- Nov 24, 2022
- 304 (0.38/day)
I got an option in bios for hyper threading and this processor should support that with single core? https://www.cpu-world.com/sspec/SL/SL6WJ.html it was not enabled in bios, does it improve much?
System Name | WorkInProgress |
Processor | AMD 7800X3D |
Motherboard | MSI X670E GAMING PLUS |
Cooling | Thermalright AM5 Contact Frame + Phantom Spirit 120SE |
Memory | 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32 |
Video Card(s) | Asus Dual Radeon™ RX 6700 XT OC Edition |
Storage | WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming)| 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500 |
Display(s) | LG GP850-B |
Case | Corsair 760T (White) {1xCorsair ML120 Pro|5xML140 Pro} |
Audio Device(s) | Yamaha RX-V573|Speakers: JBL Control One|Auna 300-CN|Wharfedale Diamond SW150 |
Power Supply | Seasonic Focus GX-850 80+ GOLD |
Mouse | Logitech G502 X |
Keyboard | Duckyshine Dead LED(s) III |
Software | Windows 11 Home |
Benchmark Scores | ლ(ಠ益ಠ)ლ |
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality case, 2 x Fractal Design 140mm fans, stock CPU HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
Why not try it and see for yourself how it works with your system and your configuration? Then report back to us how it went.it was not enabled in bios, does it improve much?
Yes i can place the motherboard in a bigger chassi to. The cpu temp without too much work seems to be 35 when i only use windows update. Can i found a tower cpu cooler for this model?
Is it possible to fit in a tower cooler to this motherboard?
System Name | Mini efficient rig. |
Processor | R9 3900, @4ghz -0.05v offset. 110W peak. |
Motherboard | Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked. |
Cooling | some server blower @1500rpm |
Memory | 2x16GB oem Samsung D-Die. 3200MHz |
Video Card(s) | RX 6600 Pulse w/conductonaut @65C hotspot |
Storage | 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds |
Display(s) | Samsung C24RG50FQI |
Case | Jonsbo C2 (almost itx sized) |
Audio Device(s) | integrated Realtek crap |
Power Supply | Seasonic SSR-750FX |
Mouse | Logitech G502 |
Keyboard | Redragon K539 brown switches |
Software | Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched). |
Benchmark Scores | Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts. |
you can spot the bad capacitors if they are bulged on the top. And you can power the fans directly from the power supply, you have 12v yellow (fast) and 5v red (quiet) options.I have 2 faults on the board to. The 3 pin cpu fan and chassi fan does not work, Can it be bad capacitors or have the connectors 3pin gone bad?
I did it before but i changed to a fan with molex. I took yellow and black or red and black, i can take a photo of the board, i think some caps looks strange, they looked fine but it seems to be some kind of dried layer on top.an and chassi fan does not work, Can it be bad capacitors or have the connectors 3pin gone bad?
