[Case Gallery] Convective silence
dead_meat
Specs:
ASUS A8R32-MVP Deluxe
AMD Athlon 64 3500+ CPU
Asus EN7600GT
2GB RAM
Antec P182 case
Antec Phantom 500 Passive PSU
DIY Passive Radiator
+ 2x samsung 22" LCD's
Mods:
Watercooling, DIY passive radiator, Switchpanel for the pre assembled (and quite unnecessary) case fans.
The idea was to make a pc that would be totally silent.
I also wanted a somewhat Darth Vaderish look since Las-Vegas-in-a-box like LED pollution annoys me a bit. I constructed a passive heat exchanger for my old watercooling rig so I could get rid of all the fans in the system. Of course, it also required a power supply that had no actively rotating fans (the Antec Phantom). I mounted the Eheim pump and Innovatek tank on top of the DIY radiator, so it is a separate module with shut off valves and quick connectors and can be disconnected easily for maintenance. This thing turned out to be quite good, the noisiest part of the system is now my second monitor (old 17" CRT) that keeps a slight humming sound.
Update: the second CRT broke, so I swapped to 2 x 22" LCD:s,
totally silent now....
AsRock
TPU addict
19,076 (3.00/day)
UK\USA
Welcome to the TPU forum..
Looks good like to see more pics though ones that show more of what you have done.
dead_meat
Thanks,
I added one picture , and I will post more when I get a decent cam.
Dont want to snap the new ones with a crappy cell phone camera...
AsRock
TPU addict
19,076 (3.00/day)
UK\USA
I am not on about the quality of the pics but how close the camera is. Like to see some taken further away from the computer.
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
hope your planing on upgrading your hardware, just seems like a bit much of a water cooling setup, for your hardware, other then that WOW nice job on the water setup looks,, AWESOME.
intel igent
4,640 (0.65/day)
Toronto, Canada
System Name old school / new school
Processor 3.0e C0 @ 3.6 / e5200
Motherboard p4p800e-dlx / p5q-DLX
Cooling custom water see sig / air
Memory 2x1g oczPC4000EbPl / 2x2g ocz2rpr1066
Video Card(s) 3850AGP / 4890vaporX
Storage 36g raptor+120g wd / wd 1001fals 1tb
Display(s) BenQ / sharpAQUOS LC-37D64U
Case modded antec plusview / generic
Audio Device(s) audigy 2zs / ASUS Xonar HDAV1.3
Power Supply fan/cable modded powerstream 520 / OCZ 700mxsp
Software Xp pro SP2 / VISTA ultimate OEM
Welcome to TPU!
Nice rig! Care to share some more details about your rad?
dead_meat
I am not planning to upgrade the hardware because there is no need for me to do so at the moment. If I want / need more juice I will simply overclock, the rad is quite effective ...
This will do for a one more year or so, after that, I will a replace these with the best MOBO, CPU, RAM & 3D card that i can find and so we go for another few years....
The watercooling parts (except the rad) in this setup date back to 2001 and have seen 24/7 use in three setups before this.
AsRock
TPU addict
19,076 (3.00/day)
UK\USA
Just becouse hardware is not the latest and greatest it should NOT go against the actual mod.. I hate it when ppl put down a modded case \ system due to old \ older hardware.
dead_meat
Welcome to TPU!
Thanks,
The rad itself is an old crude aluminium 20kW DC power supply cooling profile.
The rounded aluminium corner pieces and backplate are made from a
telecommunications cabinet manufactured in the 70's. Four meters of copper tubing is connected using silver soldered capillary T-pieces that i bought for about 2$.
The copper tubes are soldered to silvered flat copper pieces used to link battery terminals
and screwed in to the rad (with some heat sink paste).
After this, I painted it with acrylic silk black (for the not so glossy finish).
