All,
I'm trying to install OS X Snow Leopard or Lion on my new PC build. Regrefully, I didn't research the graphic card and I know the Sapphire Radeon 6770 will not work on my build. I've read that if I change the device ID to the 5770 that it will work, so I want to attempt that.
I'd rather not go through the trouble of returning and buying the 5770 if it isn't an complicated process.
I can't find anywhere how to do that, I've looked for at least 24 hours. I don't want to do any other BIOS changes. Just change the device ID only. How do I do that?
Here are my build specs:
GIGABYTE GA-Z68XP-UD3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
SAPPHIRE Vapor-X 100328VXL Radeon HD 6770 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
COOLER MASTER Silent Pro M600 RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Bronze Certified Modular Active PFC Power Supply
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
LG CD/DVD Burner Black SATA Model GH22NS70 OEM
COOLER MASTER Elite 430 RC-430-KWN1 Black Steel / Plastic Computer Case
Rosewill RNX-N300X PCI Wireless Adapter
