Capacitor Whine
1,241 (0.21/day)
Connecticut
System Name Corsair 900D
Processor FX8350
Motherboard Asus Crosshair V
Cooling Corsair H110I
Memory 16GB Corsair Vengeance
Video Card(s) Asus GTX1080
Storage 2x 500GB 1x 1TB WD Green
Display(s) Acer 24" 1080p / HP 27" 1080p LED
Case Corsair 900D
Audio Device(s) Sound Blaster X-Fi (Built in/Mobo) - Xonar Sound Card
Power Supply Enermax 1020Watt
Mouse Logitech Something Whatever
Keyboard Logtich G910
Alright I have a Capacitor Whine..I can't find it, it's annoying..and I need to try and find a fix.
Is there anyway to find out which cap is causing the whine? All of them look fine, none are damaged.
And if I can locate the cap, can it be replaced..It's on my EVGA 680i board.
AsRock
TPU addict
19,144 (2.98/day)
UK\USA
If it's the mobo try getting a RMA if thats a option. You sure it's not a coil making the noise ?. IF it is a coil maybe some hot wax on it might help.
In the past i used a rolled up piece of paper and put it by the ear and listen though it.
1,241 (0.21/day)
Connecticut
Processor FX8350
Case Corsair 900D
It goes with system load/idle. Doesn't do it in BIOS or during the Boot process, but once inside window's it does it.
Doesn't really do it until I start pushing some juice through it and playing with some OC setting's..so im guessing its a cap.
AsRock
TPU addict
19,144 (2.98/day)
UK\USA
Role some A4 paper up and see if you can find it that way. could be v card or PSU unless your totally sure it's the mobo for some reason.
1,777 (0.29/day)
South Australia
System Name QUACK
Processor Intel i7 2600K (3.4 GHz, 8 threads)
Motherboard Asus P67P8-V3
Cooling Xigmatek Balder 120mm (4x120,1x140mm case)
Memory Patriot 2 Viper Sector 5, 8GB DDR3 1600 MHz
Video Card(s) Gigabyte GeForce GTX 960 G1 4GB
Storage 1x Samsung EVO 850 (500GB) SSD, 1x Fujitsu 256GB SSD
Display(s) Dell Ultrasharp U2311h 23" (so sexy)
Case CoolerMaster Gladiator RC-600
Audio Device(s) Onboard 5.1
Power Supply Antec 850w with yellow racing stripes
Software Windows 7 HP 64 bit
I've been having the same issue only with my graphics card, thanks for the tip Asrock!
2,702 (0.45/day)
System Name Dire Wolf IV
Processor Intel Core i9 14900K
Motherboard Asus ROG STRIX Z790-I GAMING WIFI
Cooling Arctic Liquid Freezer II 280 w/Thermalright Contact Frame
Memory 2x24GB Corsair DDR5-6600
Video Card(s) NVIDIA RTX4080 FE
Storage AORUS Gen4 7300 1TB + Western Digital SN750 500GB
Display(s) Alienware AW3423DWF (QD-OLED, 3440x1440, 165hz)
Case Corsair Airflow 2000D
Power Supply Corsair SF1000L
Keyboard Chuangquan CQ84
I had something similar. Around half a year ago, without any warning, my HD4870X2 started screaming under load. The whine came from the card itself, and I couldn't figure out why. I Googled around a bit, and a few issues people were having pointed out to the PSU as being the culprit. I had an old HEC Cougar 750W at the time.
I replaced the PSU with a brand new one (Hiper 880W) and the whine went away. The HEC kept running in a secondary rig for about two more months before failing (And getting replaced by a nice and quiet 330W S12-II Seasonic).
Might be worthwhile to look into.
2,792 (0.39/day)
Tre, Suomi Finland
System Name Ladpot ◦◦◦ Desktop
Processor R7 5800H ◦◦◦ i7 4770K, watercooled
Motherboard HP 88D2 ◦◦◦ Asus Z87-C2 Maximus VI Formula
Cooling Mixed gases ◦◦◦ Fuzion V1, MCW60/R2, DDC1/DDCT-01s top, PA120.3, EK200, D12SL-12, liq.metal TIM
Memory 2× 8GB DDR4-3200 ◦◦◦ 2× 8GB Crucial Ballistix Tactical LP DDR3-1600
Video Card(s) RTX 3070 ◦◦◦ heaps of dead GPUs in the garage
Storage Samsung 980 PRO 2TB ◦◦◦ Samsung 840Pro 256@178GB + 4× WD Red 2TB in RAID10 + LaCie Blade Runner 4TB
Display(s) HP ZR30w 30" 2560×1600 (WQXGA) H2-IPS
Case Lian Li PC-A16B
Power Supply Corsair AX860i
Mouse Logitech MX Master 2S / Contour RollerMouse Red+
Keyboard Logitech Elite Keyboard from 2006 / Contour Balance Keyboard / Logitech diNovo Edge
Software W11 x64 ◦◦◦ W10 x64
Benchmark Scores It does boot up? I think.
