Raevenlord
- Aug 12, 2016
- 3,755 (1.23/day)
- Portugal
System Name | The Ryzening |
Processor | AMD Ryzen 9 5900X |
Motherboard | MSI X570 MAG TOMAHAWK |
Cooling | Lian Li Galahad 360mm AIO |
Memory | 32 GB G.Skill Trident Z F4-3733 (4x 8 GB) |
Video Card(s) | Gigabyte RTX 3070 Ti |
Storage | Boot: Transcend MTE220S 2TB, Kintson A2000 1TB, Seagate Firewolf Pro 14 TB |
Display(s) | Acer Nitro VG270UP (1440p 144 Hz IPS) |
Case | Lian Li O11DX Dynamic White |
Audio Device(s) | iFi Audio Zen DAC |
Power Supply | Seasonic Focus+ 750 W |
Mouse | Cooler Master Masterkeys Lite L |
Keyboard | Cooler Master Masterkeys Lite L |
Software | Windows 10 x64 |
Club 3D is proud to announce its next generation Multi Stream Transport (MST) Hub models CSV-7300 (DisplayPort 1.4 Triple Monitor 4K60Hz) and CSV-1550 (USB Type C 3.2 Gen 1 DisplayPort 1.4 Triple Monitor 4K60Hz) which will be available in the market from beginning of December.
Since Multi-Monitor-Solutions are part of Club 3D's DNA for many years, we have taken the time to develop the best available solutions with those two new MST Hubs. They both can provide 2x 4K60Hz when the source device is not supporting DSC 1.2 (Display Stream Compression). In case the source device supports DSC 1.2 all three outputs can deliver 4K60Hz. Detailed Display/Resolution charts can be found in the respective specification sheet.
Club 3D Multi Stream Transport (MST) Hub DisplayPort 1.4 Triple Monitor 4K60Hz
CSV-7300 - The Club-3D Multi Stream Transport (MST) Hub DisplayPort 1.4 Triple Monitor is an integrated solution that allows you to enjoy displaying content onto three different monitors / displays simultaneously under MST mode.
The three screens can accommodate displaying different contents in parallel or by simply extending the existing screen, giving a panoramic view of the content which maximizes the user's visual experience. With its multi-display capabilities, this hub can serve as a convenient and hassle-free portable, alternative solution to the conventional docking station. It's the perfect solution for host devices which feature DP1.2 /1.4 graphic cards that supports all DP Alt mode video signal output, for gaming and commercial applications.
Club 3D USB Type C 3.2 Gen 1 Multi Stream Transport (MST)Hub DisplayPort1.4 Triple Monitor 4K60Hz
CSV-1550 - The Club-3D USB Type C 3.2 Gen 1 Multi Stream Transport (MST) Hub DisplayPort 1.4 Triple Monitor is an integrated solution that allow you to enjoy displaying content onto three different monitors / displays simultaneously under MST mode. The three screens can accommodate displaying different contents in parallel or by simply extending the existing screen, giving a panoramic view of the content which maximizes the user's visual experience. With its multi-display capabilities, this hub can serve as a convenient and hassle-free portable, alternative solution to the conventional docking station.
It's the perfect solution for host devices which feature DP1.2 /1.4 graphic cards that supports all DP Alt mode video signal output, for gaming and commercial applications. The MST Hub is directly powered from the host thru the USB Type C 3.2 Gen 1 connector.
