- Oct 9, 2007
- 47,407 (7.52/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Extreme gamers continue to seek high performing gaming notebooks to keep up with an ever increasing demand from the e-sports scene. However, notebooks tend to have cooling that is almost insufficient for the high-end hardware that they contain. The SF-19, the first in a new series of gaming notebook coolers, uses a highly effective and customizable cooling design. CM Storm seeks to target users of large notebooks with sizes of 19" and beyond.
Designed with future compatibility in mind, the SF-19 comes equipped with 4 advanced USB 3.0 ports which make it future-proof for all devices such as high speed hard drives, high performance gaming mice, headsets, and peripherals that require high speed transfer rates.
Utilizing a Multi-Light Shader, The SF-19 helps create an environment for any gaming intensity by providing 7 colored light profiles. It makes creating an ambiance to fit a gamer's mood an easy task. In addition, special consideration is paid to mobility in that the SF-19 can effortlessly be transported to a new gaming battleground via its swift carrying handle.
The optimum solution in thermal environments
In order to protect a gamer's gear while it's under heavy stress from game play, the SF-19 employs its incredible ability to dissipate all of that excess heat through its surface. It also has a strengthened mesh that can withstand all notebook sizes up to 19". It also features 2 x 140mm adjustable turbine fans that are specially engineered to provide unprecedented airflow that keeps notebook components running at optimal temperatures.
To achieve maximum cooling efficiency, the SF-19 fans whirl at an impressive 2600 RPM fans. These fans come affixed to a removable fan bracket that allows gamers to use either 140mm or 120mm fans. With this, fan positions can be adjusted to create an optimum airflow pattern. The SF-19 is built to not only extend your notebook lifespan, but also enhance your combat effectiveness in competition by keeping components frosty while you're under fire.
