Changing motherboard without reinstalling Wndows 7 Pro
1,131 (0.23/day)
Motherboard ASRock X670E Lightning PG
Cooling Thermalright Phantom Spirit 120SE CPU cooler, 3x 140mm, 1x 120mm case fan
Memory 32GB G.SKILL Flare X5 DDR5 6000 (PC5 48000) F5-6000J3038F16GX2-FX5
Video Card(s) Zotac RTX 4070 Super Trinity Black
Storage 2TB Sandisk SSD, 2TB P31 SK Hynix, 4TB WD SN850X, WD Black 6TB, WD Red Plus 12TB
Case Fractal Design Definse S
Power Supply Seasonic Focus 750
Mouse Logitech Pro
Keyboard Corsair Strafe Cherry MX Silent w/red LED
VR HMD Meta Quest 2
Hello,
I am thinking of upgrading my old AMD 965 to a newer Intel i5 3570K or i5 4670K setup. Obviously, this will require a new motherboard and RAM in addition to the CPU. However, I would like to keep my current Windows 7 Pro 64bit install. I have a lot of programs and games with mods set up in particular ways that are hard (if not impossible in some instances) to reconfigure in the same way. And my Windows 7 install is in good shape (69 from power on to Firefox) so I don't feel a need to wipe my HDD.
I am wondering if I can change my motherboard without having to reinstall Windows 7 Pro 64bit and what the process is. First, my current specs:
ASUS M3N78 Pro: M3N78 PRO - http://www.asus.com/Motherboards/M3N78_PRO/#overview
Windows 7 Pro 64bit with latest updates
AMD 965
8GB GDDR2
GTX670
WD Black 2TB (boot drive)
Seagate 750GB (backup data drive, unplugged most of the time)
ASUS DVD burner
Antec Earthwatts 650 Green
What I am looking at upgrading to:
MSI Z77MA-G45:
http://www.msi.com/product/mb/Z77MA-G45.html#/?div=Basic
With an i5 3570K and DDR3 RAM of whatever quality brand is on sale.
Or MSI Z87-G43:
http://us.msi.com/product/mb/Z87-G43.html
With an i5 4670K and DDR3 RAM of whatever quality brand is on sale.
This is a big change, going from AMD to Intel and ASUS to MSI. So can this hardware change be done without reinstalling Windows 7 Pro 64bit? If so, can someone detail the steps must I take?
Note: I do have a data HDD which I use for data backups, so I do have a backup of all my files. I also realize a motherboard switch requires Windows 7 to be reactivated.
Thanks for your help.
Kursah
Super Moderator
14,734 (2.20/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
All I've ever had to do here is uninstall the MB drivers, have new MB drivers ready. Make sure if you were or were not in ACHI mode you ensure the new MB is setup that way in BIOS or EFI.
Everything should work on the base driver, except for maybe network adapters. If you have drivers ready you should be okay.
You may have to run a scandisk or windows repair if it fails to intialize a boot after the hardware repair. Also if you swap connector numbers on HDD's, you may either need to swap them physically on the MB (i.e. SATA 0 was OS, now you have the OS drive on SATA 1 and DVD on SATA 0) or via Manage Disks in Windows.
Really though should be pretty minimal..uninstall cpu, all MB related drivers and software, shut down. hardware swap...setup new MB bios, boot into windows, install new drivers and go. That's worked for me many times...not very hard. But others have had great issues. I recommend you run MS Easy File Transfer or similar backup methods, or copy your Users folder and other important data off your OS drive or OS partition just in case it gets corrupted during the initialization of new hardware like others have experienced.
Good luck! Should be pretty easy imho...but ymmv! Keep us posted! :toast:
4,966 (0.87/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
8,552 (1.84/day)
Ovronnaz, Wallis, Switzerland
VR HMD Medion Erazer
i went from a 890FX to a X58 without problems other than re activating my Win7Pro64 on the other hand i had to do a new install when i went from a X58 (Asus P6T SE) to a ...X58 (Asus Rampage III Extreme)
also went from a 970 to the 890FX i mentioned above without anything else than re activate win7
1,131 (0.23/day)
Mouse Logitech Pro
VR HMD Meta Quest 2
Thanks for the quick reply. I have a couple of extra questions. I can't seem to find any ASUS drivers in the Uninstall Programs list. Would I have to uninstall the drivers via the Device Manager; and if so which devices in particular?
http://i995.photobucket.com/albums/af73/Flogger23m/Untitled_zpsa471db96.jpg
What is EFI?
For Windows 7 Repair do I insert the DVD and boot from the disk?
