- Mar 25, 2009
- 9,817 (1.70/day)
System Name | Old reliable |
Processor | Intel 8700K @ 4.8 GHz |
Motherboard | MSI Z370 Gaming Pro Carbon AC |
Cooling | Custom Water |
Memory | 32 GB Crucial Ballistix 3666 MHz |
Video Card(s) | MSI RTX 3080 10GB Suprim X |
Storage | 3x SSDs 2x HDDs |
Display(s) | ASUS VG27AQL1A x2 2560x1440 8bit IPS |
Case | Thermaltake Core P3 TG |
Audio Device(s) | Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset |
Power Supply | Zalman EBT-1000 |
Mouse | Mionix NAOS 7000 |
Keyboard | Mionix |
Computer Upgrade King demoed 2 new extremely powerful and colorful mATX gaming desktops at CES that release in Spring 2019. On display at Patriot's suite, they featured their Continuum Mini which has an intense infinity mirror front panel with large side vents to ensure excellent air flow. Inside, there was an NVidia RTX 2080 TI GPU and an Intel i9-9900K CPU with their own custom cooling system consisting of an RGB CPU water block, anodized brushed aluminum reservoir and pump combo, front mounted 240mm radiator and lotus style ARGB fans.
On display at AMD's suite, they featured their Stratos Mini which has a triple RGB fan front panel with metal blade design to ensure excellent air flow. Inside, there was a Gigabyte Vega 56 GPU, an AMD Threadripper 2950X CPU with their own custom cooling system, a Team Group T-Force Delta RGB SSD, and halo style RGB fans.
Boasting a small footprint of just 27 liters, these exclusive Computer Upgrade King Continuum and Stratos Mini case designs are what gamers have been craving: powerful, compact without compromising performance, and affordable gaming PC without the need of a bulky desktop tower. The chassis is made of steel for durability and a premium appearance. It features dual-hinged tempered glass side panel for easier access to your components for future upgrades.
The mini Stratos and the mini Continuum case with 6 pre-installed ARGB high airflow fans will start at $99.99. An entry level VR Ready desktop will start at $549.99.
With exceptional cooling capacity supporting powerful configurations up to a 250W Threadripper 2990WX or and 250W+ RTX 2080 TI or Titan graphics, these desktops pack quite the punch for their size. Open loop cooling systems will be offered starting as low as $100 above the cost of 240mm AIO.
Features include:
Features include:
- Support for Top or Front mounted 240mm radiator for choice of AIO cooler or half or full open loop cooling system
- Up to Two 2.5in HDDs and a single 3.5in HDD
- ATX PSU up to 180mm length.
- GPU length up to 300mm with radiator for Continuum Mini and 325mm for Stratos Mini
- Dual hinged tempered glass side panel
- 6 pre-installed high pressure 2,000rpm PWM 5V addressable RGB fans (Halo or Lotus style) with dual mode controller for motherboard software or remote control
- Removable magnetic top and PSU bottom mount dust filter for quick and easy cleaning
