For the squirr cage are you going to use some tubing to carry the intake air onto your compoundments? If so how are you going to distribute them into the cpu,ram GPU and the HDD? So you are trying to run a full passive cooling comp.. custom mod some homemade WATER COOLING system like me ^_^.
Yes.. and I'm not trying to run a passive cooling system, it WILL be one, no question, no worries. The sheer amount of cold air I'm pushing into the components heatsinks will more than easily cool the entire rig even if my airflow implementation is crap
However, I considered doing it via heatpipe, by standard radiaton and by direct routing through the heatsink. I think the most pratical one would be just blowing over the radiating fins of the heatsinks. Hell, I might try all three.. but come to think of it, routing them through a sink like water cooling systems would prolly cause way too much turbulence and likely generate a bit of heat itself just by necking down the airflow that tight.
Also in that confined of a space, I think the efficiency of the system would drop dramatically. Water and air are completely different beasts in that respect.
As for LED fans, this is not the case for it. This is purely an experiment in cooling. I will prolly put some white CCFL's in to highlight the install though, but thats about it as far as plans go now. Later as the case pushes forward, I might go as far as to try to make it a truly environmentally controlled case. Humidity, Pressure, Tempature... etc.. I wonder if I can keep the cpu from changing temperature regardless of the ambient.. or load...
Some exceptions, obviously, but you get the idea. Hardware would *love* a case like that.
As for specs, which one? I have 21 machines, 9 modded. If you mean this one, I have not selected anything for it yet.. I still need to choose everything from the mobo to the optical.
Water cooling.. never held much interest for me. I might try one some day just for a laugh or when/if I decide to tackle a total environmentally controlled box and it becomes part of the method.
50 slot 1 cpus and coolers...they came from about 3 or 4 retrofitting jobs combined that I did back then.. businesses in the area I lived in then were always on the bleeding edge.. as soon as Intel went FC-PGA, they all just *had* to be upgraded again. I got the leftovers. lol
Really, for CFM, what it boils down to is I just don't know yet. I'm mulling it over.. have yet to decide anything really, except that the outside is a silver flake teal, and the inside is flat black.
