Converting MOV. to AVI or MPG format?
4,251 (0.73/day)
California
Processor Intel i7 10700k
Cooling Corsair H100i
Audio Device(s) Onborad dts
Power Supply Corsair RX 650 W
Mouse Roccat Kiro
Keyboard Razer Tarantula
Software Windows 10 Home x64
Hello my fellow TPUer's,
I want to edit some videos of the Muse concert I saw last night and am looking for a good free program that will allow me to convert a MOV. file to an AVI or MPG format. What do you guys recommend?
Thanks for the help :)
~T77~
2,417 (0.41/day)
Whitby, Ontario
Processor AMD Ryzen 5 2600
Motherboard MSI B450 Gaming Plus
Memory GSkill 8GB Dual Channel DDR4-2800
Video Card(s) MSI GamingX RX580 4GB
Storage Kingston V300 240GB SSD + WD Green 2TB
Display(s) ACER K212HL 27" + Haier 55" + Lenovo Explorer Mixed Reality Headset
Case Enermax Ostrog (Red)
Power Supply EVGA SuperNOVA B2 750W
Software Win10 64bit
4,251 (0.73/day)
California
Mouse Roccat Kiro
So far Handbrake appears to be a good program, but I am a novice when it comes to video codec and I after watching some how-to's on youtube I think I figured it out... but will have to wait and see the finish results.
EDIT: Okay so that didn't work, I have no idea how to use this program. :(
7,233 (1.03/day)
Motherboard ASRock B650M PG Riptide Bios v. 3.08 AMD AGESA 1.2.0.2 \ Lenowo BDPLANAR Bios 1.68
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
Software Win11 Pro 23H2 UK | Win11 LTSC UK / Arch (Fan)
it's actually easy, click source and open video file and find ur mov file and u can got presets if u need it on ur phone or anything u can use one of them...
and u can choose between mp4 or mkv...
or try Freemake Video Converter it's free, supports gpu encoding and a lot of in and put formats: http://www.freemake.com/
4,251 (0.73/day)
California
Mouse Roccat Kiro
Yeah I saw the options for mp4 and mkv, but where is the avi, mpg or mpeg format options? because those are the ones I need. I will check out Freemake as well, thanks.
Mussels
Freshwater Moderator
58,413 (7.98/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
handbrake if you want fine control, freemake if you want a one click solution.
12,311 (2.28/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
574 (0.13/day)
Australia
Processor Intel® Core i5 6600
Cooling Hyper 212 Evo
Memory G.Skill Ripjaws V Series 16GB DDR4 2400mhz
Video Card(s) Gigabyte Geforce GTX 960 G1 4GB Gaming
Storage 256GB Intel SSD 525 Series
Display(s) 24" LG LED Monitor
Case Corsair Carbide 200R
Power Supply Seasonic MK12II 620W
Mouse Logitech G5
Keyboard Logitech G110
Mindweaver
Moderato®™
8,246 (1.46/day)
Charleston, SC
System Name Tower of Power / Delliverance
Processor i7 14700K / i9-14900K
Motherboard ASUS ROG Strix Z690-A Gaming WiFi D4 / Z690
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / Air
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) DDR4 3600 / DDR5 2x 16gb
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / GeForce RTX 4080
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / NVM3 PC801 SK hynix 1TB
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, 2x LG HDR 32" 60hz 4k / 2x LG HDR 32" 60hz 4k
Case Phantek "400A" / Dell XPS 8960
Audio Device(s) Realtek ALC4080 / Sound Blaster X1
Power Supply Corsair RM Series RM750 / 750w
Mouse Glorious Gaming Model D Wireless / Glorious Gaming Model O 2 Wireless
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (128gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 11 Pro x64
Benchmark Scores Yes
I've used Pazera to convert any video file to avi. I use Handbrake to backup my movies to mp4 or mkv to play on my android tablet. Handbrake is a great product, but your limited to mp4 and mkv files. :toast:
4,251 (0.73/day)
California
Mouse Roccat Kiro
Thank you for all of your guys recommendations, I now have some good resources for the future. :)
I have decided to stick with Pazera, it worked perfectly for my project. Thanks Midweaver!
Aquinus
Resident Wat-man
13,161 (2.83/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
12,062 (2.64/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
XMedia Recode if you want the German fine tuning sort.
