Cincoze Unveils GeForce RTX 30-series and Quadro T1000-series MXM Upgrade Cards
47,555 (7.46/day)
Cincoze, a professional manufacturer of embedded systems, expands the Cincoze GM-1000's machine vision application performance with two new Quadro MXM GPU modules. Building on the GM-1000's powerful processing base, the MXM-RTX3000 and MXM-T1000 provide the additional GPU capacity for rapid adoption of machine vision in smart factories, from simple environmental perception applications such as positioning, measurement, identification, and sorting, to more complex vision-guided automation functions. GPU requirements for each scenario are different, so specifications must match the environment and application. The two new Quadro MXM GPU modules broaden the GM-1000's available selection to cover a wider range of uses.
The GM-1000—part of the Cincoze GOLD series—is positioned as a high-performance machine vision system featuring high computing performance, high-speed I/O, and industrial-grade reliability. It is the preferred choice for machine vision system integrators and AOI (Automated Optical Inspection) manufacturers. The GM-1000's unique carrier board can be matched with a selection of Cincoze MXM GPU modules, including the MXM-RTX3000, MXM-T1000, MXM-P2000, and MXM-E9174, providing a precise match for different computing requirements.
Upgrade flexibility has always been a proud advantage of Cincoze. The GM-1000 only needs a carrier board and MXM GPU module replacement to facilitate future performance upgrades without replacing the computer host.
Computational Prowess While Saving Power
The new Quadro MXM GPU modules, the MXM-RTX3000 and MXM-T1000, use the latest NVIDIA Quadro Turing GPU architecture based on the latest 12nm process.
In terms of core computing power and performance, the MXM-RTX3000 has 1920 CUDA cores, 5.3 TFLOPS peak FP32 high-end computing power, parallel integer execution, AI computing Tensor core, and specialized RT core for raytracing. Together these provide fully integrated GPU features to face complex visual image calculations. The MXM-T1000 has 896 CUDA cores, 2.6 TFLOPS peak FP32 computing power, and only 50 W power consumption for power-conscious high-speed computing.
Both models support GDDR6 memory. The MXM-RTX3000 has a single card capacity of up to 6 GB and 336 GB/s memory bandwidth. The MXM-T1000 has 4 GB capacity and 192 GB/s memory bandwidth. The faster memory smooths data reading and multiplies computing performance.
In addition, both modules have different form factors, the MXM-RTX3000 sporting an MXM 3.1 Type B form factor, while the MXM-T1000 has a Type A form factor, allowing for free choice according to the situation.
Cincoze's GM-1000 embedded system is tailored for machine vision. It also meets the long-term supply demands of the industrial field, providing extended availability of fifteen years for the GM-1000 and five years for the two Quadro MXM GPU modules. So whether it is industrial equipment or other smart application fields, future availability is ensured.
238 (0.05/day)
Processor 3700X
Motherboard X570 TUF Plus
Cooling U12
Memory 32GB 3600MHz
Video Card(s) eVGA GTX970
Storage 512GB 970 Pro
Case CM 500L vertical
Quadro RTX 3000 = Turing, like the Quadro RTX 4000, Quadro RTX 6000, etc.
1,610 (0.34/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Fractal Arc XL / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM850 / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
This, the title is misleading, there were no Geforce cards unveiled, they're all Turing based Quadros.
551 (0.17/day)
Texas
System Name O-Clock
Processor Intel Core i9-9900K @ 52x/49x 8c8t
Motherboard ASUS Maximus XI Gene
Cooling EK Quantum Velocity C+A, EK Quantum Vector C+A, CE 280, Monsta 280, GTS 280 all w/ A14 IP67
Memory 2x16GB G.Skill TridentZ @3900 MHz CL16
Video Card(s) EVGA RTX 2080 Ti XC Black
Storage Samsung 983 ZET 960GB, 2x WD SN850X 4TB
Display(s) Asus VG259QM
Case Corsair 900D
Audio Device(s) beyerdynamic DT 990 600Ω, Asus SupremeFX Hi-Fi 5.25", Elgato Wave 3
Power Supply EVGA 1600 T2 w/ A14 IP67
Mouse Logitech G403 Wireless (PMW3366)
Keyboard Monsgeek M5W w/ Cherry MX Silent Black RGBs
Benchmark Scores https://hwbot.org/search/submissions/permalink?userId=92615&cpuId=5773
Why is GeForce even in the title..???
