[Case Gallery] Clear B&R
DaMulta
My stars went supernova
16,168 (2.47/day)
Oklahoma T-Town
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
Specs:
AM2 x2 3600+ 65mm OC 2678 1.38 volts No IHS on CPU
CPU cooled with Cool Master Aquagame Viva
G.Skill 8500HK clocked at 1071.4 2.4volts 5-5-5-15
EPoX EP-AD580XR motherboard
C3D x1950XTX
X-Fi Fatal1ty
80Gig SATA
250 SATA
Themaltake Toughpower 750Watt
Case: Cool Master Aluminum
Mods:
Custom clear wall, added lights, 9 case fans inside, AS5 on all parts, and took the IHS off of the CPU.
2ed stick of memory will be in it next week.
43,593 (6.63/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Pink? Huh? Nice cable management. I'm going to pass voting on this one. I'd like to see some changes.
DaMulta
16,168 (2.47/day)
Oklahoma T-Town
Storage SSD 64GB
No those are red. The Camera makes it look that way for some odd reason.
43,593 (6.63/day)
Storage WD m.2
Keyboard Tester84
Potato - potahto, looks pink to me. Then you get a 9 for having a camera that butchers the color red.
DaMulta
16,168 (2.47/day)
Oklahoma T-Town
Storage SSD 64GB
Those blue lights are super bright(I think that's what causes it). Oh yea I have each blue light on its own switch.
Now that I look at it/ It does look like(Not the pics) those fans are pinkish and red.
3,558 (0.53/day)
Enschede, The Netherlands
System Name Lian Li Carbon fiber ed.
Processor Intel i5 2500k 4.6Ghz 24/7 Max OC 5Ghz
Motherboard Asrock Z68 Extreme3 Gen3
Cooling Swiftech blocks, 360 Xflow rad, Swiftech 120 rad, Liang with XSPC res/pump top.
Memory 8Gb Mushkin 1600Mhz 8-9-8-24
Video Card(s) Sapphire HD6950 2Gb
Storage OCZ Vertex 4 128 / Western Digital 160
Display(s) ASUS 25,5" wide VW266h
Power Supply Corsair HX620 modular
Software Windows 7 64
Very nice system. Thumbs up.
How does the Coolermaster CPU cooler perform?
993 (0.15/day)
Los Angeles...U.S.A
Processor i7 920
Motherboard EVGA X58
Cooling eight 120mm fans, Swiftech GTZ cpu block, 3 120mm radiator, MCP655 pump, primochill tubing
Memory 6 gig G-Skill DDR3 1600
Video Card(s) GTX 285's (SLI)
Storage 500GB Western Digital
Display(s) 3 Asus 23 in inchers
Case Lian Li A77B
Audio Device(s) on board 7.1
Power Supply Corsair 1000
Software win 7 64
Very clean. Not a real "fan" of the fan color, but hey.............good job
DaMulta
16,168 (2.47/day)
Oklahoma T-Town
Storage SSD 64GB
49/55
But if I oc more it stays the same. It trys to hold it at that temp, because it has intelligent fans that look for that temp.
DaMulta
16,168 (2.47/day)
Oklahoma T-Town
Storage SSD 64GB
I'm thinking about painting the inside of this case. What color should I go with?
6,959 (1.07/day)
Australia, Sydney
Ouch at the pink!!! Did u try folding the IDE cables? I like the white SATA cables a lot. Pretty open, and apart from the pink I like it. :) 9.555555 out of 10 (10).
900 (0.14/day)
Canada
System Name MurderBox #17
Processor Intel Core i7 5930k - 4.5Ghz 1.275v - Bitspower Summit EF
Motherboard Asus X99-E WS - Bitspower THOR AIX99 Full Full Board Block
Cooling SR-1 480, 8x Corsair ML120 , MCP350, I&H Res 250, PETG hard pipe, Mayhems Pastel White
Memory 32GB G.Skill Ripjaws 4 DDR4 2666
Video Card(s) Nvidia GTX 1080 Ti Founders Edition - EK Fullcover waterblock with Backplate
Storage 970 Pro 512GB, 960 EVO 500GB, PM961 512GB, 3x SM951 256GB,, WD Black 2TB, Seagate 4TB
Display(s) ASUS PG348Q 3440x1440, 2X ASUS PB278 2560x1440
Case MurderMod TJ07 With Illuminated mid-plate
Audio Device(s) Schiit Bifrost > Schiit Asgard > Hifiman HE400i - Audio Technica AT2020
Power Supply Corsair AX1200i With custom MDPC Sleeve and Noctua NF-A14 iPPC-3000 PWM
Mouse Steelseries Rival 600
Keyboard Corsair K95 RGB
Software Microsoft Windows 10 Professional 64bit
You shouldn't stack the fans like that, it will burn out the bearings in a hurry. Other than that good job.
DaMulta
16,168 (2.47/day)
Oklahoma T-Town
Storage SSD 64GB
I've never seen that problem before and I have stacked fans for years. They are like what 5 bucks? Who cares if they burn out quicker.
Solaris17
Super Dainty Moderator
26,215 (3.79/day)
Alabama
System Name Rocinante
Processor I9 14900KS
Motherboard MSI MPG Z790I Edge WiFi Gaming
Cooling be quiet! Pure Loop 240mm
Memory 64GB Gskill Trident Z5 DDR5 6000
Storage 1x 500GB 980 Pro | 1x 1TB 980 Pro | 1x 8TB Corsair MP400
Display(s) Odyssey OLED G9 (G95SC)
Case LANCOOL 205M MESH Snow
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Power Supply ASUS ROG Loki SFX-L 1000W
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
Software openSUSE Tumbleweed
i like the pink i dont see what ppls problems with it are i mean im not gay and iv had sex more times than i can count i was going to go purple with mine blue fans with purple cathodes but newegg was out and i got my blue cathodes for free so...meh maybe in the future.
DaMulta
16,168 (2.47/day)
Oklahoma T-Town
Storage SSD 64GB
I ended up with a 7 because of semi pink-red case fans LOL
