Compatibility check (Motherboard with CPU)
Aurum81
2 (0.00/day)
Hello,
can anyone tell me if MSI B450M PRO-VDH MAZ will work with AMD Ryzen 5 3400G?
Building a budget computor for a young gaming girl.
This is the hole build (sorry prices are in SEK):
If you have any other input on the build i would be happy to hear them but the main thing is to keep it pretty budged friendly. And i was thinking with this setup you can allways buy a graphics card later on.
No, the manual for it states "Supports 1st, 2nd and 3rd Gen AMD Ryzen™/ Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics/ Athlon™ with Radeon™ Vega Graphics Desktop Processors for Socket AM4".
Yea i saw that and got confused. Is this not a 3rd gen AMD Ryzen CPU? Then it should support it? I posted this by mistake in the motherboard forum as well. And a guy there says it should support that CPU..
Yes, this mobo supports 3400g even on its first bios release, so you can be 100% sure.