Capacitors cannot possibly make any sounds.
r9
3,300 (0.55/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
Coils then. And try with another PSU.
InnocentCriminal
Resident Grammar Amender
6,477 (0.89/day)
System Name BeeR 6
Cooling Corsair H100i
Case Fractal Design Arc Mini
Power Supply Corsair HX750W
I have this problem but with USB devices, it's so odd. The more devices I add, the louder the whines get.
AsRock
TPU addict
19,144 (2.98/day)
UK\USA
You could all so use a paper towel tube too :p. Never find one when i want one though.
7,228 (1.08/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
But they can be the cause of the whine. Basically, they are not "smoothing" or "storing" charge without introducing additional harmonic frequencies to the original AC source. A better capacitor can remove/reduce this fail-to-smooth or the harmonic signal generation.
And hence FIX the issue.
ANALOGY: A child with his hand caught in the door cannot make a sound. Wait. Right. The child will whine. But it aint the hand or the door that's doing the whining.
1,241 (0.21/day)
Connecticut
Processor FX8350
Case Corsair 900D
Thanks.
I think I found the problem. It's around the NB...but im not sure which cap is causing it, or if it is a cap causing it. It sound's like it's coming from the chipset itself...and the Chipset is also getting extremely hot..even with the fan.
Could the motherboard actually be making the sound? Caused by just age and heat from the PC?
Would it be recommended to just replace all of them in that area?
http://img.techpowerup.org/090701/board-bigE.jpg
(Uploaded an image so all can see the area im talking about)
2,792 (0.39/day)
Tre, Suomi Finland
You're talking about electrical noise, one that you see with a scope. Not the audible variety the thread's about.
But yes, wrong/bad caps can make inductors to squeal.
7,228 (1.08/day)
How do you make an audible noise from an electrical circuit? (wait a beat). Exactly! QED.
12,067 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
You are experiencing bus noise.
1,241 (0.21/day)
Connecticut
Processor FX8350
Case Corsair 900D
This is all grand, about how something can't make noise, then it can make noise, and how you can see it with a oscilloscope or not.
Bottom line is...It's making noise, It's fucking annoying, I need it fixed.
Located problem, doesn't sound like it's anything replaceable, any ideas?
1,241 (0.21/day)
Connecticut
Processor FX8350
Case Corsair 900D
12,067 (1.72/day)
Motherboard Asus
Keyboard Razer
Software A lot.
Probably the two coil chokes. Hot glue them and see if it stops it, and while you are at it, try unplugging your PC speaker and speakers.
1,241 (0.21/day)
Connecticut
Processor FX8350
Case Corsair 900D
I'll try this. Thanks.
Now how exactly do I hot glue them? Glue over top, the base?
7,228 (1.08/day)
FIRST. Put your fingers on them to see if that will dampen the sound. If not, the glue wont help; the problem is elsewhere. The idea of the glue is to stop them, or reduce their ability to vibrate. Fingers work too... much quicker to test if the glue will help.
1,241 (0.21/day)
Connecticut
Processor FX8350
Case Corsair 900D
Thanks.
Didn't work, so i didn't try the glue.
Im starting to wonder that it's just the age of the board.
I've never had any other issue's and it run's flawlessly..just makes a racket during operation.
43,617 (6.45/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
I've heard of people using nail polish to coat the noisy part.
887 (0.15/day)
Processor Intel Core i3-8100
Motherboard ASRock H370 Pro4
Cooling Cryorig M9i
Memory 16GB G.Skill Aegis DDR4-2400
Video Card(s) Gigabyte GeForce GTX 1060 WindForce OC 3GB
Storage Crucial MX500 512GB SSD
Display(s) Dell S2316M LCD
Case Fractal Design Define R4 Black Pearl
Power Supply Corsair CX600M
Mouse Logitech M500
Keyboard Lenovo KB1021 USB
Well, if nothing else works, you could always get the board recapped. I've sent several motherboards to BadCaps.net for capacitor replacement. Contact him and see what he thinks about your problem.
Fitseries3
Eleet Hardware Junkie
15,508 (2.45/day)
Republic of Texas
"whine" and "squeel" are made by inductor coils, NOT capacitors. my 680i's had that issue but i have also heard cpus make a similar noise.
1,241 (0.21/day)
Connecticut
Processor FX8350
Case Corsair 900D
You do anything to fix it, or just ignore it swap it out?
Im hoping to get rid of it, cause I'm going to part my rig out.
