case fan might have died (not sure)
4 (0.00/day)
System Name POLY PC
Processor Ryzen 5 3600
Motherboard ASRock B450M Pro4
Cooling Cooler Master Hyper 212 LED
Memory VIPER Predator 16GB 3200mhz CL18
Video Card(s) GIGABYTE RTX 2060 OC
Storage 2tb barracuda hdd, 120gb wd green ssd
Display(s) AOC 24G2U 144hz and some random old acer monitor
Case i have no idea
Audio Device(s) JBL **earphones** and logitech speakers
Power Supply Be Quiet! 600W 80+ bronze
Mouse Razer Deathadder Elite
Keyboard Marvo KG954G
Software Windows 10 pro
okay so i built my pc llike 6 months ago everything worked fine. yesterday i was doing something and i needed the pc run through out the whole night... when i woke up one of my fans just wasnt spinning. i checkced SpeedFan and it said there is a fan but its spinning at 0rpm. so i think the motor died or something but the pc still recognizes it. please help
13,611 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Have you tried plugging it in to one of the other headers?
4 (0.00/day)
System Name POLY PC
Case i have no idea
yes, yes i tried plugging it into the cpu fan header and the cpu fan to the chasis fan header, cpu fan worked my case fan didnt
3,050 (1.71/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 160W PPT limit, 75C temp limit, CO -9~14
Motherboard Gigabyte X570 Aorus Pro (Rev1.0), BIOS F37h, AGESA V2 1.2.0.B
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off center mount for Ryzen, TIM: Kryonaut
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MHz 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~465W (378W current) PowerLimit, 1060mV, Adrenalin v24.7.1
Display(s) Dell Alienware AW3423DW 34" QD-OLED curved (1800R), 3440x1440 144Hz (max 175Hz) HDR1000, VRR on
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSB 22631.3737)
So if this fan is not working on another header that another fan is working, consider it damaged/dead.
If you have that fan unconnected in your hand and try to give it a spin... does it rev at all?
If you give it a good spin with your hand it should at least spin for 3-5 seconds. If it stops immediately and do only 1-2 revolutions then the bearing is dead.
If it continues spinning for 3-5 sec then the motor is dead.
Is this a 3 or 4-pin fan? Your fan headers are configured to work (regulate) speed with voltage, PWM or auto? The other fan you tried in that header is identical fan?
Is the non spinning fan new or old?
4 (0.00/day)
System Name POLY PC
Case i have no idea
okay so it spins fine for like 3,5 seconds, i connect it to a motherboard with a 3 pin connector, i have no idea what my fan headers are configured to do, it is pwm, the other fan i tried was a cpu cooler fan, and i bought the non spinning fan with my pc so like 6-7 months. also when i boot up my computer it moves a little and then it comes back
3,050 (1.71/day)
When on boot you say moves a little... how little?
If the board fan header is 3pin, it can’t be PWM. It must be voltage.
At this point you should state what the board is. And what the fan is. Model or at least if it’s 3/4pin.
Can you check into BIOS, in the fan controlling section, the configuration of the headers? At what temps are set to and what temperature of the board are controlling? Any temp/speed curves?
Also do you use any in-Windows software to control the fan speeds?
8,155 (2.23/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
Speedfan has been hit and miss working in win10 for a while now, like it depends on if it is an even or odd day. I would love to see it updated.
Fans are not perfect and subject to random fails, even the most dependable brands have a bad apple on occasion. So apply direct power from the PSU and if it works, it works, if not get another one.
2,373 (0.59/day)
Audio Device(s) A LOT
1) add your system specs to your profile!
2) Disable speedfan (especially if you don’t know how it’s configured)
3) set bios fan speeds to 100%
4) try manually starting the fan while it’s connected and receiving power
4) report back here! ;)
4 (0.00/day)
System Name POLY PC
Case i have no idea
okay so my motherboard is an ASRock B450M Pro4, i dont remember the fan model name or anything but its aRGB 120mm fan and i know its 3 pin, also i tried setting my fan speeds to 100% with my bios and nothing happened, so im guessing it really is dead
