in the same spot right?
60 (0.04/day)
I have similar problem, Asus motherboard with X570 and QVL G.Skill RAM (DDR4-3600MHz CL16-16-16-36 1.35V). I moved back to BIOS with AMD AM4 AGESA V2 PI 1.0.0.2 (BIOS from 2020/06). Last BIOS where only BIOS DOCP and 1,35V was sufficient to boot every time. Three newer BIOS skipped already, the same problem. Tired already to tune QVL RAM in BIOS after every BIOS update.
418 (0.22/day)
Processor R5 5600X
Memory 32 GB 3600 MT/s CL16
Video Card(s) Sapphire Vega 64
Storage 2x 500 GB SSD, 2x 3 TB HDD
Case Phanteks P300A
Software Manjaro Linux, W10 if I have to
It could also be your memory controller on the CPU. Try giving it 1.2 V.
3,666 (0.87/day)
GMT +2
System Name Red Radiance l under construction
Processor 5800x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ Neo rgb 3600mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) lc27g75tq
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat burst pro
Keyboard roccat ryos mk fx
Software windows 10
dont use xmp
set 3600 manually in bios
Melle
9 (0.01/day)
I will try this!
But it is stable also right? I can boot into Windows now with BIOS 2609, 3600 but it will crash after 30 sec or something.
That didn't work but I manage to get back to BIOS and change it back.
dont use xmp
Tried that, Then I tried it with Ryzen calculator timings and some other slower timings.
Melle
9 (0.01/day)
Cant move back to that BIOS version 2203 (2020/06) it says something like not a correct BIOS file.
I have BIOS 2609 now the latest version do I need to downgrade in steps or?
5,929 (2.90/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Are you adjusting soc voltage and vddg/vddp according to Dram calculator info?
5,929 (2.90/day)
Poland
Then you're f'd because you need to adjust both.
1,647 (0.88/day)
If the problem is related to a spesific timing, procODT etc you might notice instability when you get closer to 3600. for instane 3400 might work fine but 3466 is a bit unstable. Often raising timings like tRFC, tRC, tRCDRD og tRP might fix instability. Or you might get 100% stability by raising or lowering procODT a notch.
65 (0.04/day)
System Name Editing Build
Processor Ryzen 9 3900x
Motherboard MSI X470 Gaming Plus Max
Cooling Noctua D15S
Memory G.Skill Trident Z RGB 2x16GB 3200C14 @ 3733mhz 16-15-15-30
Video Card(s) Evga 2060 Super
Storage Crucial 500 Nvme + 500 HDD
Display(s) 24" 1080p Dell
Case Lian Li Lancool II
Power Supply 750w
Software Rendering and Structural Analysis
Benchmark Scores CB R20=8014 CB R15=3581
You can have quick screenshot of ZenTimings before it crash and share here.
Melle
9 (0.01/day)
I was finally able to downgrade BIOS to 2203.
Now I just used DOCP profile and changed fclk nothing else.
Running Karhu memtest now and so far no error count.
If it's stable now I will reinstall Windows and just leave everything like this.
Thanks for all the information and advice.
11,878 (2.23/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
You might want to try setting the memory to jedec 2133 and upping the infinity fabric on its own, see if it's the CPU imc limiting you.
3,425 (1.85/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -8~12
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (366W current) PowerLimit, 1060mV, Adrenalin v24.8.1
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSBuild 22631.4169), upgraded from Win10 to Win11 on Feb 2024
Did you notice that the Uncore Frequency is in half the DRAM frequency? Thats not good.
Meaning that memory controller is in half speed.
Download ZenTimings software and post a screenshot
Melle
9 (0.01/day)
No, I didn't notice that I was just happy it worked with the correct speed and timings.
So when the Uncore Frequency is in half-half the DRAM frequency. What can I do about it and how?
EDIT: I might have set the FCLK wrong I will check this.
3,760 (0.75/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
It means it's not stable.
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
This time you lose silicon lottery in you ryzen 3900x
Melle
9 (0.01/day)
Yea I put the FCLC wrong was in a hurry to test the new speed, now it should be ok.
Just curious do Intel CPU/mainboards have the same trouble with their DRAM speeds as AMD/Ryzen do?
3,760 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
Ah... not sure how this is an AMD thing. You are deciding to use a 3rd party app to oc your ram using tight timings. Any trouble it seems to me is self inflicted.
