Components to apply Artic Silver V (GPU? DDR ICs?)
jfromeo
4 (0.00/day)
Hi my fellow TPUppers.
My new rig just arrived some days ago, and I wanted to ask which components should I apply my thermal paste (Artic Silver V) to increase heat disipation.
I've been told there are several components (like DDR ICs, GDDR graphic memories...) where applying AS5 brings negative results due to its capacitive factor (minimal but can play havocs on your rig anyway).
Up to now, I've applied it to the CPU IHS, northbridge and southbridge. And I'm hesitating if I should apply it to any other components.
I've read its quite dangerous even applying it to GPUs. Should I buy Artic Ceramique for these type of chips (GPU, DDR ICs...)?
Many thanks.
Fitseries3
Eleet Hardware Junkie
15,508 (2.47/day)
Republic of Texas
I have always thought that AS5 or any silver compound was for metal to metal contact and ceramique is for metal to die or anything conductive contact.
5,739 (0.96/day)
Wakefield, UK
i put ArcticSilver5 on my 3870 GPU and for 1month its been cool and worked fine.
813 (0.13/day)
Almonte, Canada
System Name Sonny Boy
Processor i5 11600K 4.9GHz @ 1.35 Vcore
Motherboard AORUS Z590 Elite AX
Cooling Deepcool Gammix 240mm AIO
Memory 4 X 8GB Teamgroup DDR4 3200MHz
Video Card(s) ASUS RTX 3060 Ti GDDR6X
Storage Adata Legend 1TB
Display(s) Philips 27" 4K
Power Supply Corsair 750W
Mouse Razer Basilisk
Keyboard Razer Huntsman V2
Many thanks.
I have used AS5 before on just about everything. You do need to be careful that it does not end up on any component leads. I have used it on CPU'sand GPU's. However, I have now switched over to MX-2 since it has better performance and is completely non-conductive, non-capacitive.
When applying AS5 see the application guide on the manufacturuer website and follow it. Putting large goops of it is: a) expensive. b) worse cooling c) more danger of overspill on components.
newtekie1
Semi-Retired Folder
28,473 (4.09/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
What ^^he^^ said.
2,165 (0.34/day)
Wallingford, CT
Processor Intel i7-5930k
Motherboard ASRock Taichi X99
Cooling Phanteks PH-TC14PE
Memory 4x8GB HyperX FURY DDR4-2666 15-17-17-15
Video Card(s) MSI GTX 1070 Gaming X 8G
Storage 1x Plextor PX-512M6S SSD, 1x WD 750gb HDD, 2x Hitachi 2TB HDD, 1x Seagate 4TB HDD
Display(s) 2x Dell P2314H
Case Fractal Define R4
Power Supply Corsair AX860i
Mouse ROCCAT Kone Pure Color White
Keyboard Corsair K95 RGB - Cherry MX Brown
I use Ceramique for everything...not only does it work better but its non-conductive. The ONLY thing I have ever put AS5 on was a CPU...I wouldn't risk a NB, SB, GPU, or anything else.
aCid888*
2,754 (0.45/day)
In a state of flux...
OCZ Freeze is pretty damn good too, I used to use AS5 but I changed to Freeze and my temps went down by a few degrees allowing for higher clocks at the same temps as I used to run before :)
601 (0.09/day)
Under Columbus, Ohio
System Name Gen0cide
Processor AMD Phenom x4 920 2.8 @ 3.36 1.44v
Motherboard Asus M2N-Deluxe + WiFi
Cooling Thermoright True Rev C
Memory 2x 2gig of Gskill DDR2 1066 @ 5-5-5-15 20 2.125v
Video Card(s) Gigabyte 250 GTS 1 Gig
Storage 5x 730gig 7,200 RPM Raid 5 Western Digital Black
Display(s) Neovo F-417
Case Antec Twelve Hundred
Audio Device(s) On-Board
Power Supply SeaSonic M12 SS-600HM
Software Windows 7 x64 / Arch Linux-fluxbox(duel Boot)
I use AS5 on everything i tried freeze my cpu heated up more and my southbridge got alot warmer.
aCid888*
2,754 (0.45/day)
Apply it correctly ;)
I've seen anywhere from 2 - 5'C drop in temps at any given time (due to room temps, usually constant 21'C but sometimes goes up/down 3'C) since using Freeze...AS5 is good but its not as good in my view :)
813 (0.13/day)
Almonte, Canada
When you say your Southbridge "got warmer" was there a sensor built into the SB that you could read or were you just feeling the heatsink with your finger?
If the thermal compound is working better then your heatsink can actually feel warmer since you are transferring the heat more efficiently into the heatsink. The heatsink gets warmer but the device is cooler. Make sense?
601 (0.09/day)
no i was using a thermal thermometer from the bottem side of the mobo and from the top - but im also water cooled and passively cooling my nb,sb with heatsinks
