- Jul 15, 2019
- 594 (0.29/day)
- Hungary
System Name | Detox sleeper |
Processor | Intel i9-7980XE@4,5Ghz |
Motherboard | Asrock x299 Taichi XE (custom bios with ecc reg support, old microcode) |
Cooling | Custom water: Alphacool XT45 1080 + 9xArctic P12, EK-D5 pump combo, EK Velocity D-RGB block |
Memory | 8x16Gb Hynix DJR ECC REG 3200@4000 |
Video Card(s) | Sapphire RX7900XT - NITRO+ Vapor-X 20GB |
Storage | Samsung PM9A1 1Tb + 2x PM981 512Gb + Kingston HyperX 480Gb + Samsung Evo 860 500Gb |
Display(s) | HP ZR30W (30" 2560x1600 10 bit) |
Case | Chieftec 1E0-500A-CT04 + AMD Sempron sticker |
Audio Device(s) | Genius Cavimanus |
Power Supply | Super Flower Leadex 750w Platinum |
Mouse | Logitech G400 |
Keyboard | IBM Model M122 (boltmod, micro pro usbc) |
Software | Windows 11 Pro x64 |
i have a few ch341a black programmer. Now i bought a green ch341a 1.7 just because it can do multi voltage settings.
That 1.7 not detecting anything.
I tried all of the programs that in the first post.
Current programmer: CH341
ID(9F): 000000(Unknown)
ID(90): 0000(Unknown)
ID(AB): 00(Unknown)
ID(15): 0000(Unknown)
the green light is on, even there is no chip in the socket
my other older black works fine, but i dont want to kill the 3.3v spi chips.
![IMG_20250211_094257.jpg IMG_20250211_094257.jpg](https://tpucdn.com/forums/data/attachments/374/374269-ac08100c6dafa64615f737c3309ae15f.jpg)
jumper is on the 1-2 prog mode. voltage at 3.3v
Do i need a different program?
ID(AB): 00(Unknown)
