Clevo P150EM and GTX980M
jadawin_2
1 (0.00/day)
Hi yall,
two years ago i bought a Clevo P150EM (prostar Branded) second hand. I really love this old peace of laptop and wanted to upgrade the GTX670m.
So i bought a GTX980M from China on Aliexpress stating that it was compatible with all laptop like clevo, alienware etc...
When i put the card inside the laptop, it beeps for 30s (one beep every second) and shuts down.
I did upgrade the bios and EC of the laptop with the lastest of Eurocom :
EC V 1.02.11EC
BIOS V1.02.17EC v3b GTX9
and when i plug the card in the laptop, the bios says that it is a NVidia card, but it stills beeps for 30s and shuts down.
I checked the temps with my finger and it never gets the chance to be hot. The fans are new and spinning.
I can boot into windows, even log into my account but it shuts down before i can do anything.
I tried to flash the Vbios with one for GTX980M specific from Clevo, but NVflash (dos version) does not recognize the card, even with instructions that would force the bios to be updated.
By the way the GTX670M is still working great.
So my question is : is the GPU dead ?
Or is there a way to bypass the shutdown so i can investigate further inside windows ?
Is there a magical trick i am not aware of ?
Thanks.
243 (0.18/day)
USA
System Name Desktop PC
Processor AMD Ryzen 5 5500
Motherboard MSI B450I Gaming Plus Max Wi-Fi
Cooling Corsair Hydro X Series Custom Loop
Memory 32 (2x16) GB Corsair Vengeance LPX DDR4 3200 MHz
Video Card(s) NVIDIA GeForce RTX 2060 Super FE
Storage 1 TB Samsung 970 EVO PCIe 3.0 NVMe SSD
Display(s) Vizio 1080p TV Screen (Temporary)
Case Fractal Design Define Nano S
Audio Device(s) Razer Kraken X Headset
Power Supply Corsair RM650x 650W
Mouse Razer DeathAdder V2 Gaming Mouse
Keyboard Razer Cynosa Lite Gaming Keyboard
VR HMD HTC Vive Cosmos
Software Windows 10 Home 64 Bit
Benchmark Scores 3DMark Time Spy: 8706 (Stock)
Laptops with MXM cards are kind of weird. Companies like Clevo design laptops with rigorous size, TDP, and cooling requirements in mind. Your laptop motherboard might support a handful of MXM cards, but certainly not all of them. Desktops are much more lenient when it comes to compatibility between motherboards and graphics cards.
I'd suggest that you do not remove your 670M unless it breaks and you have an identical 670M on hand to replace it.
214 (0.14/day)
System Name PowerSpec 1720 (Clevo PB70EF-G)
Processor i7-8750H (UV)
Motherboard PB70EF-G
Cooling SYY 157
Memory 32GB 3000MHz 15-18-18-36 1T (OC)
Video Card(s) 115W RTX 2070 8GB GDDR6 (OC/UV)
Storage 500GB WD Black SN700 NVME, 1TB Samsung 980
Display(s) 144Hz G-Sync 17.3" IPS
Case PowerSpec
Audio Device(s) Sound Blaster Pro-Gaming X
Power Supply 230W
Keyboard Redragon K556/DITI K585
Software M$ Windows 10 Pro, Throttle Stop 9.5, MSi Afterburner, ParkControl
I believe @Rithsom is exactly right. Unfortunately AliExpress info can often be bad and perhaps that card is MXM but not actually compatible. I am no authority so continue to research until you are absolutely sure.
Some cards that appear to have worked in that model (for reference);
List of other P150 successful upgrades - https://linustechtips.com/topic/814438-successful-mxm-gpu-upgraded-laptops/
9,340 (5.39/day)
Louisiana
Keyboard G710+x3
Best policy is to stay away from aliexpress period they always side with the fraud seller.
2,715 (0.58/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
It could be that the 980m might be a dell version or msi version. I remember the Dell version was only Compatible with dells but the msi or asus version was compatible with many brands. Honestly it morebof a pain to get it working.
I would go over to http://forum.notebookreview.com/forums and ask for help. But since the gpu is old and mxm designs are long dead, you might not get much help. Plus those forums are dying.
bassistas
1 (0.03/day)
Hello, I have the same laptop P150EM laptop and I recently got an msi gtx 980m from ebay (msi MS-1W0J1) to upgrade the old 670m. I have installed the premamod 1.02.17PM V2 bios but when I turn on the laptop it starts beeping after about 1 minute and finally, it shuts down. I guess I need to flash the prema vbios for this card in order to work correctly but I cant find the file. Does anyone have it?
