[Case Gallery] cdawall's rig
cdawall
where the hell are my stars
27,680 (4.14/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
Specs:
AMD Phenom 9500@2.84ghz 1.37v
2x1GB patriot extreme DDR800 5-5-5-12@1022 5-5-5-15 2.2v
2x1GB corsair XMS2 DDR800 4-4-4-12@1022 5-5-5-15
2x HD3850 256mb 750/1048
swiftech MCP655, 500mL bottle rad, BIX240 and maze4
Mods:
painted tooless fan mounts black
painted OCZ ram cooler black
added blue LED fan to side panel
cut out 2x120mm holes in the front of the case for rad
created a res from a 500mL sport bottle
freaksavior
To infinity ... and beyond!
8,095 (1.24/day)
System Name ZeroUptime | M.A.S.S / MM1
Processor Xeon 2659 v3 / Xeon 2683 v4 / ARM A14
Motherboard Asus X99-E-10G WS / ASRock x99 usb 3.1 / Apple
Cooling NZXT Kraken / Noctua NH-L12 / Apple
Memory 16Gb DDR4 / 32Gb DDR4 / 16GB HBLM
Video Card(s) Powercooler ATI vega 64 / GT 7300 / ARM
Storage Samsung 970 512 Evo NVMe / A lot. / 256 + 512 External TB3
Display(s) Acer Predator X34 / Headless / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MMM1
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corais HX850 | Corsair TX750 / Internal 250w
Mouse g502 proteus core / Headless / g502 proteus core
Keyboard Corsair K95 Cherry Blue / Headless / K65 Cherry Red
Software Windows 10 / ESXI / Big Sur 11.2.2
haha i helped build that
chron
569 (0.08/day)
a little dark, but from what i can tell, not bad. Are the tubes painted silver? Is there a downside to not having see-through tubing?
intel igent
4,640 (0.65/day)
Toronto, Canada
System Name old school / new school
Processor 3.0e C0 @ 3.6 / e5200
Motherboard p4p800e-dlx / p5q-DLX
Cooling custom water see sig / air
Memory 2x1g oczPC4000EbPl / 2x2g ocz2rpr1066
Video Card(s) 3850AGP / 4890vaporX
Storage 36g raptor+120g wd / wd 1001fals 1tb
Display(s) BenQ / sharpAQUOS LC-37D64U
Case modded antec plusview / generic
Audio Device(s) audigy 2zs / ASUS Xonar HDAV1.3
Power Supply fan/cable modded powerstream 520 / OCZ 700mxsp
Software Xp pro SP2 / VISTA ultimate OEM
yes! another antec/chieftech/chenming build! :rockout
you fit the 240 in the front under the drive bay's? IIRC my mcr woul'nt fit....
tubing run's could use some work ;)
is that tygon silver?
nice rig!
cdawall
27,680 (4.14/day)
Houston
Processor 2990WX
Software W10P
yep its tygon silver and yes i fit a 240 under the drive bays :D
heheh its a ultra dragon tho not one of the other names of it
intel igent
4,640 (0.65/day)
Toronto, Canada
ultra dragon was made by chieftech ;)
that BIX RAD must be smaller than the mcr then cuz like i said i don't think i could've fit it in there......
it's OK the H/C cool's just as well as a 240 anyway.....
good choice on the tubing should give you extended maintenance interval's
