[Case Gallery] CM HAF 932
12 (0.00/day)
BC Canada
System Name SM8
Processor i7 4770k
Motherboard Asus Sabertooth Z87
Cooling XSPC Blocks and Bits Dual Pump Top and Tube Res
Memory 16GB Corsair Vengeance 1600 White LP
Video Card(s) 2 X GTX 670
Storage Kingston HperX 120GB SSD
Display(s) Benq XL2420T
Case Caselabs SM8
Power Supply Corsair AX850
Software Win 7
Specs:
Case: CoolerMaster HAF 932 Advanced(Black Interior)
Fans: 140mm Gelid Wing 14 Gamer x 2 (Bottom Intake and Rear Intake)
230mm CoolerMaster Blue LED (Front Intake)
Mobo: ASUS Sabertooth 67 TUF Thermal Armour
CPU: i7 2600K
Memory: 16GB Corsair Vengeance DDR3 1600 CL9-9-9-24
SSD: Kingston HyperX 120G(Boot Drive)
HDD: Seagate Barracuda 500GB(Storage Drive)
DVD RW: LG Super Multi
PSU: Corsair AX850
GPU: Nvidia GTX670 2-Way SLI
Cooling:
CPU: XSPC Raystorm Waterblock
GPU: XSPC Razor GTX 670 Waterblock x 2
Rad: XSPC EX360(Mounted Inside Top of Case)
Fans: Scythe Gentle Typhoon AP-15 x 6(Push/Pull)
Res: XSPC 5.25" Dual Bay Acetal
Pump: D5 Vario
Tube: TFC 3/8 ID-5/8 OD Blue UV
Fittings: BitsPower and TFC Silver
Fan Controller: G-Vans FC9 4 Channel @ 50 Watts per Channel
Temp. Sensors: Phobya Temperature Sensor G1/4 with C/F Display x 1 (Res)
Phobya Temperature Sensor x 1 (Case Internal)
Drain: BitsPower Mini-Valve(Installed in Bottom GPU WaterBlock
Cables: All Sleeved ( Jet Black)
Lights:
NZXT Sleeved LED Cable Kit - 2M - Blue x 1 with Modded Switch to Front Case Panel
XSPC 3mm LED-Blue Installed in CPU WaterBlock x 4
XSPC 3mm LED-Blue Installed in GPU WaterBlocks(1 ea.)
XSPC 5mm LED-Blue Installed in Res
Mods:
Watercooling Switches Fan
