I installed ThrottleStop, did UV, reduced CPU clocks, and PL1/PL2. Everything works great, but I have a few more questions.
I managed to replace my RTX4060 laptop with a 4070 for a nominal amount. Previously, I had a 13620H and its power was more than enough for me, now I have 6 more cores in the 14650HX, which means higher power consumption, higher temperatures, etc. I use the laptop for work, it works 8-12 hours a day, so these aspects are important to me.
1. Is it better to disable 4 cores (2P and 2E) in the BIOS or lower the clock speed? (I would like to maintain single-core performance, so I left 2 cores with full turbo 5.2Ghz). Default P core: 2 x 5.2 + 6 x 4.8; E core: 3.7, reduced to 2.6
2. Do the TPL settings as in the screenshot keep my PL1 and PL2 values or those saved in the laptop profile? I have ThrotteStop set to automatically turn off when running on battery, does PL1 and PL2 then switch to the laptop profile? By default, the laptop battery has 15 and 30 W (energy saving). I'm asking because when changing these options, a padlock often appears and the changes are only applied after the computer is restarted.
If you have any other advice, I would be obliged
