can't run gpu with 16x help
mexi95
17 (0.01/day)
Hello to everyone , i have this pc config moba: asus formula xi z390 gpu : asus 2080 ti strix ssd nvme samsung 970 pro, and my gpu is running at 8x instead 16x , and can't change it from the bios , can anyone help me ?
it's not my first build i have this problem only in this config
9,910 (1.84/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
which slot you plug the card?
1st slot or 2nd slot?
14,165 (3.82/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Is there anything in the other PCI-e slot?
It runs at x8/x8 if two slots are populated.
9,340 (5.30/day)
Louisiana
Keyboard G710+x3
You might check which mode your m.2 is in and possibly switch m.2 slots used.
mexi95
17 (0.01/day)
For what I know this moba can handle 2 m.2 with the 16x in the gpu , for change it have to empty the water cooling system , it’s a pain in the ... before doing it want to be sure
Any hint ?
9,340 (5.30/day)
Louisiana
Keyboard G710+x3
I returned a z490 formula for a z490 apex for a few reasons but most was the lame m.2 layout
2nd was this platform does not need a vrm water block.
3rd memory oc is better on apex.
4th saved 100.us :)
Ruru
S.T.A.R.S.
12,958 (2.96/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-K
Cooling Arctic Freezer 50 / Alphacool Eisbaer 240
Storage 3.3TB of SSDs / several small SSDs
VR HMD Oculus Rift CV1
Using a M.2 NVMe SSD shouldn't affect the 1st slot. Usually just on cheaper boards it could disable some SATA connectors but that's not the issue here.
bug
13,832 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
I asked to ASUS to help me and they said the cpu has only 16 lanes , and using a nvme I’m using 4 lanes from those 16
Hm, what CPU is that?
And if that's the case, just move the SSD to the other M.2 slot.
Deleted member 24505
I'm using a z390-f and have 2x PCIe M2 and gpu is still at 16x using both M2 slots. I have sata controller disabled in the bios though if that makes a difference.
752 (0.45/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
Yeah, OP's right. Z390 would be 9th gen Intel, and they're limited to 16 lanes according to ARK. So using a CPU-connected M.2 slot will turn the GPU to x8 mode. If you've got more than one M.2 slot I'd suggest using another one, OP. Check the manual to see which ones are connected to the chipset, use them.
mexi95
17 (0.01/day)
I have 9900k
Can u help me how to do it ?
The manual do specify it
9,340 (5.30/day)
Louisiana
Keyboard G710+x3
You really haven't showed any proof you're running at x8
Use gpu-z and at least show a screen shot saying it is
9,340 (5.30/day)
Louisiana
Keyboard G710+x3
That would be nice because you saying it just is not enough anymore.
Screen shot I show is just too darn easy to show.
Toothless
Tech, Games, and TPU!
9,650 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Make sure there is a load on the GPU when you get the screenshot or all we'll see is the card on idle.
mexi95
17 (0.01/day)
I can demonstrate to you from the bios , is set the gpu set in 8x and can’t change it
how could i tell if my M2's are using cpu or chipset PCIe lanes? as i have 2xPCIe M2's and GPU is still at 16x My CPU is 9th gen so i am assuming only 16 lanes as someone stated up there ^
Toothless
9,650 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
752 (0.45/day)
System Name Main PC
Case Corsair 1000D
how could i tell if my M2's are using cpu or chipset PCIe lanes? as i have 2xPCIe M2's and GPU is still at 16x My CPU is 9th gen so i am assuming only 16 lanes as someone stated up there ^View attachment 166765
x16 1.1? Is this under load? If that's under load, something's wrong. That's the equivalent of 4x 3.0 lanes in bandwidth, which would severely hamper the performance.
Mines not 1.1, mine is 3.0
752 (0.45/day)
System Name Main PC
Case Corsair 1000D
It clearly states "It is currently running at: PCI Express x16 v1.1" in that red box in the picture. Although that might just be power saving at idle