As for the HDD SATAs, are you suggesting to keeping them in the same position as they are in my current motherboard? So if my boot drive is in position 1 I should ensure it is in position 1 on the new motherboard?
there are posts on this all the time, it's one of the most commonly asked questions. If you have a specific error by all means but please read existing threads before making additional ones.
http://www.techpowerup.com/forums/showthread.php?p=2985790
best of luck :)
Will do, it just that most other posts seem to be smaller/more similar upgrades (ASUS to ASUS, Intel to Intel ect.) where as I am going to Intel and MSI. I am not sure if that complicates things more or adds extra steps.
8,552 (1.84/day)
well as you can see i had no problem from a Asus AMD 890FX to a Asus P6T SE X58, but i had one when i went from a Asus P6T SE X58 to a Asus Rampage III Extreme X58
AMD to Intel no probs, Intel to Intel and same chipset no go :D weird eh?
from a ASRock 970 Extreme 3 to a X58 no prob either ... eh eh eh ...
as said except do a driver uninstall nothing else is critical
but be allways prepared to fresh reinstall, allways a good idea to have a small HDD/SSD 120/160gb for win and most used soft and some 7200 or even better 10k/SSD for games and 5600 for vids/pics/data less used
Kursah
Super Moderator
14,734 (2.20/day)
Missoula, MT, USA
Uninstall drivers through device manager yes, and software via Programs and Features.
What is EFI?
Pretty much a BIOS with a GUI that also supports mouse use and advanced features that modern OSes can utilize.
Well Windows will generally give you the option to repair, but yes it may require the install DVD to replace corrupted files. It will tell you.
Yes, that will keep the drive letter and physical drive order in check, and make the OS not have to look as hard for drives, drive letter assignments that could cause issues with locating programs, etc.
Tatty_Two
Gone Fishing
25,962 (3.73/day)
Worcestershire, UK
Software Win 11 Home x64
You should use "control panel" >>> add/remove programmes as shown in attachment, you should then see things like "chipset" drivers, maybe "Ethernet/Lan controllers" etc......
1,131 (0.23/day)
Mouse Logitech Pro
VR HMD Meta Quest 2
Thanks, that seems simple enough. I'll double check my manual to see what my HDD is currently in.
Though I can not seem to find anything under the uninstall programs area that would be apart of my motherboard drivers:
http://i995.photobucket.com/albums/af73/Flogger23m/programlist1_zps2dba4b1f.jpg
http://i995.photobucket.com/albums/af73/Flogger23m/programlist2_zps9a2cfcd4.jpg
http://i995.photobucket.com/albums/af73/Flogger23m/programlist3_zps5999e2c0.jpg
http://i995.photobucket.com/albums/af73/Flogger23m/programlist4_zps41dbb92a.jpg
Does anything there look like it would belong to my motherboard (ASUS M3N78 Pro)?
Kursah
Super Moderator
14,734 (2.20/day)
Missoula, MT, USA
Looks like you're okay...only did a quick scan. Uninstall the hardware and swap and boot. A few restarts from driver installs (it helps to have them ready, unzipped and quickly accessable), and enjoy. Should be good to go. I also use CCLeaner just in case there's old stuff that might cause issues, had a solid Win7 experience overall until I recently went Win 8. You should be good to go! Keep us posted and good luck! I hope nothing goes awry!
:toast:
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
Uninstall all MB software and drivers. You will have to reactivate Windows and if its an OEM you may have to call MS. You will take a performance hit but it shouldn't be much
1,131 (0.23/day)
Mouse Logitech Pro
VR HMD Meta Quest 2
:toast:
I haven't ordered any new parts or uninstalled any software yet, just looking for the motherboard drivers to uninstall and note them when the time comes. But I am not seeing any. :confused: As the screen shots show, I am not seeing any specific driver or software for my motherboard to uninstall which I find odd.
Edit: Also what my Device Manager lists:
http://i995.photobucket.com/albums/af73/Flogger23m/devicemanager1_zps78aee7c7.jpg
http://i995.photobucket.com/albums/af73/Flogger23m/devicemanager2_zpsfd1f16f9.jpg
Which of these devices pertain to my motherboard, if any? And if I am to uninstall something through the Control Panel should I uninstall just the driver or also the driver and the device?
Only thing I can think of is the nvidia nForce Networking Controller and possibly the stuff under the Audio tab. Or is doing that unnecessary?
2,330 (0.36/day)
Australia
System Name All Ryze
Processor Ryzen 7 1700
Motherboard MSI X370 Pro Carbon
Cooling Air
Memory G-skill Flare x 16GB 2400MHz
Video Card(s) MSI 1080
Storage Intel 600p NVMe 512GB for OS , 1TB WD Black and a 4TB Toshiba
Display(s) BENQ PD3200U
Case Phanteks
Power Supply Corsair 750W
Mouse Logitech G403 wired
Keyboard G19
I went from a P35 chipset windows 7 and uninstalled all drivers and chucked in an x58 setup booted into windows and installed drivers. Been running fine for the last year or so.
