Cinebench R10 Benchmark suite
shevanel
3,464 (0.63/day)
Leesburg, FL
If you'd like to post your results feel free.. click on the button that says Rendering xcpu under CPU benchmark.
Cinebench 10
Software Description
The completely reworked MAXON CINEBENCH R10 is now available for all users, manufacturers and hardware testers who want to test the performance of graphics cards and CPUs for either Macintosh or Windows systems. The new version of MAXON CINEBENCH R10 contains new test scenes especially designed to meet the demands of state-of-the-art hardware. Like its predecessors, MAXON CINEBENCH R10 is also based on MAXON Computer's Hollywood-proven software, CINEMA 4D.
The CPU test, which renders a 3D scene photo-realistically, now applies even more performance-intensive functions such as area light sources, procedural shaders, Ambient Occlusion and multi-level reflections. Especially when used on faster, multi-core CPU systems, MAXON CINEBENCH R10 delivers much more accurate results.
The graphics cards tests have also been thoroughly reworked. The computer running the test must execute a camera flight at maximum speed to determine the performance of the graphics card.
The MAXON CINEBENCH R10 uses a wide range of algorithms and instructions which ensure that the tests performed deliver a very good overview of a system's overall performance capabilities, also with regard to other CPU and graphics card-intensive tasks. MAXON CINEBENCH R10 supports up to 16 CPUs or CPU cores and runs under Windows (2000, XP, Vista in 32-bit or 64-bit) or Mac OS X (with PowerPC and Intel processors).
It's a real-world test suite that assesses your computer's performace capabilities. MAXON CINEBENCH is based on MAXON's award winning animation software CINEMA 4D, which is used extensively by studios and production houses worldwide for 3D content creation. MAXON software has been used in blockbuster movies such and Spiderman, Star Wars, The Chronicles of Narnia and many more.
MAXON CINEBENCH runs several tests on your computer to measure the performance of the main processor and the graphics card under real world circumstances. The benchmark application makes use of up to 16 CPUs or CPU cores and is available for Windows (32- and 64-Bit) and Macintosh (PPC- and Intel-based).
The resulting values among different Operating Systems are 100% comparable and therefore very useful with regard to purchasing decision-making. It can also be used as a marketing tool for hardware vendors or simply to compare hardware among colleagues or friends.
shevanel
3,464 (0.63/day)
Leesburg, FL
Top 20
01. Crazybc 24665 00:00:35 i7 920 @ 4.2ghz
02. shevanel 16902 00:00:52 q9550 @ 3.8ghz
03. vrgn86 15990 00:00:55 i7 920 @ 2.6 stock
04. Stanhemi 15845 00:00:55 q9550 @ 3612mhz
05. Shevanel 15317 00:00:57 q9550 @ 3.5ghz
06. Raptori 14518 00:01:00 q6600 @ 3573mhz
07. chuck216 14239 00:01:02 phenom II 940 @ 3.5ghz
08. scope54 14176 00:01:02 q9550 @ 3.33ghz
09. 3dsage 12430 00:01:11 Phenom 9950 @ 3.4ghz
10.
shevanel
3,464 (0.63/day)
Leesburg, FL
be sure to click X-CPU under CPU Benchmark to utilize all cores
shevanel
3,464 (0.63/day)
Leesburg, FL
Q9550 @ 3.5ghz .. rendered in 00:00:57
stanhemi
801 (0.14/day)
Montreal,-Canada.
System Name CRUNSHING MINI FARM
Processor Q9550 C1(lapped)@4105mhz 1,38vcore/Q6600 G0 @3010mhz 1,24vcore
Motherboard P5Q-E 8.5 x 483 fsb/P5QPL-AM 9x334fsb
Cooling watercooled storm,mcw60,2x240mm,micro res rev2,laing ddc3.2/Xig s1283(lapped)
Memory CORSAIR DOMINATOR 2X2G 1066MHZ@965-mhz 5-4-5-15/kingston kvr800mhz 2x1g
Video Card(s) SAPPHIRRE 4870 1G @850/1020/ati x1950 pro
Storage RAID0 2X RAPTOR 74gb/wd 250g
Display(s) 22'' LCD 1680x1050/lg 17" 1280x1024
Case Antec 900 white inside/crappy white case
Audio Device(s) onboard/onboard
Power Supply ocz 700 watt mod xstream pro/enermax noiseblocker 485 watt
Software Windows 7 x64/vista 32
Benchmark Scores 3dmark06 18950
15845@3612mhz 00:00:55 (3600mhz it my crunching clock try later today at 4000mhz:D)
70 (0.01/day)
southern ontario
Processor Intel 6700K
Motherboard GIGABYTE Z170 Gamming 7
Cooling Corsaid H115i
Memory G.SKILL Ripjaws V Series 32GB F4-2800C15Q-32GVR
