Clicking noise from water pump
139 (0.03/day)
Ukiah
System Name The Tempest
Processor i7 5960x at 4.5ghz 1.255 bios vcore 3.4ghz cache 1.13v on custom water 1.85vin llc5
Motherboard Asrock X99X Killer Fatality
Cooling Swiftech DDC mcp50-x pump XSPC RaystormPro waterblock Acool xt45 Supernova1260 rad 9 140mmfans 1vrmF
Memory 32gb 4x8gb Kingston HyperX Fury (Micron rev.b) 2400mhz 15-15-15-35 @ 3200 16-19-19-36 2T 1.4v
Video Card(s) AMD 6800 XT reference OC 2525~2625 1.1v mem oc 2150 Fast timing Alphacool Eisblock gpx waterblock
Storage M.2 2 TB SSD Seagate 4tb 5400 Western Digital 6tb 7200
Display(s) 4k HDR TLC 43" 60hz TV
Case Antec 900 Top fan 200mm/1side/2front/1rear 120mm AC Supernova 1260 rad 9/140mm fans 1700RPM 1VRM fan
Audio Device(s) Onboard Realtech Logitech 5.1 surround/ Bluetooth headphones
Power Supply Corsair RM1000i PSU
Mouse Logitech
Keyboard Logitech
Benchmark Scores Time Spy ~20000 Extreme 7800 Fire Strike 55000 Extreme 27415 Ultra 13604 Port Royal 10032
Suddenly my water pump started making a clicking sound. I'm wondering if its the pump going bad or some debris in the pump. I recently cleaned it all out and everything was fine, but now it suddenly started ticking or clicking. Anybody ever experience this? The pump is fairly new. Its a custom loop I put together as you all can see in the below video.
18,584 (2.67/day)
System Name AlderLake
Hmm, I don't see any video....
18,584 (2.67/day)
Use the "media" option to insert a youtube video.
139 (0.03/day)
Ukiah
Mouse Logitech
Keyboard Logitech
It sounds like a mini jackhammer up close, and can also hear it when at 20% pwm, usually it's silent.
393 (0.09/day)
Processor Ryzen 7 5800x @ 4,85Ghz
Motherboard AORUS MASTER X570
Cooling Costume External Water Loop 1080 Rad
Memory Patriot Viper Steel DDR4-3600 16GB @3800 mhz cl16
Video Card(s) RTX 3090 Water
Storage Raid0 4 x Sasmsung 850 EVo, 980 1TB M.2
Display(s) ASUS Swift
Case Open test bench
Power Supply Be quiet! 850 P10
Mouse G703
Keyboard Old USB Dell Keyboard x2
VR HMD Rift S
Lei
1,143 (0.87/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
Did you let air through its lungs?
3,385 (1.68/day)
Power Supply Corsair RM750x
Mouse Logitech M575
What kind of pump is that? It doesn't sound good like there is an obstruction hitting the pump fins.
I recognize that case - Antec 900 right? I had modded mine to put the rad on top (outside) of the case while keeping the 200mm fan.
I still have 2 of them and the big brother 1200 model.
139 (0.03/day)
Ukiah
Mouse Logitech
Keyboard Logitech
Nope no air has gone through it. Dang this the second 50-x I bought any have a 35-x or 50-x that runs 24/7 a long time? They are rated at 50,000 hours. Yep that's an Antec 900, I used to have both rads in the front with hdd's and cd drive above. The tubing ended up getting kinked under the cd drive I'm thinking of setting it up like that again without the cd drive. How did you mod the 900 for rad up top?
43,467 (6.76/day)
Check to ensure no fans are strinking wires.
Otherwise replace the pump
1,780 (0.33/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
It sounds like cavitation, probably from lack of net positive suction head (NPSH). It needs a large reservoir mounted well above the pump inlet to let gravity assist.
2,260 (1.23/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
Sounds like the impeller is hitting the housing or something?
Lei
1,143 (0.87/day)
usually in my shirt
@Good Guru
I recommend getting a big reservoir and sink the pump in.
5 liters suffice
A bonus is that it muffles the pump noise too
9,340 (5.15/day)
Louisiana
Keyboard G710+x3
Only time I've had issues like this is if a water block cpu/ gpu was near or completely clogged.
43,467 (6.76/day)
3,830 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
Dude excessive use of useless anti kink coils man. There is nothing to do just listening to it. Take it a apart and fix it. It's a TT...
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
That pump is either dead, or has no fluid in it
You sure it's even plumbed correctly, with the out on the res going to the inlet of the pump?
Without telling us anything at all it's damned hard to help
What model is that res? the pump? What fluid is used? What have you done to it recently?
3,385 (1.68/day)
Mouse Logitech M575
I still have a picture of it. Basically I found some old motherboard standoffs (x4) where the threads had matched my AIO I was using at the time. So I inserted them into the AIO and drilled some holes in the top panel to match the placement of the standoffs in the AIO. then used some screws with washers on the back side of the panel into the standoffs to keep it in place. With fans on top I got some fan grilles to keep fingers and stuff from getting into the fans. In order to get the AIO into the case I used a Dremel to cut out the 120mm fan grille and lined the sharp edges with some small tubing (I had to split) that was normally used to feed water to furnace humidifiers and ziptied the tubing into place. To close the hole I used some blue automotive filter cut to size and weaved zipties through it to close the gap around the tubing. For a custom loop you can probably get away with using the (I think it was 2) existing holes with cable grommets on the back side to run the tubing instead so you don't have to loose the 120mm back fan.
139 (0.03/day)
Ukiah
Mouse Logitech
Keyboard Logitech
The resevoir is an old thermaltake one, the pump is swiftech mcp 50-x and the fluid is Mayhems Ultra 1 clear. I have'nt done anything to it recently.
Outback Bronze
Super Moderator
2,137 (0.43/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
Yeah sounds like the pumps on the way out. You gota get a Swifttech MCP 655/ D5 pump. I've got one here that's been going for over 12 years now. Awesome pumps.
Had a few pumps like that and generally that noise means its cactus. Even if its not cactus, the noise of it will drive you insane.
You can try rotating the pump etc to see if that removes the sound.
Lei
1,143 (0.87/day)
usually in my shirt
The vibration of the pump can create that noise as you placed it on wooden desk.
It's like putting a hard disk in the same position you put your pump now.
Try placing a cushion sheet under it and see how it goes.
Looks like your pipe fastener is also touching the pump body.
2,259 (1.00/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
sound like you have some thing stuck in the impeller bit of o-ring or crud from res or rad, strip it down and give it a clean.
4,524 (0.81/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
Second the D5. My first lasted 6-7 years 8760 hr/year, the second has only 3-4 to it’s name but is still running. Both silent. See my spec for details.
  • Like
Reactions: Lei
Outback Bronze
Super Moderator
2,137 (0.43/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Asus
Keyboard Corsair
Software Win 11
How did the first one die? Mines still going. What fluid did you use?
Thanks.
4,524 (0.81/day)
Denmark
Thanks.
Leak as far as I remember, motor short. Expensive pure H2O, small amount of anti-fugus, changed it once :oops:
Lei
1,143 (0.87/day)
usually in my shirt
Lol, my pump is swimming in the reservoir for 2 years.
I just use H2O, same one I drink.
