- Mar 3, 2014
- 13 (0.00/day)
- Brasil
Specs:
Asus rampage iv extreme
I7 3930k 2011
32 gb ddr3 HyperX FURY 1866MHz 4 x 8gb
2 ssd raid 0 , Kingston HyperX Fury120GB cada um, SATA 3 SHFS37A/120G
Fonte Corsair 1000W CP-9020062-WW 80 Plus Gold
Placa de vídeo VGA EVGA GeForce GTX760 2GB DDR5 256-Bit PCI-Express 3.0
NZXT Controlador de FANS - SENTRY MIX 6 Canais
6 Spire Cooler FAN 120 x 120 x 25 mm SP12025S3H3/4- PCI Blue
Kit cabos extenssores sleveed Monkey custon 24 pinos + 2 pci express + energia cpu =
3 fan Enermax Cooler FAN Vegas Duo 14cm
2 fan Enermax Cooler FAN Vegas trio 12cm
watercooler
1 waterblock xspc raystorm CPU
1 waterblock xspc universal xspc
kit waterblock koolance rampage IV extreme =
1 Reservatorio Alphacool Cape Fuzion Core 30 - Acetal - Preto
1 radiador triplo rs 360 xspc
1 radiador triplo black ice gt
2 Medidor De Vazão Barrow C/ 3 Threads 1/4 (Hélice)
3 Sensor De Temperatura D'Água XSPC LED azul
8 Barb Fitting Bitspower Chrome
4 Compression Fitting XSPC ID:1/2 OD:3/4 Cromado
1 Válvula Bitspower- Dreno - Black Sparkle Com Manopla
8 Conector(Fillport) xspc cromado =
22 Compression Fitting 3/8" x 1/2" Rigid Revolver Diamond Knurled 10 Pack - Anodized Black
Tubulação rígida (acrilico) PrimoChill 3/8 rígida PETG Tubing Azul
1 Adaptador XSPC Em ''T''
1 barra de leon plasma azul raios, (dentro do reservatorio)
1 Top Bitspower para 2 bombas
1 bomba d5 xspc Fluxo máximo: 1200 lph (12V) com controle de velocidade
1 bomba d5 Alphacool VPP655 com controle de velocidade
LED lighting and LED bar
Acrilicos
painting
hammer THOR
Mods:
Casemod theme was based on the God of Thunder Thor.
All done manually
The cabinet has been modified (cut) in some spots.
Various acrylic mold parts.
Special paint, made of Watter transfer (thunder)
The pictures speak more than words.
Brazilian Champion casemod 2nd place 2015 Campus Party Brazil
Hello .Sou Douglas Alves.
I'm from Brazil.
Specs:
I7 3930k 2011
watercooler
Acrilicos
painting
hammer THOR
Mods:
All done manually
I'm from Brazil.