994 (0.15/day)
SoCal
Processor Intel C2D E6420 (3.2 gHz @ 1.365v)
Motherboard Gigabyte 965P-DS3
Cooling Zalman CNPS9500 LED
Memory 4 x 512mb Corsair XMS2 DDR2 667
Video Card(s) Visiontek HD 4870 512mb
Storage 200gb Maxtor SATA, 400gb WD SATA
Audio Device(s) Audigy 2 ZS
Software Windows XP Pro SP2
I have to say, you did an awesome job with this. Have you tried overclocking this rig yet?
dead_meat
Yes, 10-20% CPU & GPU overclock is reasonable , but after this you might get crashes & lockups etc..as usual, these values are from my pages for comparison:
Convection rad
idle CPU 30C, GPU 35C, MOBO 26C, full overnight torture CPU 40C, GPU 55C, MOBO 28C
Old rad
idle CPU 26C, GPU 32C, MOBO 26C, full overnight torture CPU 38C, GPU 50C, MOBO 28C
You can see that with the old radiator the temps were few degrees lower than with this, but hey...the old one had four 120mm fans on it .....
Also, the hotter this gets, the more efficient it is as it is not cooled by force.
1,372 (0.21/day)
Chicago, IL
I use old hardware all the time, not putting his mod down, just asked if he was planing to upgrade,, & he said his computer runs fine with the old hardware. the computer I'm using right now is an old 2.6 P4 with 1.5gb of PC133 memory, but I dont think I would spend all that time building a kick-ass water cooling setup for it,, Just my opinion. it's his time not mine. still think he did a awesome job on it.
3,296 (0.53/day)
System Name Thakk
Processor i7 6700k @ 4.5Ghz
Motherboard Gigabyte G1 Z170N ITX
Cooling H55 AIO
Memory 32GB DDR4 3100 c16
Video Card(s) Zotac RTX3080 Trinity
Storage Corsair Force GT 120GB SSD / Intel 250GB SSD / Samsung Pro 512 SSD / 3TB Seagate SV32
Display(s) Acer Predator X34 100hz IPS Gsync / HTC Vive
Case QBX
Audio Device(s) Realtek ALC1150 > Creative Gigaworks T40 > AKG Q701
Power Supply Corsair SF600
Mouse Logitech G900
Keyboard Ducky Shine TKL MX Blue + Vortex PBT Doubleshots
Software Windows 10 64bit
Benchmark Scores http://www.3dmark.com/fs/12108888
Looks wicked man! I love it! If I was going to setup a lc rig, I'd have the same outcome! Love it! 10/10 flat!
3,296 (0.53/day)
System Name Thakk
Cooling H55 AIO
Case QBX
Mouse Logitech G900
I voted 10/10 because:
7,662 (1.20/day)
c:\programs\kitteh.exe
Processor C2Q6600 @ 1.6 GHz
Motherboard Anus PQ5
Cooling ACFPro
Memory GEiL2 x 1 GB PC2 6400
Video Card(s) MSi 4830 (RIP)
Storage Seagate Barracuda 7200.10 320 GB Perpendicular Recording
Display(s) Dell 17'
Case El Cheepo
Audio Device(s) 7.1 Onboard
Power Supply Corsair TX750
Software MCE2K5
this is secks ... 11/10
993 (0.15/day)
Los Angeles...U.S.A
Processor i7 920
Motherboard EVGA X58
Cooling eight 120mm fans, Swiftech GTZ cpu block, 3 120mm radiator, MCP655 pump, primochill tubing
Memory 6 gig G-Skill DDR3 1600
Video Card(s) GTX 285's (SLI)
Storage 500GB Western Digital
Display(s) 3 Asus 23 in inchers
Case Lian Li A77B
Audio Device(s) on board 7.1
Power Supply Corsair 1000
Software win 7 64
Wicked water set-up... :)
1,773 (0.29/day)
Detroit, MI
Processor AMD Ryzen 7 5800X3D
Motherboard ASUS TUF Gaming X570-Pro Wifi II
Cooling Hyper 212 EVO v2
Memory 2x16GB G.Skill DDR4-4000
Video Card(s) AMD RX 6750 XT
Storage WD Black SN850 2TB, various other SSD's from ages past
Display(s) LG 27GL850 1440@144, AG Neovo EM2701QC 1440@75
Case Zophos EVO Silent by Raijintek
Audio Device(s) HyperX Cloud II Wireless headphones
Mouse ProtoArc EM01
Keyboard Razer Blackwidow X Chroma Mercury
pShh, hardware is unimportant in a good mod. There's a lot of work done to this thing, I see it, and much appreciate it. Making your own rad out of copper tubing, and silver solder is worthy of a 10 to me.
