[Case Gallery] [cocoru] Antec ISK300-150 A small water-cooled PC
Bartyu_Z-zone
9 (0.00/day)
Specs:
CPU:core2duo E4400
MB :Intel CLASSIC Series Desktop Board DG41MJ
PSC:picoPSU 160W
Thermaltake Original customize
Mods:
Small personal computer equipped with a water cooling system, but the inside is painted green, the interior is made ​​plain refreshing appearance by processing each part.
I added a picture of the radiator.
830 (0.19/day)
Sydney, Australia
System Name The White Breeze||Medion Akoya Ultrabook
Processor i7-3770k||Core i5-3317U
Motherboard MSI Z77 MPOWER||Laptop?
Cooling Custom TEC waterloop||Laptop?
Memory 16GB Kingston HyperX @ 2133MHz||8GB SDRAM
Video Card(s) 2X SLI MSI GeForce GTX 680 Lightning||Intel 4000
Storage Corsair GT 120GB, WD Caviar Black 1TB||500GB HDD with 32gb MSATA cache
Display(s) Samsung U28D590D 4k||14" LED
Case NZXT Switch 810||Laptop shell?
Audio Device(s) Creative Sound Blaster X-Fi surround pro 5.1||Dolby Home Theatre V4
Power Supply Seasonic XP-860 Platinum||Laptop Power Brick
Software Windows 7||Windows 8
I love the Green in the mesh. Quite a space saving idea with the hose on the outside, makes it look cool too.
2,667 (0.44/day)
Switzerland
Processor i9 9900KS ( 5 Ghz all the time )
Motherboard Asus Maximus XI Hero Z390
Cooling EK Velocity + EK D5 pump + Alphacool full copper silver 360mm radiator
Memory 16GB Corsair Dominator GT ROG Edition 3333 Mhz
Video Card(s) ASUS TUF RTX 3080 Ti 12GB OC
Storage M.2 Samsung NVMe 970 Evo Plus 250 GB + 1TB 970 Evo Plus
Display(s) Asus PG279 IPS 1440p 165Hz G-sync
Case Cooler Master H500
Power Supply Asus ROG Thor 850W
Mouse Razer Deathadder Chroma
Keyboard Rapoo
Software Win 10 64 Bit
how you can cool without radiators ?
4,357 (0.91/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
The E4400 doesn't output much heat. Its stock heatsink is about 2cms tall if I recall correctly; I think the reservoir might be enough for short sessions.
Bartyu_Z-zone
9 (0.00/day)
Thank you for your comment.
I would not put the radiator to overheat and this case has a small CPU, heat generation is small. I am equipped with a radiator at the bottom of the SSD. I stable in position 34 degrees at idle
76 (0.01/day)
I voted 10/10 because:
Nice Work!
Hajimemashite. Mr.Bartyu..san. :)
I love little case.
Your machine is little ..but very unique! :)
Keep your good works..!! ;)
Bartyu_Z-zone
9 (0.00/day)
Nice Work!
I love little case.
Hajimemashite rojiuranonekosann
Thank you!
I look forward to the day to meet you someday.
