Cleaning corrosion/oxidised stain on Noctua D-15S heatsink
785 (0.23/day)
System Name Fat NCASE
Processor Ryzen R9 3900X
Motherboard ASUS TUF GAMING B550M ZAKU (WIFI) Edition
Cooling Scythe Fuma with 3 SCYTHE Wondersnail 2400RPM + Arctic MX2
Memory Corsair Vengeance 128GB @3200Mhz Cl16 (32GB X 4)
Video Card(s) Palit RTX 3060 StormX ITX 12GB
Storage MX500 4TB SATA + Toshiba MG08 16TB HDD
Display(s) LG 27UL500 4K monitor
Case Jonsbo W2 black
Audio Device(s) Onboard realtek 1200 & Soundblaster G3 usb
Power Supply ASUS ROG STRIX 850W Gundam Edition
Mouse Elecom wireless mouse :)
Keyboard RK100 Royal Kludge
Software Windows 10 HOME
Benchmark Scores Don't know any benchmark. It runs good enough for me.
Today disassemble my pc to clean of the dust and everything in my itx pc. I realised that my d15s heatsink have to solid white powder stain at the tips of the fins. I could not wipe it out with a micro fiber cloth. And I am unable to scratch it off with my nail, it looks pretty rock solid. Do you know what is it and how to remove it?
2,149 (0.34/day)
Austin TX
Processor i9 11900k
Motherboard Maximus XII Apex
Cooling Custom Liquid W/ 360x60 Radiator
Memory 32Gb Team XTREEM ARGB 3600 b-die
Video Card(s) Waterblocked MSI RTX 4070
Storage Intel 900p 480Gb + 4tb Intel 670p
Display(s) LG C2 evo 42"
Case Geometric Future Model 8
Audio Device(s) HD58X + Sennheiser GSX 1000
Power Supply Corsair RM 750x
Mouse Steelseries Aerox 5 wired
Keyboard Akko Mod 007b HE
VR HMD Samsung Odyssey+
Dunk one tower at a time into some white vinager for about 10 or so minutes, then rinse with water. You might have to repeat this process a few times.
It might also help to use N old toothbrush to scrub the surface of the fins while it is soaking in the vinager bath.
565 (0.25/day)
Zadar, Croatia
System Name SloMo
Processor G4560
Motherboard MSi H110-PRO-D
Cooling LC-CC-95 @ Arctic Cooling fan
Memory 2X Crucial DDR4 2400 4GB
Video Card(s) Integrated HD 610
Storage WD 500 GB + Seagate 500 GB + Toshiba 3 TB
Display(s) Lenovo D221
Audio Device(s) Manhattan Flex BT Headphones, Encore P-801 stereo speakers
Power Supply Corsair CX450M
Mouse microsoft office mouse
Keyboard Modecom mc-800m
Benchmark Scores gorstak @ hwbot.org
those are too gentle for rubbing with something hard. You might bend them or brake them or if you use some liquid, they will change it's colour. I'd leave it as it is.
785 (0.23/day)
@Arrakis9
Would the nickel plating be stripped off if I did that? I remember putting my rusted dvd drive cover plate in vinegar, it stripped of the rust but it also stripped of the coating to bare metal. It rusted worse after that. I find it strange how this stain happen to the plated heatsink especially my tower coolers. Stock intel heatsink don't seem to suffer from it.
hat
Enthusiast
21,745 (3.30/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
You probably already know this but it's purely a cosmetic issue, shouldn't affect performance in any way...
silentbogo
5,541 (1.38/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 4x8GB Samsung DDR4 ECC UDIMM
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
NO! It may damage nickel-plated layer and maybe even cause some black spots to appear on heatpipes. Also not good for aluminium.
That white powdery stuff is aluminium hydroxide, which probably appeared from too much moisture in the air. Yesterday I was cleaning customer's ROG laptop from this crap (for some reason it spent nearly 6mo in the garage).
You may attempt to remove it with a toothbrush, but it won't be permanent. Even if you have some small amount left, it will be enough to propagate growth in the future. The best thing you can do is give it an ultrasonic bath. If you know anyone in automotive repair business, those guys may have a bath large enough to fit the heatsink.
All you need to do afterwards is spray it with some anti-corrosive stuff (if you are not afraid of smell, then even a WD40 will do).
If ultrasonic bath is not an option, then WD40+toothbrush and probably half an hour of manual labor. You'll probably scratch the surrounding fins in the process, but that's still better than corrosion.
1,487 (0.32/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
WD40, PB blast, any other anticorrosive spray( quite a few out there) will do. Napa or Autozone has a lot. Also Aluminum prep spray can work as well if you can not find a ultrasonic bath. @silentbogo said it best with ultrasonic bath.
Also check with any powder coat or cerakote business in town they may have a ultrasonic cleaner
9,910 (1.85/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
Yep try first with vinegar
7,061 (1.01/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay)
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Don't do anything to it. Its fine. Probably the fans abraided some Nickel? anti corrosion coating/plating off so you have a small amount of aluminum oxide. It doesn't matter one bit.
2,963 (0.84/day)
Long Island
SilentBogo got it right ... The heat sink is not nickel, it;'s aluminum and aluminim reacts with moisture to form aluminim oxide. You will find this and other compounds inside water loops of AIOs with aluminum rads.
1. Is it reducing cooling performance ? yes, the oxide is acting like an insulator
2. Is it a concern ? No, it's covers such a small area, that the % impact is miniscule.
If it is aesthetically objectionable ....
1. Remove cooler
2. Wipe TIM with 90%+ isoprophyl alcohol till clean
3. Get a tupperware or container, fill with solution of vinegar and water and insert up side down covering affected areas.
4. Wait 10 minutes, clean with stiff non metal brush or use small plastic scraper / spatula like thingie (available at hardware store) to remove.
5. Rinse with water... dry with fan.
6. Grab a good TIM (Shin Etsu $4 at Directron) and reinstall
7. Get a dehumidifier
2,149 (0.34/day)
Austin TX
Processor i9 11900k
@Arrakis9
There may have been grease/dirt in those exact spots when the heatsink was being electro plated wich would answer why it corroded in the first place. As mentioned by some of the other members there is a possibility for it to strip the nickel off, but you can always dilute the vinager with water and reduce the soak time to help mitigate that issue. At this point it's entirely up to you if you wnat to chance it. Personally I would just leave it be and slap the fans back on it and not worry about it.