Video Card(s) MSI GTX 970
Storage Samsung 950 pro 312 gb
Display(s) 24" Benq FP241W
Case Corsair 750D
Power Supply EVGA 750 G2
Mouse Corsair M65 pro
Keyboard Corsair K70
Software W10 64 bit premium
I think this is done right
895 (0.15/day)
System Name Raptor
Processor Core i7 13700K
Motherboard MSI Z690 Tomahawk WiFi
Cooling ArcticFreezer 420
Memory Corsair VENGEANCE® 32GB (2x16GB) DDR5 5600MHz C36
Video Card(s) Palit GameRock 3080Ti OC
Storage M.2 Addlink S70 Lite , Samsung SSD 980 PRO 2TB, SanDisk Ultra II 480GB, 1TB seagate
Display(s) ASUS TUF VG27AQL1A
Case LANCOOL III
Audio Device(s) Realtek® ALC4080 Codec + Philips SHP9500
Power Supply Seasonic GX-1000
Mouse G502 Proteus Spectrum
Keyboard ASUS CERBERUS
got 14518 with Q6600@3573 rendered in 00:01:00
3dsage
1,797 (0.31/day)
NW Burbs of Chicago
System Name *5GHZ_STAR*
Processor Core i5 2500K 5GHZ 24/7 1.38Vcore
Motherboard Asrock P67 Extreme6
Cooling Scythe SCMG-2100 REV. B
Memory 2x2GB GSkill Ripjaw X 1600 CL7
Video Card(s) 4850 XFIRE
Storage 500GB + 1TB NAS
Display(s) I-INC 28" LCD 1920x1200
Case Antec P180
Power Supply Thermaltake TR2 TRX-650
Software Seven Ultimate 64-bit
Heres one of my old Phenom 9950 B.E @ 3.4GHZ
304 (0.04/day)
Chicago
System Name Big Beast
Processor AMD Ryzen 7 5800x3D
Motherboard Asus Strix x570-I Gaming
Cooling NZXT AIO
Memory Patriot Viper 16GB 3666MHz
Video Card(s) AMD Radeon 7900XTX
Storage Lot's of it
Display(s) Samsung CHG70 27"
Case NZXT H1
Power Supply 850watt
Software Windows 11 Professional x64
Q9550 @ 3.33Ghz
did it in 1:02
809 (0.13/day)
Tampa FL
Processor AMD Ryzen 3800x
Motherboard Asus TUF Gaming X-570-Plus (WiFi)
Cooling Corsair Hydro Series H110i
Memory 32 GB Corsair Dominator RGB DDR4 3200 Mhz @3600
Video Card(s) Asus AREZ RX Vega 64 Strix OC 8GB
Storage Samsung 970 EVO Plus 1 TB
Display(s) Asus PB258Q 25" 2560x1440
Case Cooler Master Master Case 5 Pro
Power Supply Corsair RMx 1000
Software Windows 10 Pro 64
Here's my Phenom II 940 BE @3.5 ghz:
shevanel
3,464 (0.63/day)
Leesburg, FL
Here is my run after getting my q9550 to 3.8ghz "stable" (passes tests but wanna see if it hard-locks during games)
Binge
Overclocking Surrealism
6,979 (1.19/day)
PA, USA
System Name Molly
Processor i5 3570K
Motherboard Z77 ASRock
Cooling CooliT Eco
Memory 2x4GB Mushkin Redline Ridgebacks
Video Card(s) Gigabyte GTX 680
Case Coolermaster CM690 II Advanced
Power Supply Corsair HX-1000
My cinebench R10 result from 7+ months ago. I'll do another when my rig is back up and running this week.
stats were Rampage 2 Extreme + 920 C0 @ 4.2Ghz + 3x1 1600Mhz Cas 8
shevanel
3,464 (0.63/day)
Leesburg, FL
man those i7's are insane, i want one!
too bad i just bought this q9550 a week ago
637 (0.11/day)
Canada
System Name Tahiti Treat
Processor i7 4770K @ 4500MHz
Motherboard Asus Maximus VI Hero
Cooling Custom H20
Memory Patriot Viper 8GB @ 1866MHz
Video Card(s) 2X Sapphire 7870XT (Tahiti Core) @ 1150/1500 CrossFire
Storage 2 x Intel 120GB 520 Series SSD Raid0 # 2x Seagate 1TB Raid0 # 1 WD 2TB EARS
Display(s) 3 x 22" Eyefinity
Case Cosmos S Custom
Audio Device(s) Asus X-FI
Power Supply Corsair AX860i
Software Win7 64Bit Ultimate
Benchmark Scores http://www.3dmark.com/3dm11/6848547
Q9650 @ 4.2GHz renederd in 48 seconds Score 18314
Deleted member 74752
24/7 mb
JrRacinFan
Served 5k and counting ...
20,105 (3.15/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
Athlon2K15
HyperVtX™
7,909 (1.21/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
Core i7 860 @ 4.2ghz 35 seconds 24601 is the score
stanhemi
801 (0.14/day)
Montreal,-Canada.
16854@ 3825mhz 00:00:52
2,894 (0.49/day)
South Carolina
System Name KILLER
Processor Intel Core i7 4790K
Motherboard MSI Z87 G45 Gaming
Cooling Water Cooling
Memory 2x8GB Gskill 2400mhz
Video Card(s) EVGA GTX 980
Storage SSD Samsung 500GB
Display(s) 24" Asus 144hz
Case Cooler Master HAF
Audio Device(s) X-Fi Platinum
Power Supply Antec 1200 Watt Modular
Software Windows 10 64 Bit
Benchmark Scores 3DMark Vantage 51342
Heres my score.
998 (3.29/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Here's mine :)
(Sorry, late to the game)
Screen shot taken Jan 10th 08'
