CLU safe to use with water block and gpu?
341 (0.12/day)
System Name Core p90
Processor I7 9700k
Motherboard ASRock Z390 Phantom Gaming 4
Cooling Ek supremacy evo cpu block/nexxxos ut60 rad 480mm/D5 vario pump 310mm reservoir combo.
Memory Trident gskill 16gb 3000mhz
Video Card(s) Nvidia Founders edition rtx 3080 10gb
Storage M.2 Intel 660p 1024gb, 4tb 7200 rpm black Western Digital hdd
Display(s) Acer x34 predator 3440x1440p 120hz g-sync ultrawide 21:9 monitor
Case Thermaltake Core P90 tempered glass edition
Audio Device(s) On board
Power Supply Thermaltake smart m1200w
Mouse Logitech G600
Keyboard Logitech G910
Software Windows 10 64bit
Can I use CLU between ihs and water block?
Can I use it on my GPU?
21,749 (3.41/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4000 (Running 1:1:1 to FCLK)
Case Thermaltake Core X31
Yes, but it's conductive so you have to be really really careful with the application. In general, I'd say it is not worth the risk.
2,707 (0.74/day)
On The Highway To Hell \m/
Like he says. If you do use it, exercise extreme caution. I use it on my GPU die. But I covered everything nearby that could be shorted by it with dielectric grease as a protective barrier first. Which has been working fine so far.
341 (0.12/day)
Processor I7 9700k
Mouse Logitech G600
What about nail Polish? Can I use that?
If I use clu on water block must I also cover the Golden bits or the CPU with nail Polish?
The ones outside the ihs
21,749 (3.41/day)
Olympia, WA
System Name Pioneer
I wouldn't use nail polish. I'm unsure if it's electrically safe. I'd honestly just use a cobventional thermal grease.
2,707 (0.74/day)
You probably could use clear nail polish. But it's less reversible. So I wouldn't for this purpose. That and it would be harder to see if you had enough/good coverage. What I did was gob a good thick layer of clear dielectric grease on the areas inside the red lines. And CLU inside the area within green lines(obviously).
341 (0.12/day)
Processor I7 9700k
Mouse Logitech G600
That picture is a picture of a gpu right?
2,707 (0.74/day)
Yes. It's of the same GPU I applied it on. An R9 280X to be specific.
341 (0.12/day)
Processor I7 9700k
Mouse Logitech G600
For the CPU little gold bits. The ones inside the ihs area on the die. Can I use colored nail Polish. Or must it be clear absolutely?
2,707 (0.74/day)
I would use clear. In case whatever was used as a colorant might have conductive properties. Might not matter. But clear seems the safest bet.
peche
Thermaltake fanboy
6,709 (1.79/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
my question here is... why CLU between CPU IHS and waterblock... ultra worthless
also using it over GPU die still risky for me, worthless, better use some Arctic Cooling MX4 or better, liquid metals are 100% electrically conductive, also might corrode GPU die, CPU IHS and some aluminium blocks are well know for being destroyed, so beware...
