[Case Gallery] Cool It Master
93 (0.02/day)
Processor AMD 1700X
Cooling Corsair H110iGT
Memory 16GB Corsair VENGEANCE LPX 3200 CL16
Video Card(s) VEGA 64 w/ Corsair H100
Storage 480GB Patriot Hellfire -- WB Blue SN550 1TB -- WD Red 2TB Raid 0 -- WD Black 4TB
Display(s) Dual Benq 24"
Case Corsair C70 VENGEANCE
Specs:
Cooler Master Ammo 533
ASUS Maximus Formula SE
Intel E6850
4GB PC2-8500 Crucial Tracer
CrossfireX Dual 3870X2
Seagate 120GB, 320GB, 500GB HDD
OCZ GameXtreme 1010 Watt PSU
Freezone Chiller
Freezone Elite Chiller
Mods:
Modified a Cooler Master 4-in-3 Drive Bay Caddie to house the Freezone Elite piped to Dual 3870X2. Piped the CPU and Northbridge Fusion Block to Freezone gen1. Dual Liquid Loops
Cool It Systems in a Cooler Master case: Cool It Master... Original?- NO, Cheezy?- 110% Yes. This my LAN Party Machine. 'Beat the Heat, KILL the noise!' The first gen Freezone I had owned for some time now, piped it to chill the NB and CPU in a series loop. Order a Freezone Elite dry mounted it into the Cooler Master 4-in-3 drive bay caddie (STB-3T4-E3-GP) and piped it to the dual 3870X2 mounted with koolance water blocks in parallel. Use Cool It Systems patented MTEC contol system to regulate each chiller from the desktop. I will get flamed for it, but I apologize for my rookie wire management, should have went with a modular power supply.
93 (0.02/day)
Processor AMD 1700X
More on the build here ---> CLICK ME
667 (0.10/day)
QLD, Australia
Processor Ryzen 9 7950X3D
Motherboard Asus ROG X670E GENE MATX
Cooling Phanteks Glacier One 280MPH AIO
Memory G.Skill 48GB (2x24GB) F5-8000J4048F24GX2-TZ5RK Trident Z5 RGB 8000MHz DDR5
Video Card(s) ASUS TUF Gaming Radeon RX 7900 XTX OC Edition 24GB GDDR6
Storage Crucial T700 Gen5 2TB NVMe | Crucial P5 Plus Gen4 2TB NVMe | Crucial P5 Plus Gen4 1TB NVMe
Display(s) AOC U3277PWQU 32in 4K
Case Phanteks Enthoo Evolv mATX TG
Audio Device(s) Onboard SPDIF --> Logitech Z-5500
Power Supply Seasonic ATX 3.0 VERTEX-GX-1000
Mouse Razer Mamba Chroma
Keyboard Razer Cynosa V2 Chroma
Software Arch Linux - KDE Plasma 6.1.3 (Wayland)
9/10. Commendations on the mod's with the coolit systems. Wire management isn't too bad, cabling sleeving may help. Still, great job. How do you find the coolit freezones?
93 (0.02/day)
Processor AMD 1700X
Simply amazing! I ran the Gfx cards flat out for hours with the Freezone Elite flat out as well, and it held the cards at 40 degrees celcius under Vista. When the system idles, it isn't any louder than my laptop.
Many people can't seem to justify the price of a Freezone or Freezone Elite, but their prebuild kits are incredible. The old first gen freezone was able to keep the cpu temp at 42 degrees celcius when i used run it at 4ghz on a DFI LANPARTY UT ICFX3200-T2R/G.
667 (0.10/day)
QLD, Australia
I was running a feezone for quite awhile and was very happy with it. Not using it now as I was getting alot of condensation on the chiller units from the mobo chipsets whilst running an Asus 780i Formula II. Don't know how hot the intel boards get, though keep an eye on it.
1,372 (0.22/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
Now that sucker is packed full of goodies, as far as the W/M, I feel you did the best you could for that size case,, Nice system & pictures, very well done. I voted 8/10........ Have time check out my Rig http://www.techpowerup.com/gallery/1523.html Thanks.
