Connecting Arctic LFIII ARGB to motherboard
antos_151
14 (1.40/day)
So i got a ,,AsRock z690 Phantom Gaming ITX/TB4” and Arctic LFIII ARGB 360. I don’t want to do the all in one cable because as i believe connecting every cable individually gives you much better control. So on my motherboard i have: CPU_FAN1, CPU_FAN2, CHA_FAN1. And correct me if i’m wrong but i think this AIO has 3 cables to connect: Pump, Fan, VRM (and argb ofc) . I thought about connecting Pump to cpu1, Fan to cpu2 and VEM to cha1. So you guys think it’s fine? I got other fans on my nzxt controller connected via USB 2.0. Oh and also are the fan cables already daisy chained or i have to do it myself?
470 (2.81/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
If you cannot tell by looking, you really should let someone else install it for you.
470 (2.81/day)
Texas, USA
No one thinks you are dumb. "I got" infers to me that you are already in possession of it. I will not presume next time, but it could have been more clear.
Any PWM fan connector is fine. There are only 3 on the motherboard, so those are the ones you'll be using.
Since the manual, install guide, etc. (all available documentation) says nothing about you having to connect the radiator fans to each other, one can assume that it is already done for you. You'll know very quickly once you receive it.
antos_151
14 (1.40/day)
Alright thanks for help. Can’t lie my english is pretty bad because i’m from eastern europe and only 15yo so im still learning but trying to text as clear as i can.
3,778 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
Have it in your hands first and take it from there.
I have an LFII nonRGB 420 and connect it to board with all-in-1 cable on the CPU_OPT header, and set a curve through Gigabyte's software.
When I first connect it to CPU_FAN the pump wasn't working. All of my board's FUN/PUMP headers (7) are 4pin PWM capable but not all can work a pump.
Keep that in mind.
If your board doesn't have a CPU_OPT header then either CPU_FAN1 or CPU_FAN2 is a pump capable if not both.
Maybe this can help you
antos_151
14 (1.40/day)
Keep that in mind.
I will keep an eye on that. I will try go with seperate cables but if i will have any issues i will go with the all in one. But i don’t think this issues will happen because a lot changed from LFII to LFIII. But we never know, thanks for info
