- Jul 8, 2005
- 3,087 (0.44/day)
- Victoria, BC, Canada
System Name | Meshlicious Monster |
Processor | Intel Core i5-10600T |
Motherboard | MSI Z490I Unify |
Cooling | NZXT Kraken Z53 with 2x Noctua Redux 1300 RPM PWM fans |
Memory | ADATA 16 GB 3200 Mhz DDR4 |
Video Card(s) | MSI GeForce RTX 3070 Gaming X Trio |
Storage | TeamGroup 1TB NVMe SSD |
Display(s) | Asus ProArt 27" 1440P, 75Hz |
Case | ssupd Meshlicious with mesh side panels |
Power Supply | Fractal Design Ion 660 W Platinum ATX |
Mouse | Corsair Dark Core RGB Pro Wireless |
Keyboard | Microsoft Sidewinder X4 Keyboard |
Software | Windows 10 Home |
You will find two new CPU coolers at their booth. The first is the UFO V51, which can simply be described as massive. The prototype on display uses two 80 mm fans and four heat pipes. We were told, that the production unit will have the same design, but will be a bit smaller to maintain compatibility. It is constructed of aluminum with a pure copper base. The second CPU cooler does not yet have a name, but also uses two fans.
Their new AL and AX power supply series can also be viewed. The AL PSU is available with up to 650W, is 80 Plus certified and is actually semi-passive. The fan stops spinning if not needed. The AX series goes up to 1050W and comes with a modular cable tree. These are also 80 Plus certified.
Another very unique power supply is the AC100P series. It is a single output + USB power AC/DC unit. This means that you can not only output AC, but DC as well and can supply power to a USB device as well. This unit is ready for mass production and will cost around 100 US Dollars at retail.
